Date/Time: Sun, 26 Jan 2025 07:06:13 +0000
Placing orders with Ctrl + left / right click
View Count: 710
[2019-02-14 12:38:36] |
User97684 - Posts: 136 |
Hi, PLs help - how to create Ctrl + Left / Right clicks for entering orders on the screen ? Many thanks |
[2019-02-14 12:53:11] |
User403598 - Posts: 15 |
there is no such possibility. Chart trading described here: Chart Trading and the Chart DOM: Entering Orders From the Chart |
[2019-02-14 18:32:04] |
Yes that type of improper functionality is not supported. What is supported is documented here: Chart Trading and the Chart DOM: Entering Orders From the Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
