Date/Time: Sun, 26 Jan 2025 07:04:45 +0000
I can't draw Volume profile, i can't see number bars in chart
View Count: 915
[2019-02-14 16:43:42] |
Hopeman - Posts: 166 |
Hello the study of Numbers bars to disappeared and the numbers calculkate values bar can not make any calculation, I do not know why this happened. yesterday everything worked perfect !! Many thanks in advance
[2019-02-14 19:42:05] |
This is now resolved for your account. Previously your account was on the Standard service package. You need to have the Advanced service package which your account is now using.
