Date/Time: Sun, 26 Jan 2025 06:57:45 +0000
Since i updated from 1862 to a newer build - i dont know which one - SC started to hang
View Count: 676
[2019-02-12 16:49:42]
Cavalry3162 - Posts: 523
Hello SC,
since the last couple of builds SC_64 (i dont know abt the 32bit version) sc is becoming unresponsive after a while..
i have nothing further but its a bit of a struggle to trade when it starts to like crash..
please advise
[2019-02-12 17:44:33]
Look at the Windows Task Manager when this happens, do you notice that the CPU usage is 0% or some other greater number? Let us know what you see.
[2019-02-14 22:38:20]
If you are running version 1870 through 1874, this issue is now resolved.
[2019-02-14 23:53:13]
User465507 - Posts: 74
I also have hanging issues in one instance of Sierra Chart. Hangs every day or two. It's only one instance though so maybe there's something in it causing the issues.
[2019-02-15 03:44:52]
This should be resolved in 1875. If not, we will test the Chartbook you are using to determine the reason.
