Date/Time: Sat, 25 Jan 2025 01:19:26 +0000
New Instance - Works Fine and then Disconnects (reconnects 15 to 30 seconds later)
View Count: 701
[2019-02-11 15:03:13] |
absorrel4 - Posts: 97 |
I am running SC version 1872 - 32 bit version (can not run 64 bit since the custom indicator I paid for will not run on the 64 bit version). I created a New Instance and it works perfectly....until it disconnects and then reconnects about 15 to 30 seconds later. This happened in the middle of a trade (luckily, in simulated). I have attached the log. Any suggestions to keep this from happening? The log is long....but, I think you can see how often this is happening since I had SC running overnight. First part of log is probably when I was setting up the New Instance....but, the middle of the log to the end will show the frequency of the problem. Thank you... Reading Internal Order ID file. | 2019-02-10 23:17:06 Reading Trade Orders file. | 2019-02-10 23:17:06 Reading Trade Positions file. | 2019-02-10 23:17:06 Account Balance file. | 2019-02-10 23:17:06 UDPListener (1216). Port 22903 | Listening on UDP port 22903. | 2019-02-10 23:17:06 Software version: 1872 32-bit | 2019-02-10 23:17:06 Usage end date: 2019-10-22 | 2019-02-10 23:17:06 Enabled for: Advanced Features. | 2019-02-10 23:17:06 Enabled for: Advanced Features 2. | 2019-02-10 23:17:06 Enabled for: Sierra Chart Historical Data Service. | 2019-02-10 23:17:06 Allow Support for Sierra Chart Data Feeds is disabled. | 2019-02-10 23:17:06 Current selected Data/Trading service: CQG FIX Trading | 2019-02-10 23:17:06 Chart Update Interval: 50 | 2019-02-10 23:17:06 Intraday Data Storage Time Unit: 0 | 2019-02-10 23:17:06 Time Zone: -07:00:00 (MST-07MDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2019-02-10 23:17:06 2019-02-10 23:17:06 Local computer time | 2019-02-10 23:17:06 2019-02-11 06:17:06 Local computer time in UTC | 2019-02-10 23:17:06 2019-02-10 23:17:06 Local computer time in SC Time Zone | 2019-02-10 23:17:06 2019-02-11 06:17:07 Server time in UTC | 2019-02-10 23:17:06 Local computer UTC time and Server UTC time difference: 2 seconds. | 2019-02-10 23:17:06 Program path: C:\SierraChart\ | 2019-02-10 23:17:06 Data Files path: C:\SierraChart\Data\ | 2019-02-10 23:17:06 OS Version Number: 10.0 | 2019-02-10 23:17:06 Locale Setting: C | 2019-02-10 23:17:06 DLLs: ab_sorrel.dll, UserContributedStudies.dll, UserContributedStudies_64.dll | 2019-02-10 23:17:06 Created the DTC Protocol server. | 2019-02-10 23:17:06 DTC Protocol Server listening on port 11099. | 2019-02-10 23:17:06 Created the DTC Protocol historical data server. | 2019-02-10 23:17:06 HD Server Manager | Listening on port 11098 | 2019-02-10 23:17:06 Checking for new symbol settings. Requested symbol settings MD5 for service code cqg. Request ID: 1. | 2019-02-10 23:17:06 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (4) | Creating socket. Using TLS 1.2. | 2019-02-10 23:17:06 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (4) | Connecting to IP: 46.4.97.203. | 2019-02-10 23:17:06 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2019-02-10 23:17:06 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2019-02-10 23:17:06 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2019-02-10 23:17:06 Received 5 login tokens. | 2019-02-10 23:17:07 Symbol settings MD5 received. Request ID: 1. | 2019-02-10 23:17:07 Symbol settings are up-to-date for cqg. | 2019-02-10 23:17:07 HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (2) | Shutdown started. Waiting for graceful close. | 2019-02-10 23:17:07 HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (2) | Socket gracefully closed by remote side. | 2019-02-10 23:17:07 HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (2) | Closed. | 2019-02-10 23:17:07 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (4) | Shutdown started. Waiting for graceful close. | 2019-02-10 23:17:07 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (4) | Socket gracefully closed by remote side. | 2019-02-10 23:17:07 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (4) | Closed. | 2019-02-10 23:17:07 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Creating socket. Using TLS 1.2. | 2019-02-10 23:17:08 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Connecting to IP: 46.4.97.203. | 2019-02-10 23:17:08 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2019-02-10 23:17:09 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2019-02-10 23:17:09 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Closed. | 2019-02-10 23:17:09 Created process C:\SierraChart\SierraChartInstance_2\SierraChart.exe. Parameters: /enc:Oy$YFI0VavP4pQ0Vpnz9p+ziaXrYpnPKtmX-pQDVFI-2oOrYpIPc1vE4NL5EI$_t1mTfa+ePFmX4NGrYf0Y8IIPc1vPcfI0VavP4p$#Yp+Y2oL4z5Lx#E.Yaf.@EIIPc1vPcqQ0cpb56ohrCBXrYnVelI$3tMv0cf0Y8InPK.mX-pQDVFI-8tQEla+Y2NvDepIc#Eq_8fme4anPVp$X9am-2fmZ9aOrtanGcNmn#Eq_8qQD-pndYpvY2o2SKFVSPNVlU. Current folder: C:\SierraChart\SierraChartInstance_2 | 2019-02-10 23:17:12 DTC Protocol server | Incoming connection from 127.0.0.1. | 2019-02-10 23:17:22 DTCServer (1) | Creating socket. | 2019-02-10 23:17:22 DTC client #1. 127.0.0.1 | Set DTC encoding to Binary VLS | 2019-02-10 23:17:22 DTC client #1. 127.0.0.1 | Requested heartbeat interval: 20 | 2019-02-10 23:17:22 DTC client #1. Sierra Chart. 127.0.0.1 | Received logon request. | 2019-02-10 23:17:22 DTC client #1. Sierra Chart. 127.0.0.1 | Connecting to primary Data/Trading service. | 2019-02-10 23:17:22 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2019-02-10 23:17:22 DTC client #1. Sierra Chart. 