Date/Time: Mon, 14 Sep 2026 06:10:42 +0000
Excel input option
View Count: 1863
| [2013-11-14 13:41:33] |
| plaforte - Posts: 13 |
Hello, I refer to the old support board, a SC response to a question was "... You will want to use the Sierra Chart Worksheet Study and set the Use Excel input to Yes...." I cannot find this setting anywhere, can you refer me to the documentation that refers to this Excel input setting. Thank you |
| [2013-11-14 14:11:00] |
| Sawtooth - Posts: 4352 |
The 'Use Excel' option is not available in the Spreadsheet System for Trading study. It is only available in the other two spreadsheet studies.
| [2013-11-14 14:23:00] |
Thank you Tom, I am actually using a "Spreadsheet Study". When I add it to a chart and open the settings, there are 3 tabs 1. Settings and inputs 2. Subgraphs 3. Alerts I cannot find on any of these 3 tabs the "Use Excel input", where is it located ? |
| [2013-11-14 14:38:55] |
ok I got it Thank you |
