Date/Time: Sun, 26 Jan 2025 07:30:29 +0000
(Below) Chart Trade Window Graphic/Color Adjustment
View Count: 906
[2019-02-17 04:17:22]
DGee - Posts: 82
I am trying to custom my DOM's in Sierra and wondering if anyone can help? I'm trying to darken below the 'chart trade window'. I went into the Global Settings and tried every scenario under 'chart trade window' but just can't manage to tweak this. It may be that it's not under the 'chart trade window' background setup and it's called something else. Actually trying to darken everything as much as possible including the menu (Chart, Trade Window) up top. See attach and note under the 'chart trade window.' Any input is appreciated. Thank you!
DG
imageDom snippet2.png / V - Attached On 2019-02-17 04:17:04 UTC - Size: 17.72 KB - 267 views
[2019-02-17 18:53:30]
User907968 - Posts: 825
Chart trade window background is the correct setting to colour the area you are trying to, make sure that the individual DOM is set to use global graphics settings.
Graphics Settings: Use Global Graphics Settings Instead of These Settings
[2019-02-17 20:13:13]
DGee - Posts: 82
Okay, I unchecked the global graphics settings in the individual DOM. The DOM went back to it's original colors (that's because I custom the individual DOM not using the Global graphic setting) and now below the chart trade window darkened. However I'm trying to change back to the colors I custom and nothing is changing.
[2019-02-19 05:10:08]
This is not clear for us. Just make sure you are setting the colors through the Chart >> Graphics Settings window.