127.0.0.1 | Sent successful Logon response message to client. Username: Alan Sorrel. Result text: Connected to SC DTC Protocol server. Service=cqgfix|SymbolSettings=cqg | 2019-02-10 23:17:22 DTCServer (1) | Creating socket. | 2019-02-10 23:17:22 DTCServer (1) | Connecting to IP: 0.0.0.0. | 2019-02-10 23:17:22 DTCServer (1) | Error connecting. Address Family: 2. IP: 0.0.0.0. Windows error code 10049: The requested address is not valid in its context. | 2019-02-10 23:17:22 * DTCServer (1) | Connect event error. Windows error code 10049: The requested address is not valid in its context. | 2019-02-10 23:17:22 * DTCServer (1) | Shutdown error. Windows error code 10057: A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied. | 2019-02-10 23:17:22 * DTCServer (1) | Shutdown started. Waiting for graceful close. | 2019-02-10 23:17:22 DTCServer (1) | Socket receive error. Windows error code 10057: A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied. | 2019-02-10 23:17:22 DTCServer (1) | Closed. | 2019-02-10 23:17:22 CQG FIX socket (2) | Creating socket. Using TLS 1.2. | 2019-02-10 23:17:22 CQG FIX socket (2) | Connecting to IP: 208.48.16.214. | 2019-02-10 23:17:22 CQG FIX: Sending the Logon message. | 2019-02-10 23:17:22 CQG FIX Trading | Connected to trading server. | 2019-02-10 23:17:23 CQG FIX Trading | Connecting to server api.cqg.com | 2019-02-10 23:17:23 CQG WebSocket | Connecting to WebSocket server. | 2019-02-10 23:17:23 CQG FIX | FCM name: Phillip | 2019-02-10 23:17:23 CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2019-02-10 23:17:23 CQG WebSocket socket (1) | Connecting to IP: 208.48.16.35. | 2019-02-10 23:17:23 CQG WebSocket | Opening WebSocket. | 2019-02-10 23:17:23 CQG WebSocket | Sending WebSocket handshake. | 2019-02-10 23:17:23 CQG WebSocket | Header line. HTTP/1.1 101 Switching Protocols | 2019-02-10 23:17:23 CQG WebSocket | Header line. Connection: upgrade | 2019-02-10 23:17:23 CQG WebSocket | Header line. Sec-WebSocket-Accept: OCQV8KHbAOxO8MOwO39je6gge1M= | 2019-02-10 23:17:23 CQG WebSocket | Header line. Server: WebSocket++/0.7.0 | 2019-02-10 23:17:23 CQG WebSocket | Header line. Upgrade: websocket | 2019-02-10 23:17:23 CQG WebSocket | Header line. | 2019-02-10 23:17:23 CQG WebSocket | Web socket state is now open. | 2019-02-10 23:17:23 CQG FIX Trading | WebSocket connected. | 2019-02-10 23:17:23 CQG FIX Trading | Sending market data logon message. | 2019-02-10 23:17:23 CQG FIX Trading | Base Time: 2019-01-27T06:23:04. 2019-01-27 06:23:04 | 2019-02-10 23:17:23 CQG FIX Trading | Logon successful. Session Token = E5w+g1EIzWpzY8MSv7GXZktGus5OHxoafqquFo/WTKUJbiHBN8XXbG+2/zVONUq7xCXLJVn5QyZ | 2019-02-10 23:17:23 CQG FIX Trading | Connected to data and trading server. | 2019-02-10 23:17:23 Loading DLL C:\SierraChart\Data\ab_sorrel.dll | 2019-02-10 23:17:32 F.US.ENQH19 20 Sec #1 | Reloading chart. | 2019-02-10 23:17:37 F.US.ENQH19 1 Min #6 | Reloading chart. | 2019-02-10 23:17:37 F.US.ENQH19 20 Sec #7 | Reloading chart. | 2019-02-10 23:17:37 F.US.YMH19 2 Min #8 | Reloading chart. | 2019-02-10 23:17:37 Chart #6 has tagged chart #1 for full recalculation. Chartbook: March NQ - 1 to 1.Cht | 2019-02-10 23:17:38 Chart #6 has tagged chart #1 for full recalculation. Chartbook: March NQ - 1 to 1.Cht | 2019-02-10 23:17:38 'Allow Support for Sierra Chart Data Feeds' is disabled. The F.US.ENQ?## pattern/symbol will not use the SC Exchange Data Feed. | 2019-02-10 23:17:38 CQG FIX Trading | Starting real-time market data updates for: F.US.ENQH19. ID: 1 Service code: cqg | 2019-02-10 23:17:38 CQG FIX Trading | Sending symbol resolution request for F.US.ENQH19. ID: 919666 | 2019-02-10 23:17:38 CQG FIX Trading | Requesting market data for | 2019-02-10 23:17:38 CQG FIX Trading | Requesting security definition data for: F.US.ENQH19. ID: 1 | 2019-02-10 23:17:38 Intraday data recording state for symbol F.US.ENQH19 is set to download 'Pending'. | 2019-02-10 23:17:38 F.US.ENQH19 20 Sec #1 | Performing a full recalculation because it has been tagged. Chartbook: March NQ - 1 to 1.Cht | 2019-02-10 23:17:38 Delaying start of download for F.US.ENQH19 | 2019-02-10 23:17:38 CQG FIX Trading | Market data subscription for was unsuccessful. Text: Contract was not found. | 2019-02-10 23:17:38 CQG FIX Trading | Received symbol resolution report for symbol F.US.ENQH19. Search Symbol: F.US.ENQH19. Request ID: 919666. Contract ID: 1. | 2019-02-10 23:17:38 CQG FIX Trading | Requesting market data for F.US.ENQH19 | 2019-02-10 23:17:38 'Allow Support for Sierra Chart Data Feeds' is disabled. The F.US.YM?## pattern/symbol will not use the SC Exchange Data Feed. | 2019-02-10 23:17:38 CQG FIX Trading | Starting real-time market data updates for: F.US.YMH19. ID: 2 Service code: cqg | 2019-02-10 23:17:38 CQG FIX Trading | Sending symbol resolution request for F.US.YMH19. ID: 919667 | 2019-02-10 23:17:38 CQG FIX Trading | Requesting market data for | 2019-02-10 23:17:38 CQG FIX Trading | Requesting security definition data for: F.US.YMH19. ID: 2 | 2019-02-10 23:17:38 Intraday data recording state for symbol F.US.YMH19 is set to download 'Pending'. | 2019-02-10 23:17:38 Requesting market depth updates for: F.US.ENQH19 if supported. | 2019-02-10 23:17:38 CQG FIX Trading | Requesting market data including full depth for F.US.ENQH19 | 2019-02-10 23:17:38 Requesting market depth updates for: F.US.YMH19 if supported. | 2019-02-10 23:17:38 CQG FIX Trading | Requesting market data including full depth for | 2019-02-10 23:17:38 CQG FIX Trading | Market data subscription for was unsuccessful. Text: Contract was not found. | 2019-02-10 23:17:38 CQG FIX Trading | Received symbol resolution report for symbol F.US.YMH19. Search Symbol: F.US.YMH19. Request ID: 919667. Contract ID: 2. | 2019-02-10 23:17:38 CQG FIX Trading | Requesting market data including full depth for F.US.YMH19 | 2019-02-10 23:17:38 CQG FIX Trading | Market data subscription for was unsuccessful. Text: Contract was not found. | 2019-02-10 23:17:38 CQG FIX Trading | Market data subscription for F.US.YMH19 was unsuccessful. Text: Real-time data for instrument F.US.YM (corresponding to ID = 2) are not allowed. | 2019-02-10 23:17:38 Symbol Error - F.US.YMH19 is unknown, unavailable, or improperly formatted. Real-time data for instrument F.US.YM (corresponding to ID = 2) are not allowed. | 2019-02-10 