Date/Time: Sat, 15 Mar 2025 07:51:04 +0000
Maximum Number of Open Positions
View Count: 2256
[2019-02-15 01:16:29] |
ZenAlchemist - Posts: 23 |
Is it possible to set the maximum number of open positions? I looked in the global profit/loss management settings, but didn't see it. For example, if I could set the maximum open positions to 1, then if I accidentally hit a buy/sell button more than once, then the second click would not send a second order.
[2019-02-15 02:02:15] |
User90125 - Posts: 715 |
Go to Global Settings >> Symbol Settings and you can set the "Use Global Trade Position Limit" quantity as needed. You can also individually set the quantity for the Trade Position Limit and Order Quantity Limit by clicking on the Additional 2 tab for each Symbol as well. |
[2019-02-15 02:29:04] |
Awesome! Thanks.
[2019-02-15 18:12:21] |
Here is the documentation for that option: https://www.sierrachart.com/index.php?page=doc/GlobalSymbolSettings.php#GlobalPositionLimit Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-07-16 14:53:52] |
User5044343 - Posts: 68 |
Is there a away to set this value through ASCIL or dtc protocol?
[2022-07-16 15:28:09] |
No this is not supported.
