Date/Time: Sun, 26 Jan 2025 06:50:41 +0000
Supported Data Services
View Count: 618
[2019-02-14 23:39:26] |
User117499 - Posts: 6 |
I don't see DTN-IQ under "Data/Trade Services" any longer. Is it still being supported? Thanks in advance! |
[2019-02-15 05:29:07] |
Yes, IQ Feed is still supported. It is listed here and you will find the documentation for it: Table of Contents | (Supported Data and Trading Services) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-02-15 05:29:24