23:17:38 HD Request # 2 | Downloading Intraday chart data for F.US.ENQH19 to the file F.US.ENQH19.scid. Service: cqg | 2019-02-10 23:17:43 HD Request # 2 | Download start date-time: 2019-02-10 23:16:48.000 | 2019-02-10 23:17:43 HD Request # 2 | Using server: ds4.sierracharts.com port 10150 | 2019-02-10 23:17:43 Socket (3) | Creating socket. | 2019-02-10 23:17:43 Socket (3) | Connecting to IP: 192.81.56.146. | 2019-02-10 23:17:43 HD Request # 2 | Setting DTC encoding to Binary VLS | 2019-02-10 23:17:43 HD Request # 2 | Sending historical data logon request message. | 2019-02-10 23:17:43 HD Request # 2 | Requesting Intraday data. Start date-time: 2019-02-10 23:16:48. Record interval: 0. Symbol: F.US.ENQH19 | 2019-02-10 23:17:44 HD Request # 2 | Decompressing data. | 2019-02-10 23:17:44 HD Request # 2 | Receiving Intraday data for F.US.ENQH19 starting at 2019-02-10 23:16:48 | 2019-02-10 23:17:44 HD Request # 2 | Timestamp of first Intraday data file record written: 2019-02-10 23:16:48 | 2019-02-10 23:17:44 Socket (3) | Shutdown started. Waiting for graceful close. | 2019-02-10 23:17:44 Historical data download thread signaled to stop. | 2019-02-10 23:17:44 HD Request # 2 | Received 8 records from 2019-02-10 23:16:48 to 2019-02-10 23:16:48 (0.0 seconds) and wrote 7 records for F.US.ENQH19 | 2019-02-10 23:17:44 HD Request # 2 | Completion time: 0s | 2019-02-10 23:17:44 HD Request # 2 | Intraday data download complete for F.US.ENQH19. Unique request ID: 1 | 2019-02-10 23:17:44 Removed historical data download ID 1 | 2019-02-10 23:17:44 Real-time Intraday chart data file updates started for F.US.ENQH19 | 2019-02-10 23:17:44 Intraday chart data file opened for F.US.ENQH19 | 2019-02-10 23:17:44 HD Request # 3 | Downloading Intraday chart data for F.US.YMH19 to the file F.US.YMH19.scid. Service: cqg | 2019-02-10 23:17:44 HD Request # 3 | Download start date-time: 2019-02-10 23:07:11.000 | 2019-02-10 23:17:44 HD Request # 3 | Using server: ds3.sierracharts.com port 10149 | 2019-02-10 23:17:44 Socket (4) | Creating socket. | 2019-02-10 23:17:44 Socket (4) | Connecting to IP: 65.182.172.42. | 2019-02-10 23:17:44 Socket (3) | Socket gracefully closed by remote side. | 2019-02-10 23:17:44 Socket (3) | Closed. | 2019-02-10 23:17:44 Chart #6 has tagged chart #1 for full recalculation. Chartbook: March NQ - 1 to 1.Cht | 2019-02-10 23:17:44 Chart #6 has tagged chart #7 for full recalculation. Chartbook: March NQ - 1 to 1.Cht | 2019-02-10 23:17:44 F.US.ENQH19 20 Sec #7 | Performing a full recalculation because it has been tagged. Chartbook: March NQ - 1 to 1.Cht | 2019-02-10 23:17:44 F.US.ENQH19 20 Sec #1 | Performing a full recalculation because it has been tagged. Chartbook: March NQ - 1 to 1.Cht | 2019-02-10 23:17:44 HD Request # 3 | Setting DTC encoding to Binary VLS | 2019-02-10 23:17:44 HD Request # 3 | Sending historical data logon request message. | 2019-02-10 23:17:44 HD Request # 3 | Requesting Intraday data. Start date-time: 2019-02-10 23:07:11. Record interval: 0. Symbol: F.US.YMH19 | 2019-02-10 23:17:44 HD Request # 3 | Decompressing data. | 2019-02-10 23:17:44 HD Request # 3 | Receiving Intraday data for F.US.YMH19 starting at 2019-02-10 23:07:11 | 2019-02-10 23:17:44 HD Request # 3 | Timestamp of first Intraday data file record written: 2019-02-10 23:07:59 | 2019-02-10 23:17:44 Socket (4) | Shutdown started. Waiting for graceful close. | 2019-02-10 23:17:44 Historical data download thread signaled to stop. | 2019-02-10 23:17:44 HD Request # 3 | Received 112 records from 2019-02-10 23:07:11 to 2019-02-10 23:17:23 (10.2 minutes) and wrote 109 records for F.US.YMH19 | 2019-02-10 23:17:44 HD Request # 3 | Completion time: 0s | 2019-02-10 23:17:44 HD Request # 3 | Intraday data download complete for F.US.YMH19. Unique request ID: 2 | 2019-02-10 23:17:44 Removed historical data download ID 2 | 2019-02-10 23:17:44 Real-time Intraday chart data file updates started for F.US.YMH19 | 2019-02-10 23:17:44 Intraday chart data file opened for F.US.YMH19 | 2019-02-10 23:17:44 Socket (4) | Socket gracefully closed by remote side. | 2019-02-10 23:17:44 Socket (4) | Closed. | 2019-02-10 23:17:44 Opened cached Intraday file: C:\SierraChart\Data\F.US.ENQH19.scid | 2019-02-10 23:17:46 Deleting individual DTC server: DTC client #1. Sierra Chart. 127.0.0.1 | 2019-02-10 23:18:06 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2019-02-10 23:18:08 HD Server Manager | Started new historical data server. Count=1 | 2019-02-10 23:18:08 HD Server | Thread:4284 (3) | Creating socket. | 2019-02-10 23:18:08 HD Server | Setting DTC encoding to Binary VLS | Thread:4284 | 2019-02-10 23:18:08 HD Server | Received login. Requesting authorization. | Username: Alan Sorrel. | Thread:4284 | 2019-02-10 23:18:08 HD Server | Login has been authorized. | Username: Alan Sorrel. | Thread:4284 | 2019-02-10 23:18:08 HD Server | HD Request #2 | Socket: 3 | Symbol: F.US.ENQH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2019-02-11 06:16:37 | ClientRequestID: 2 | Username: Alan Sorrel. | Thread:4284 | 2019-02-10 23:18:08 HD Server | HD Request #2 | Socket: 3 | Symbol: F.US.ENQH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 22 | ClientRequestID: 2 | Username: Alan Sorrel. | Thread:4284 | 2019-02-10 23:18:08 HD Server | Thread:4284 (3) | Socket gracefully closed by remote side. | 2019-02-10 23:18:08 HD Server | Thread:4284 (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-02-10 23:18:08 HD Server | Thread:4284 (3) | Closed. | 2019-02-10 23:18:08 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2019-02-10 23:18:08 HD Server Manager | Started new historical data server. Count=2 | 2019-02-10 23:18:08 HD Server | Thread:3216 (3) | Creating socket. | 2019-02-10 23:18:08 HD Server | Setting DTC encoding to Binary VLS | Thread:3216 | 2019-02-10 23:18:08 HD Server | Received login. Requesting authorization. | Username: Alan Sorrel. | Thread:3216 | 2019-02-10 23:18:08 HD Server | Login has been