Date/Time: Sat, 25 Jan 2025 01:03:34 +0000
version 1872 mdi text fonts
View Count: 620
[2019-02-11 18:46:50] |
rhk - Posts: 3 |
Hi, Ive just downloaded the latest version 1872 and when I set the text/font for the mdi tabas , they jump back to a random setting. When I change the setting, they go to what I want ( eg. font of 8 and arial font ), but when I click on the tab they change to another font. It only does this with the mdi tabs. The chartbook tabs are fine. Is this a bug..?? Should I try to reinstall the software.?? cheers and many thks Roelof |
[2019-02-11 19:07:41] |
rhk - Posts: 3 |
hi... Just want to add... I do have the same problems with the chartbook tabs... they change text/font when I click on them |
[2019-02-11 19:23:47] |
We are aware of a problem like this, and we are implementing a new tab control in Sierra Chart. It will be out as soon as possible.
