Date/Time: Sun, 26 Jan 2025 07:05:03 +0000
Suppress periodic download of Intraday data
View Count: 574
[2019-02-12 22:29:52]
onnb - Posts: 662
In order to suppress SC from automatically updating intraday files and getting the message below, is it enough to disconnect SC from the data feed or is there some other step that is necessary?
SC Data - All Services | Performing periodic download of Intraday data for open Intraday charts not receiving real-time data | 2019-02-11 19:25:47
[2019-02-12 23:53:00]
User553714 - Posts: 184
I have a similar question; I would like to avoid using SC Intraday data and use exclusively data from my broker IB; I have done the following;
1) Unticked - Global Settings >> Allow Support for SC Data Feeds
2) Changed in the IB Service settings the "Maximum Historical Intraday days to 2000"
3) Unticked - Global Settings >> Connect on Program Startup
4) Unticked - Global Settings >> Reconnect on Failure
With these settings when I "delete all data and Download" say 200-days of data, it seems that SC is still using SC servers to download Intraday Data not available from IB (which I think is limited to 30-days of Intraday Data), is there a way to stop this altogether as I would like my data going forward to be from IB only.
[2019-02-13 18:09:51]
In response to post #1, refer to step 15 here for the option that controls this:
Sierra Chart Historical Data Service: Setup Instructions
In response to post #2, this is all you need to do:
