Date/Time: Sun, 26 Jan 2025 07:18:16 +0000
downloading interval for historical data
View Count: 645
[2019-02-14 09:31:57] |
User993527 - Posts: 1 |
hi, can I set to 1 min interval after I subscribed the service? I'm using trial, whenever I set, It will change to 30mins. |
[2019-02-14 16:50:08] |
The minimum is going to be 30 minutes. It is not possible to set this to 1 minute. For the record you are referring to the setting described in step 15 here: Sierra Chart Historical Data Service: Setup Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
