Date/Time: Sun, 26 Jan 2025 06:56:50 +0000
Bitfinex broken symbols
View Count: 670
[2019-02-12 05:09:40] |
rhovega - Posts: 279 |
Several (most?) Bitfinex symbols are broken. Showing as 0.0 on the quoteboard, no intraday data loading, and no historical data since October 2018. Examples: DAIUSD-BITFINEX MKRUSD-BITFINEX VETUSD-BITFINEX XLMUSD-BITFINEX PAXUSD-BITFINEX TSDUSD-BITFINEX UDCUSD-BITFINEX USTUSD-BITFINEX Can you fix this? Thank you. |
[2019-02-12 06:05:29] |
Similar problems with most Poloniex symbols. For example the following symbols (which do exist in Poloniex) are not loading: USDC_DOGE-PLNX USDC_BCHABC-PLNX USDC_BCHBSV-PLNX USDT_BNT-PLNX USDT_LSK-PLNX USDT_MANA-PLNX USDT_REP-PLNX |
[2019-02-12 21:06:09] |
In the case of Bitfinex possibly the issue is because they have added more symbols at some point, there may be a limit to the number of symbols that can be tracked on a single websocket connection leading to not receiving market data for some of them. This is involved for us to resolve and it is not something we are willing to commit our valuable time for on a substandard connection like that. In regards to Poloniex that data feed is from another source and we are not willing to spend any time looking into this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-02-12 21:28:34] |
Any plans then to add a reliable data feed for a spot crypto exchange listing altcoins?
