Date/Time: Sun, 24 Nov 2024 16:05:48 +0000
auto draw or auto mark at 9am on CL# on chart
View Count: 1170
[2013-11-14 05:40:23] |
User35749 - Posts: 32 |
Hi, Is there any way that I can setup an auto mark (such as a vertical line or an arrow) at 9AM everyday on the 5-minute crude oil (symbol CL#) chart? Thanks, Van |
[2013-11-14 06:02:37] |
Yes. Use the Time Line study.
