Date/Time: Sun, 26 Jan 2025 07:29:55 +0000
Chart DOM / Trade DOM Template
View Count: 2622
[2019-02-14 09:49:30]
User590016 - Posts: 50
Is there a way to duplicate the template from a Trade DOM to a Chart DOM without having to start from 0 ? Indeed, when I load a Chart DOM it doesnt look the same as my custom Trade DOM.
[2019-02-14 18:54:42]
Refer to:
Using Chart Templates
[2019-02-14 19:25:38]
Sorry but I think you misunderstood me. How do I turn my Trade DOM into a Chart DOM ? I want my Trade DOM to be attached on the side of a chart as a Chart DOM.
[2019-02-15 19:00:45]
Well for this, you just need to use the Chart DOM on a chart itself:
Chart Trading and the Chart DOM: Using the Chart DOM / Order Entry Ladder
[2019-02-15 20:43:09]
I guess you don't understand what I just wrote...
1. I already have a Trade DOM set up with all the colors
How do I open a Chart DOM so that it looks just like my Trade DOM?
i dont want to set it up again from scratch...
thanks
[2019-02-17 19:21:13]
In regards to color settings, this is not possible because the Trade DOM uses separate color settings compared to the Chart DOM. So you have to set those up separately but once each of them is set up you can then separately duplicate those windows.
