Date/Time: Sun, 26 Jan 2025 07:11:32 +0000
Latency issues with CTS T4
View Count: 2872
[2019-02-14 14:53:36] |
User40526 - Posts: 166 |
I am now having frequent latency issues with data from T4. I have read the documentation and tried everything but the problem persists. My CPU is running below capacity. Is there a problem with the T4 connection/server? Thank you |
[2019-02-14 14:59:02] |
User907968 - Posts: 825 |
I am having frequent disconnection issues with CTS T4 FIX again today, maybe this is the same problem you are seeing.
[2019-02-14 15:00:39] |
There was also a disconnect for a few seconds
[2019-02-14 15:06:05] |
User469312 - Posts: 97 |
I just posted the same issue
[2019-02-14 15:13:39] |
binaryduke - Posts: 377 |
+1 CTS is all over the place today. Useless.
[2019-02-14 15:19:11] |
I can tell you I know people who are using CTS with Sierra Chart, but they are not connected through Top Step, and they have no issues. They didn't the last time this happened, as well.
[2019-02-14 16:34:27] |
We see you are using CTS. If you are doing live trading, starting next week we can move you over to this new solution: Sierra Chart / Trading Technologies Futures Order Routing Service If you are using CTS with Top Step Trader and do not have a funded futures trading account, we will have a new solution out we hope in about two months which will use our reliable futures trading evaluator service. If you do have a funded futures trading account do let us know and we will give you further instructions. There is not anything we can do about the CTS issue and our plan is to gradually be phasing out CTS. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-02-14 16:35:03
[2019-02-14 17:10:04] |
Thank you. I do not have a funded futures trading account. I am trying to qualify, at the moment. |
[2019-02-14 18:28:13] |
Okay once we become a direct market data vendor with the CME, we will be able to provide you a solution. But this is not likely to be for a couple of months from now.
