Date/Time: Mon, 03 Feb 2025 09:54:48 +0000
[User Discussion] - Renko chart - Reversal bars
View Count: 1080
[2019-02-15 05:31:32] |
YCL - Posts: 1 |
Hi there, Would it be possible for the adjusted renko to show a reversal bar which is twice the length of a continuation bar? Similar to the chart attached. Otherwise, if this is not possible/supported, how would I go about duplicating the adjusted renko bar and make changes to the code for a custom chart? The example below would be a 4 tick bar with a 8 tick reversal bar. Thank you for your help! |
[2019-11-10 07:19:35] |
SWilk - Posts: 11 |
Can somebody answer this question? I would like to know it to. I think its something like this. Renko Bar Charts: Flex Renko Inverse Setting Bars EXAMPLE Settings: 30-15-60 Date Time Of Last Edit: 2019-11-10 08:12:58