authorized. | Username: Alan Sorrel. | Thread:3216 | 2019-02-10 23:18:08 HD Server | HD Request #3 | Socket: 3 | Symbol: F.US.YMH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2019-02-11 06:07:11 | ClientRequestID: 3 | Username: Alan Sorrel. | Thread:3216 | 2019-02-10 23:18:08 HD Server | HD Request #3 | Socket: 3 | Symbol: F.US.YMH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 112 | ClientRequestID: 3 | Username: Alan Sorrel. | Thread:3216 | 2019-02-10 23:18:08 HD Server | Thread:3216 (3) | Socket gracefully closed by remote side. | 2019-02-10 23:18:08 HD Server | Thread:3216 (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-02-10 23:18:08 HD Server | Thread:3216 (3) | Closed. | 2019-02-10 23:18:08 HD Server | Server thread ending. Closing socket. | Username: Alan Sorrel. | Thread:3216 | 2019-02-10 23:18:08 HD Server Manager | Current server count=1 | 2019-02-10 23:18:08 HD Server | Server thread ending. Closing socket. | Username: Alan Sorrel. | Thread:4284 | 2019-02-10 23:18:08 HD Server Manager | Current server count=0 | 2019-02-10 23:18:08 DTC Protocol server | Incoming connection from 127.0.0.1. | 2019-02-10 23:18:45 DTCServer (3) | Creating socket. | 2019-02-10 23:18:45 DTC client #2. 127.0.0.1 | Set DTC encoding to Binary VLS | 2019-02-10 23:18:45 DTC client #2. 127.0.0.1 | Requested heartbeat interval: 20 | 2019-02-10 23:18:45 DTC client #2. Sierra Chart. 127.0.0.1 | Received logon request. | 2019-02-10 23:18:45 DTC client #2. Sierra Chart. 127.0.0.1 | Sent successful Logon response message to client. Username: Alan Sorrel. Result text: Connected to SC DTC Protocol server. Service=cqgfix|SymbolSettings=cqg | 2019-02-10 23:18:45 DTC client #2. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.ENQH19 | 2019-02-10 23:18:50 DTC client #2. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.YMH19 | 2019-02-10 23:18:50 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2019-02-10 23:18:50 HD Server Manager | Started new historical data server. Count=1 | 2019-02-10 23:18:50 HD Server | Thread:7224 (4) | Creating socket. | 2019-02-10 23:18:50 HD Server | Setting DTC encoding to Binary VLS | Thread:7224 | 2019-02-10 23:18:50 HD Server | Received login. Requesting authorization. | Username: Alan Sorrel. | Thread:7224 | 2019-02-10 23:18:50 HD Server | Login has been authorized. | Username: Alan Sorrel. | Thread:7224 | 2019-02-10 23:18:50 HD Server | HD Request #4 | Socket: 4 | Symbol: F.US.ENQH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2019-02-11 06:18:07 | ClientRequestID: 4 | Username: Alan Sorrel. | Thread:7224 | 2019-02-10 23:18:50 HD Server | HD Request #4 | Socket: 4 | Symbol: F.US.ENQH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 23 | ClientRequestID: 4 | Username: Alan Sorrel. | Thread:7224 | 2019-02-10 23:18:50 HD Server | Thread:7224 (4) | Socket gracefully closed by remote side. | 2019-02-10 23:18:50 HD Server | Thread:7224 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-02-10 23:18:50 HD Server | Thread:7224 (4) | Closed. | 2019-02-10 23:18:50 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2019-02-10 23:18:50 HD Server Manager | Started new historical data server. Count=2 | 2019-02-10 23:18:50 HD Server | Thread:2708 (4) | Creating socket. | 2019-02-10 23:18:50 HD Server | Setting DTC encoding to Binary VLS | Thread:2708 | 2019-02-10 23:18:50 HD Server | Received login. Requesting authorization. | Username: Alan Sorrel. | Thread:2708 | 2019-02-10 23:18:50 HD Server | Login has been authorized. | Username: Alan Sorrel. | Thread:2708 | 2019-02-10 23:18:50 HD Server | HD Request #5 | Socket: 4 | Symbol: F.US.YMH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2019-02-11 06:17:23 | ClientRequestID: 5 | Username: Alan Sorrel. | Thread:2708 | 2019-02-10 23:18:50 HD Server | HD Request #5 | Socket: 4 | Symbol: F.US.YMH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 1 | ClientRequestID: 5 | Username: Alan Sorrel. | Thread:2708 | 2019-02-10 23:18:50 HD Server | Thread:2708 (4) | Socket gracefully closed by remote side. | 2019-02-10 23:18:50 HD Server | Thread:2708 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-02-10 23:18:50 HD Server | Thread:2708 (4) | Closed. | 2019-02-10 23:18:50 HD Server | Server thread ending. Closing socket. | Username: Alan Sorrel. | Thread:2708 | 2019-02-10 23:18:50 HD Server Manager | Current server count=1 | 2019-02-10 23:18:50 HD Server | Server thread ending. Closing socket. | Username: Alan Sorrel. | Thread:7224 | 2019-02-10 23:18:50 HD Server Manager | Current server count=0 | 2019-02-10 23:18:50 DTCServer (3) | Creating socket. | 2019-02-10 23:33:06 DTCServer (3) | Connecting to IP: 0.0.0.0. | 2019-02-10 23:33:06 DTCServer (3) | Error connecting. Address Family: 2. IP: 0.0.0.0. Windows error code 10049: The requested address is not valid in its context. | 2019-02-10 23:33:06 * DTCServer (3) | Connect event error. Windows error code 10049: The requested address is not valid in its context. | 2019-02-10 23:33:06 * DTCServer (3) | Shutdown error. Windows error code 10057: A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied. | 2019-02-10 23:33:06 * DTCServer (3) | Shutdown started. Waiting for graceful close. | 2019-02-10 23:33:06 Deleting individual DTC server: DTC client #2. Sierra Chart. 127.0.0.1 | 2019-02-10 23:33:06 DTCServer (3) | Socket receive error. Windows error code 10057: A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied. | 2019-02-10 23:33:25 DTCServer (3) | Closed. | 2019-02-10 23:33:25 DTC Protocol server | Incoming connection from 127.0.0.1. | 2019-02-10 23:34:08 DTCServer (3) | Creating socket. | 2019-02-10 23:34:08 DTC client #3. 127.0.0.1 | Set DTC encoding to Binary VLS | 2019-02-10 23:34:08 DTC client #3. 127.0.0.1 | Requested heartbeat interval: 20 | 2019-02-10 23:34:08 DTC client #3. Sierra Chart. 127.0.0.1 | Received logon request. | 2019-02-10 23:34:08 DTC client #3. Sierra Chart. 