Date/Time: Mon, 14 Sep 2026 01:52:48 +0000
Recent bid/ask volume highlighted in both columns
View Count: 1995
| [2019-02-15 07:25:43] |
| User483121 - Posts: 3 |
When trading off the DOM I noticed that both columns become highlighted for Recent Bid/Ask Volume, but it used to be so that only the last traded volume would show up (either bid OR ask.) How can I change it so that only the last traded volume gets highlights, either Bid or Ask volume?
| [2019-02-15 16:55:56] |
| John - SC Support - Posts: 47854 |
There was a change made to always highlight the last traded Recent Bid and Ask. We are in the process of adding an option to allow it to work like it used to, where only the Bid OR Ask will be highlighted. It should be done in about a week.
| [2019-02-19 16:54:51] |
We have added the option Display Both Last Traded Recent Bid and Ask Background to the Chart DOM Settings window. When this is unchecked, the Recent Bid and Ask Background highlighting (when enabled) will work as they used to with only the single last traded Bid or Ask highlighted instead of both. Note that for new charts this option will be selected on by default. Look for this in the next Pre-Release (v 1876). For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2019-11-22 20:35:25] |
| NotIll - Posts: 122 |
Is it possible to have this function for current traded bid/ask volume? Or am I asking something crazy here?
