Date/Time: Mon, 28 Sep 2026 14:23:21 +0000
[Programming Help] - Formula
View Count: 1107
[2019-02-15 20:01:08]
User228927 - Posts: 55
I am using this formula-=INDEX(K$3:K$100,MATCH(TRUE,K3:K100<>0,0)) to find first non zero cell entry in spreadsheet study. The formula works in a regular excel spreadsheet, for arrays have to press Ctrl+Shift+Enter, but doesn't seem to work in the spreadsheet study spreadsheet. Will formulas like this not work in Sierra Spreadsheet Study.
[2019-02-17 06:57:53]
No, this formula will not work. For what is supported with these functions, refer to:
Spreadsheet Functions: Available Functions
[2019-02-17 14:56:59]
Sawtooth - Posts: 4355
Try this in a Formula Column, e.g. in L3:
=IF(K3<>0,K3,L4)
This works in a static cell, e.g. H3, but you must first use a Formula Column to create a boolean TRUE:
L3:
=K3<>0
H3:
=INDEX(K3:K100,MATCH(1,L3:L100,0),1)
Or this in a Formula Column, e.g. M3:
L3:
=K3<>0
M3:
Date Time Of Last Edit: 2019-02-18 22:50:51
[2019-02-18 19:56:40]
yes, that works. Thanks