127.0.0.1 | Sent successful Logon response message to client. Username: Alan Sorrel. Result text: Connected to SC DTC Protocol server. Service=cqgfix|SymbolSettings=cqg | 2019-02-10 23:34:08 DTC client #3. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.ENQH19 | 2019-02-10 23:34:13 DTC client #3. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.YMH19 | 2019-02-10 23:34:13 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2019-02-10 23:34:14 HD Server Manager | Started new historical data server. Count=1 | 2019-02-10 23:34:14 HD Server | Thread:10752 (4) | Creating socket. | 2019-02-10 23:34:14 HD Server | Setting DTC encoding to Binary VLS | Thread:10752 | 2019-02-10 23:34:14 HD Server | Received login. Requesting authorization. | Username: Alan Sorrel. | Thread:10752 | 2019-02-10 23:34:14 HD Server | Login has been authorized. | Username: Alan Sorrel. | Thread:10752 | 2019-02-10 23:34:14 HD Server | HD Request #6 | Socket: 4 | Symbol: F.US.YMH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2019-02-11 06:17:23 | ClientRequestID: 6 | Username: Alan Sorrel. | Thread:10752 | 2019-02-10 23:34:14 HD Server | HD Request #6 | Socket: 4 | Symbol: F.US.YMH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 1 | ClientRequestID: 6 | Username: Alan Sorrel. | Thread:10752 | 2019-02-10 23:34:14 HD Server | Thread:10752 (4) | Socket gracefully closed by remote side. | 2019-02-10 23:34:14 HD Server | Thread:10752 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-02-10 23:34:14 HD Server | Thread:10752 (4) | Closed. | 2019-02-10 23:34:14 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2019-02-10 23:34:14 HD Server Manager | Started new historical data server. Count=2 | 2019-02-10 23:34:14 HD Server | Thread:12860 (4) | Creating socket. | 2019-02-10 23:34:14 HD Server | Setting DTC encoding to Binary VLS | Thread:12860 | 2019-02-10 23:34:14 HD Server | Received login. Requesting authorization. | Username: Alan Sorrel. | Thread:12860 | 2019-02-10 23:34:14 HD Server | Login has been authorized. | Username: Alan Sorrel. | Thread:12860 | 2019-02-10 23:34:14 HD Server | HD Request #7 | Socket: 4 | Symbol: F.US.ENQH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2019-02-11 06:33:06 | ClientRequestID: 7 | Username: Alan Sorrel. | Thread:12860 | 2019-02-10 23:34:14 HD Server | HD Request #7 | Socket: 4 | Symbol: F.US.ENQH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 36 | ClientRequestID: 7 | Username: Alan Sorrel. | Thread:12860 | 2019-02-10 23:34:14 HD Server | Thread:12860 (4) | Socket gracefully closed by remote side. | 2019-02-10 23:34:14 HD Server | Thread:12860 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-02-10 23:34:14 HD Server | Thread:12860 (4) | Closed. | 2019-02-10 23:34:14 HD Server | Server thread ending. Closing socket. | Username: Alan Sorrel. | Thread:12860 | 2019-02-10 23:34:14 HD Server Manager | Current server count=1 | 2019-02-10 23:34:14 HD Server | Server thread ending. Closing socket. | Username: Alan Sorrel. | Thread:10752 | 2019-02-10 23:34:14 HD Server Manager | Current server count=0 | 2019-02-10 23:34:14 DTCServer (3) | Creating socket. | 2019-02-10 23:49:06 DTCServer (3) | Connecting to IP: 0.0.0.0. | 2019-02-10 23:49:06 DTCServer (3) | Error connecting. Address Family: 2. IP: 0.0.0.0. Windows error code 10049: The requested address is not valid in its context. | 2019-02-10 23:49:06 * DTCServer (3) | Connect event error. Windows error code 10049: The requested address is not valid in its context. | 2019-02-10 23:49:06 * DTCServer (3) | Shutdown error. Windows error code 10057: A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied. | 2019-02-10 23:49:06 * DTCServer (3) | Shutdown started. Waiting for graceful close. | 2019-02-10 23:49:06 Deleting individual DTC server: DTC client #3. Sierra Chart. 127.0.0.1 | 2019-02-10 23:49:06 DTCServer (3) | Socket receive error. Windows error code 10057: A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied. | 2019-02-10 23:49:08 DTCServer (3) | Closed. | 2019-02-10 23:49:08 DTC Protocol server | Incoming connection from 127.0.0.1. | 2019-02-10 23:50:09 DTCServer (3) | Creating socket. | 2019-02-10 23:50:09 DTC client #4. 127.0.0.1 | Set DTC encoding to Binary VLS | 2019-02-10 23:50:09 DTC client #4. 127.0.0.1 | Requested heartbeat interval: 20 | 2019-02-10 23:50:09 DTC client #4. Sierra Chart. 127.0.0.1 | Received logon request. | 2019-02-10 23:50:09 DTC client #4. Sierra Chart. 127.0.0.1 | Sent successful Logon response message to client. Username: Alan Sorrel. Result text: Connected to SC DTC Protocol server. Service=cqgfix|SymbolSettings=cqg | 2019-02-10 23:50:09 DTC client #4. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.ENQH19 | 2019-02-10 23:50:14 DTC client #4. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.YMH19 | 2019-02-10 23:50:14 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2019-02-10 23:50:15 HD Server Manager | Started new historical data server. Count=1 | 2019-02-10 23:50:15 HD Server | Thread:6720 (4) | Creating socket. | 2019-02-10 23:50:15 HD Server | Setting DTC encoding to Binary VLS | Thread:6720 | 2019-02-10 23:50:15 HD Server | Received login. Requesting authorization. | Username: Alan Sorrel. | Thread:6720 | 2019-02-10 23:50:15 HD Server | Login has been authorized. | Username: Alan Sorrel. | Thread:6720 | 2019-02-10 23:50:15 HD Server | HD Request #8 | Socket: 4 | Symbol: F.US.ENQH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2019-02-11 06:49:02 | ClientRequestID: 8 | Username: Alan Sorrel. | Thread:6720 | 2019-02-10 23:50:15 HD Server | HD Request #8 | Socket: 4 | Symbol: F.US.ENQH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 24 | ClientRequestID: 8 | Username: Alan Sorrel. | Thread:6720 | 2019-02-10 23:50:15 HD Server | Thread:6720 (4) | Socket gracefully closed by remote side. | 2019-02-10 23:50:15 HD Server | Thread:6720 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-02-10 23:50:15 HD Server | Thread:6720 (4) | Closed. | 