Date/Time: Sun, 26 Jan 2025 06:56:04 +0000
Message Log
View Count: 589
[2019-02-13 14:59:09] |
distilledmatt - Posts: 10 |
I recently updated to 1872 and the Message Log is popping up way more than it use to on my multiple instances. It seems to be tagging charts for full recalculation, and thus it stops live data temporarily sometimes while it recalculates. I'm using the "send For Analysis" option on one of the message logs right after I post this.
[2019-02-13 16:29:03] |
We are seeing circular references. Here is one example: Chart #4 has tagged chart #2 for full recalculation. Chartbook: ES Trigger.cht | 2019-02-13 09:44:47 Chart #2 has tagged chart #4 for full recalculation. Chartbook: ES Trigger.cht | 2019-02-13 09:44:47 This needs to be resolved. Refer to: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.9 References to Other Charts / Continuous Full Recalculation of Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
