Date/Time: Sun, 26 Jan 2025 07:10:27 +0000
My Services
View Count: 706
[2019-02-12 15:15:26] |
User800328 - Posts: 50 |
Hi Guys, I have a question. I am using the "Sierra Chart Usage Time at Service Package 5 - Advanced" service for the symbol /ES and placing the orders in SIM and as well as Live account. The question is why do I need the following 2 services when I all I need is charts for just 1 symbol (/ES) and the above service is sufficient for me. 1. Exchange Data Feed: 20 Real-Time Symbols (1st Connection). 2. CME with Market Depth for nonprofessional Trading accounts Thanks |
[2019-02-12 18:48:14] |
Well if you do not need to use the Sierra Chart Exchange Data Feed, then you do not need either of those. It is going to provide a better quality data feed though. It is up to you.
[2019-02-12 18:56:43] |
Thanks a lot. So let me understand, is there a difference between "Sierra Chart Usage Time at Service Package 5 - Advanced" and the "Exchange Data Feed: 20 Real Time Connection Feed" ? If yes, what is it ? And what benefit I get using the CME with Market Depth for nonprofessional Trading accounts ? Sorry, but I am still confused as to what benefits does the following services provide when I can get everything going (DOM, Charts, Market Profile) with just the "Sierra Chart Usage Time at Service Package 5 - Advanced" ? What if I enable "Exchange Data Feed: 20 Real-Time Symbols (1st Connection)." and disable the "Sierra Chart Usage Time at Service Package 5 - Advanced", can I have that set up ? Date Time Of Last Edit: 2019-02-12 18:59:25
[2019-02-13 14:18:59] |
HI, Can you please reply to my confusion above. Thanks. I am confused. Again my question is I already have "Sierra Chart Usage Time at Service Package 5 - Advanced" service then: 1. What is the purpose of service "CME with Market Depth for nonprofessional Trading accounts" ? Do I need it ? 2. What is the purpose of service "Exchange Data Feed: 20 Real-Time Symbols (1st Connection)." ? Do I need it ? Thanks |
[2019-02-13 21:04:33] |
So let me understand, is there a difference between "Sierra Chart Usage Time at Service Package 5 - Advanced" and the "Exchange Data Feed: 20 Real Time Connection Feed" ? If yes, what is it ? https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#Pricing We also see that at the present time you are not using the Sierra Chart Exchange Data Feed. So if you are fine with what you have now, then you do not need it. What if I enable "Exchange Data Feed: 20 Real-Time Symbols (1st Connection)." and disable the "Sierra Chart Usage Time at Service Package 5 - Advanced", can I have that set up ? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