2019-02-10 23:50:15 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2019-02-10 23:50:15 HD Server Manager | Started new historical data server. Count=2 | 2019-02-10 23:50:15 HD Server | Thread:5156 (4) | Creating socket. | 2019-02-10 23:50:15 HD Server | Setting DTC encoding to Binary VLS | Thread:5156 | 2019-02-10 23:50:15 HD Server | Received login. Requesting authorization. | Username: Alan Sorrel. | Thread:5156 | 2019-02-10 23:50:15 HD Server | Login has been authorized. | Username: Alan Sorrel. | Thread:5156 | 2019-02-10 23:50:15 HD Server | HD Request #9 | Socket: 4 | Symbol: F.US.YMH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2019-02-11 06:17:23 | ClientRequestID: 9 | Username: Alan Sorrel. | Thread:5156 | 2019-02-10 23:50:15 HD Server | HD Request #9 | Socket: 4 | Symbol: F.US.YMH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 1 | ClientRequestID: 9 | Username: Alan Sorrel. | Thread:5156 | 2019-02-10 23:50:15 HD Server | Thread:5156 (4) | Socket gracefully closed by remote side. | 2019-02-10 23:50:15 HD Server | Thread:5156 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-02-10 23:50:15 HD Server | Thread:5156 (4) | Closed. | 2019-02-10 23:50:15 HD Server | Server thread ending. Closing socket. | Username: Alan Sorrel. | Thread:5156 | 2019-02-10 23:50:15 HD Server Manager | Current server count=1 | 2019-02-10 23:50:15 HD Server | Server thread ending. Closing socket. | Username: Alan Sorrel. | Thread:6720 | 2019-02-10 23:50:15 HD Server Manager | Current server count=0 | 2019-02-10 23:50:15 DTCServer (3) | Creating socket. | 2019-02-11 00:05:06 DTCServer (3) | Connecting to IP: 0.0.0.0. | 2019-02-11 00:05:06 DTCServer (3) | Error connecting. Address Family: 2. IP: 0.0.0.0. Windows error code 10049: The requested address is not valid in its context. | 2019-02-11 00:05:06 * DTCServer (3) | Connect event error. Windows error code 10049: The requested address is not valid in its context. | 2019-02-11 00:05:06 * DTCServer (3) | Shutdown error. Windows error code 10057: A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied. | 2019-02-11 00:05:06 * DTCServer (3) | Shutdown started. Waiting for graceful close. | 2019-02-11 00:05:06 Deleting individual DTC server: DTC client #4. Sierra Chart. 127.0.0.1 | 2019-02-11 00:05:06 DTCServer (3) | Socket receive error. Windows error code 10057: A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied. | 2019-02-11 00:05:10 DTCServer (3) | Closed. | 2019-02-11 00:05:10 DTC Protocol server | Incoming connection from 127.0.0.1. | 2019-02-11 00:06:09 DTCServer (3) | Creating socket. | 2019-02-11 00:06:09 DTC client #5. 127.0.0.1 | Set DTC encoding to Binary VLS | 2019-02-11 00:06:09 DTC client #5. 127.0.0.1 | Requested heartbeat interval: 20 | 2019-02-11 00:06:09 DTC client #5. Sierra Chart. 127.0.0.1 | Received logon request. | 2019-02-11 00:06:09 DTC client #5. Sierra Chart. 127.0.0.1 | Sent successful Logon response message to client. Username: Alan Sorrel. Result text: Connected to SC DTC Protocol server. Service=cqgfix|SymbolSettings=cqg | 2019-02-11 00:06:09 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2019-02-11 00:06:13 HD Server Manager | Started new historical data server. Count=1 | 2019-02-11 00:06:13 HD Server | Thread:3240 (4) | Creating socket. | 2019-02-11 00:06:13 HD Server | Setting DTC encoding to Binary VLS | Thread:3240 | 2019-02-11 00:06:13 HD Server | Received login. Requesting authorization. | Username: Alan Sorrel. | Thread:3240 | 2019-02-11 00:06:13 HD Server | Login has been authorized. | Username: Alan Sorrel. | Thread:3240 | 2019-02-11 00:06:13 HD Server | HD Request #10 | Socket: 4 | Symbol: F.US.YMH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2019-02-11 06:17:23 | ClientRequestID: 10 | Username: Alan Sorrel. | Thread:3240 | 2019-02-11 00:06:13 HD Server | HD Request #10 | Socket: 4 | Symbol: F.US.YMH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 1 | ClientRequestID: 10 | Username: Alan Sorrel. | Thread:3240 | 2019-02-11 00:06:13 HD Server | Thread:3240 (4) | Socket gracefully closed by remote side. | 2019-02-11 00:06:13 HD Server | Thread:3240 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-02-11 00:06:13 HD Server | Thread:3240 (4) | Closed. | 2019-02-11 00:06:13 HD Server | Server thread ending. Closing socket. | Username: Alan Sorrel. | Thread:3240 | 2019-02-11 00:06:13 HD Server Manager | Current server count=0 | 2019-02-11 00:06:13 DTC client #5. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.ENQH19 | 2019-02-11 00:06:14 DTC client #5. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.YMH19 | 2019-02-11 00:06:14 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2019-02-11 00:06:14 HD Server Manager | Started new historical data server. Count=1 | 2019-02-11 00:06:14 HD Server | Thread:10180 (4) | Creating socket. | 2019-02-11 00:06:14 HD Server | Setting DTC encoding to Binary VLS | Thread:10180 | 2019-02-11 00:06:14 HD Server | Received login. Requesting authorization. | Username: Alan Sorrel. | Thread:10180 | 2019-02-11 00:06:14 HD Server | Login has been authorized. | Username: Alan Sorrel. | Thread:10180 | 2019-02-11 00:06:14 HD Server | HD Request #11 | Socket: 4 | Symbol: F.US.ENQH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2019-02-11 07:05:06 | ClientRequestID: 11 | Username: Alan Sorrel. | Thread:10180 | 2019-02-11 00:06:14 HD Server | HD Request #11 | Socket: 4 | Symbol: F.US.ENQH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 20 | ClientRequestID: 11 | Username: Alan Sorrel. | Thread:10180 | 2019-02-11 00:06:14 HD Server | Thread:10180 (4) | Socket gracefully closed by remote side. | 2019-02-11 00:06:14 HD Server | Thread:10180 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-02-11 00:06:14 HD Server | Thread:10180 (4) | Closed. | 2019-02-11 00:06:14 HD Server | Server thread ending. Closing socket. | Username: Alan Sorrel. | Thread:10180 | 2019-02-11 00:06:14 HD Server Manager | Current server count=0 | 2019-02-11 00:06:14 DTCServer (3) | Creating socket. | 2019-02-11 00:21:06 DTCServer (3) | Connecting to IP: 0.0.0.0. | 2019-02-11 00:21:06 DTCServer (3) | Error connecting. Address Family: 2. IP: 0.0.0.0. Windows error code 10049: The requested address is not valid in its context. | 2019-02-11 00:21:06 * DTCServer (3) | Connect event error. Windows error code 10049: The requested address is not valid in its context. | 2019-02-11 00:21:06 * DTCServer (3) | Shutdown error. Windows error code 10057: A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied. | 2019-02-11 00:21:06 * DTCServer (3) | Shutdown started. Waiting for graceful close. | 2019-02-11 00:21:06 Deleting individual DTC server: DTC client #5. Sierra Chart. 