Date/Time: Sat, 25 Jan 2025 01:12:23 +0000
Chartbook openings depending on connection used
View Count: 645
[2019-02-11 23:31:58]
User169391 - Posts: 62
Is it possible to set what chartbook's will be opened depending on the Broker connection you are using? e.g. You have an account with FXCM and InteractiveBrokers. As you know they use different formatting on there symbols.
[2019-02-12 00:49:22]
No but the best thing to do is just to use different installations of Sierra Chart, one for each service. Refer to:
Using Multiple Data and Trading Services at the Same Time
