Date/Time: Sun, 24 Nov 2024 16:07:55 +0000
spreadsheet number format for forex
View Count: 1226
[2013-11-14 14:02:46]
plaforte - Posts: 13
Hello, I made a SC spreadsheet and inputted few forex symbols to get the quotes that works fine, but when I want to put a variable in a cell, I cannot format the number in the cell to display with 4 decimals, I get maximum 2 decimals. How can I format to see the 4 decimals ?
Thank you
[2013-11-14 14:52:20]
OK I found the solution. SC spreadsheet is different from Excel in some cases.
Thank you
[2013-11-14 21:13:43]
To set the Number Format, refer to the documentation here:
http://www.sierrachart.com/index.php?l=doc/doc_WorksheetMenu.html#NumberFormat