127.0.0.1 | 2019-02-11 00:21:06 DTCServer (3) | Socket receive error. Windows error code 10057: A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied. | 2019-02-11 00:21:09 DTCServer (3) | Closed. | 2019-02-11 00:21:09 DTC Protocol server | Incoming connection from 127.0.0.1. | 2019-02-11 00:22:08 DTCServer (3) | Creating socket. | 2019-02-11 00:22:08 DTC client #6. 127.0.0.1 | Set DTC encoding to Binary VLS | 2019-02-11 00:22:08 DTC client #6. 127.0.0.1 | Requested heartbeat interval: 20 | 2019-02-11 00:22:08 DTC client #6. Sierra Chart. 127.0.0.1 | Received logon request. | 2019-02-11 00:22:08 DTC client #6. Sierra Chart. 127.0.0.1 | Sent successful Logon response message to client. Username: Alan Sorrel. Result text: Connected to SC DTC Protocol server. Service=cqgfix|SymbolSettings=cqg | 2019-02-11 00:22:08 DTC client #6. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.ENQH19 | 2019-02-11 00:22:13 DTC client #6. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.YMH19 | 2019-02-11 00:22:13 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2019-02-11 00:22:13 HD Server Manager | Started new historical data server. Count=1 | 2019-02-11 00:22:13 HD Server | Thread:13100 (4) | Creating socket. | 2019-02-11 00:22:13 HD Server | Setting DTC encoding to Binary VLS | Thread:13100 | 2019-02-11 00:22:13 HD Server | Received login. Requesting authorization. | Username: Alan Sorrel. | Thread:13100 | 2019-02-11 00:22:13 HD Server | Login has been authorized. | Username: Alan Sorrel. | Thread:13100 | 2019-02-11 00:22:13 HD Server | HD Request #12 | Socket: 4 | Symbol: F.US.ENQH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2019-02-11 07:21:06 | ClientRequestID: 12 | Username: Alan Sorrel. | Thread:13100 | 2019-02-11 00:22:13 HD Server | HD Request #12 | Socket: 4 | Symbol: F.US.ENQH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 46 | ClientRequestID: 12 | Username: Alan Sorrel. | Thread:13100 | 2019-02-11 00:22:13 HD Server | Thread:13100 (4) | Socket gracefully closed by remote side. | 2019-02-11 00:22:13 HD Server | Thread:13100 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-02-11 00:22:13 HD Server | Thread:13100 (4) | Closed. | 2019-02-11 00:22:13 HD Server | Server thread ending. Closing socket. | Username: Alan Sorrel. | Thread:13100 | 2019-02-11 00:22:14 HD Server Manager | Current server count=0 | 2019-02-11 00:22:14 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2019-02-11 00:22:14 HD Server Manager | Started new historical data server. Count=1 | 2019-02-11 00:22:14 HD Server | Thread:8560 (4) | Creating socket. | 2019-02-11 00:22:14 HD Server | Setting DTC encoding to Binary VLS | Thread:8560 | 2019-02-11 00:22:14 HD Server | Received login. Requesting authorization. | Username: Alan Sorrel. | Thread:8560 | 2019-02-11 00:22:14 HD Server | Login has been authorized. | Username: Alan Sorrel. | Thread:8560 | 2019-02-11 00:22:14 HD Server | HD Request #13 | Socket: 4 | Symbol: F.US.YMH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2019-02-11 06:17:23 | ClientRequestID: 13 | Username: Alan Sorrel. | Thread:8560 | 2019-02-11 00:22:14 HD Server | HD Request #13 | Socket: 4 | Symbol: F.US.YMH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 1 | ClientRequestID: 13 | Username: Alan Sorrel. | Thread:8560 | 2019-02-11 00:22:14 HD Server | Thread:8560 (4) | Socket gracefully closed by remote side. | 2019-02-11 00:22:14 HD Server | Thread:8560 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-02-11 00:22:14 HD Server | Thread:8560 (4) | Closed. | 2019-02-11 00:22:14 HD Server | Server thread ending. Closing socket. | Username: Alan Sorrel. | Thread:8560 | 2019-02-11 00:22:14 HD Server Manager | Current server count=0 | 2019-02-11 00:22:14 DTCServer (3) | Creating socket. | 2019-02-11 00:37:06 DTCServer (3) | Connecting to IP: 0.0.0.0. | 2019-02-11 00:37:06 DTCServer (3) | Error connecting. Address Family: 2. IP: 0.0.0.0. Windows error code 10049: The requested address is not valid in its context. | 2019-02-11 00:37:06 * DTCServer (3) | Connect event error. Windows error code 10049: The requested address is not valid in its context. | 2019-02-11 00:37:06 * DTCServer (3) | Shutdown error. Windows error code 10057: A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied. | 2019-02-11 00:37:06 * DTCServer (3) | Shutdown started. Waiting for graceful close. | 2019-02-11 00:37:06 Deleting individual DTC server: DTC client #6. Sierra Chart. 127.0.0.1 | 2019-02-11 00:37:06 DTCServer (3) | Socket receive error. Windows error code 10057: A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied. | 2019-02-11 00:37:09 DTCServer (3) | Closed. | 2019-02-11 00:37:09 DTC Protocol server | Incoming connection from 127.0.0.1. | 2019-02-11 00:38:10 DTCServer (3) | Creating socket. | 2019-02-11 00:38:10 DTC client #7. 127.0.0.1 | Set DTC encoding to Binary VLS | 2019-02-11 00:38:10 DTC client #7. 127.0.0.1 | Requested heartbeat interval: 20 | 2019-02-11 00:38:10 DTC client #7. Sierra Chart. 127.0.0.1 | Received logon request. | 2019-02-11 00:38:10 DTC client #7. Sierra Chart. 127.0.0.1 | Sent successful Logon response message to client. Username: Alan Sorrel. Result text: Connected to SC DTC Protocol server. Service=cqgfix|SymbolSettings=cqg | 2019-02-11 00:38:10 DTC client #7. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.ENQH19 | 2019-02-11 00:38:15 DTC client #7. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.YMH19 | 2019-02-11 00:38:15 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2019-02-11 00:38:16 HD Server Manager | Started new historical data server. Count=1 | 2019-02-11 00:38:16 HD Server | Thread:10436 (4) | Creating socket. | 2019-02-11 00:38:16 HD Server | Setting DTC encoding to Binary VLS | Thread:10436 | 2019-02-11 00:38:16 HD Server | Received login. Requesting authorization. | Username: Alan Sorrel. | Thread:10436 | 2019-02-11 00:38:16 HD Server | Login has been authorized. | Username: Alan Sorrel. | Thread:10436 | 2019-02-11 00:38:16 HD Server | HD Request #14 | Socket: 4 | Symbol: F.US.YMH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2019-02-11 06:17:23 | ClientRequestID: 14 | Username: Alan Sorrel. | Thread:10436 | 2019-02-11 00:38:16 HD Server | HD Request #14 | Socket: 4 | Symbol: F.US.YMH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 1 | ClientRequestID: 14 | Username: Alan Sorrel. | Thread:10436 | 2019-02-11 00:38:16 HD Server | Thread:10436 (4) | Socket gracefully closed by remote side. | 2019-02-11 00:38:16 HD Server | Thread:10436 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-02-11 00:38:16 HD Server | Thread:10436 (4) | Closed. | 2019-02-11 00:38:16 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2019-02-11 00:38:16 HD Server Manager | Started new historical data server. Count=2 | 2019-02-11 00:38:16 HD Server | Thread:2192 (4) | Creating socket. | 2019-02-11 00:38:16 HD Server | Setting DTC encoding to Binary VLS | Thread:2192 | 2019-02-11 00:38:16 HD Server | Received login. Requesting authorization. | Username: Alan Sorrel. | Thread:2192 | 2019-02-11 00:38:16 HD Server | Login has been authorized. | Username: Alan Sorrel. | Thread:2192 | 2019-02-11 00:38:16 HD Server | HD Request #15 | Socket: 4 | Symbol: F.US.ENQH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2019-02-11 07:37:07 | ClientRequestID: 15 | Username: Alan Sorrel. | Thread:2192 | 2019-02-11 00:38:16 HD Server | HD Request #15 | Socket: 4 | Symbol: F.US.ENQH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 44 | ClientRequestID: 15 | Username: Alan Sorrel. | Thread:2192 | 2019-02-11 00:38:16 HD Server | Thread:2192 (4) | Socket gracefully closed by remote side. | 2019-02-11 00:38:16 HD Server | Thread:2192 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-02-11 00:38:16 HD Server | Thread:2192 (4) | Closed. | 2019-02-11 00:38:16 HD Server | Server thread ending. Closing socket. | Username: Alan Sorrel. | Thread:2192 | 2019-02-11 00:38:16 HD Server Manager | Current server count=1 | 2019-02-11 00:38:16 HD Server | Server thread ending. Closing socket. | Username: Alan Sorrel. | Thread:10436 | 2019-02-11 00:38:16 HD Server Manager | Current server count=0 | 2019-02-11 00:38:16 DTCServer (3) | Creating socket. | 2019-02-11 00:47:06 DTCServer (3) | Connecting to IP: 0.0.0.0. | 2019-02-11 00:47:06 DTCServer (3) | Error connecting. Address Family: 2. IP: 0.0.0.0. Windows error code 10049: The requested address is not valid in its context. | 2019-02-11 00:47:06 * DTCServer (3) | Connect event error. Windows error code 10049: The requested address is not valid in its context. | 2019-02-11 00:47:06 * DTCServer (3) | Shutdown error. Windows error code 10057: A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied. | 2019-02-11 00:47:06 * DTCServer (3) | Shutdown started. Waiting for graceful close. | 2019-02-11 00:47:06 Deleting individual DTC server: DTC client #7. Sierra Chart. 127.0.0.1 | 2019-02-11 00:47:06 DTCServer (3) | Socket receive error. Windows error code 10057: A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied. | 2019-02-11 00:47:10 DTCServer (3) | Closed. | 2019-02-11 00:47:10 DTC Protocol server | Incoming connection from 127.0.0.1. | 2019-02-11 00:48:07 DTCServer (3) | Creating socket. | 2019-02-11 00:48:07 DTC client #8. 127.0.0.1 | Set DTC encoding to Binary VLS | 2019-02-11 00:48:07 DTC client #8. 127.0.0.1 | Requested heartbeat interval: 20 | 2019-02-11 00:48:07 DTC client #8. Sierra Chart. 127.0.0.1 | Received logon request. | 2019-02-11 00:48:07 DTC client #8. Sierra Chart. 127.0.0.1 | Sent successful Logon response message to client. Username: Alan Sorrel. Result text: Connected to SC DTC Protocol server. Service=cqgfix|SymbolSettings=cqg | 2019-02-11 00:48:07 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2019-02-11 00:48:12 HD Server Manager | Started new historical data server. Count=1 | 2019-02-11 00:48:12 HD Server | Thread:5144 (4) | Creating socket. | 2019-02-11 00:48:12 HD Server | Setting DTC encoding to Binary VLS | Thread:5144 | 2019-02-11 00:48:12 HD Server | Received login. Requesting authorization. | Username: Alan Sorrel. | Thread:5144 | 2019-02-11 00:48:12 HD Server | Login has been authorized. | Username: Alan Sorrel. | Thread:5144 | 2019-02-11 00:48:12 HD Server | HD Request #16 | Socket: 4 | Symbol: F.US.ENQH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2019-02-11 07:46:56 | ClientRequestID: 16 | Username: Alan Sorrel. | Thread:5144 | 2019-02-11 00:48:12 HD Server | HD Request #16 | Socket: 4 | Symbol: F.US.ENQH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 6 | ClientRequestID: 16 | Username: Alan Sorrel. | Thread:5144 | 2019-02-11 00:48:12 HD Server | Thread:5144 (4) | Socket gracefully closed by remote side. | 2019-02-11 00:48:12 HD Server | Thread:5144 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-02-11 00:48:12 HD Server | Thread:5144 (4) | Closed. | 2019-02-11 00:48:12 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2019-02-11 00:48:12 HD Server Manager | Started new historical data server. Count=2 | 2019-02-11 00:48:12 HD Server | Thread:9420 (4) | Creating socket. | 2019-02-11 00:48:12 HD Server | Setting DTC encoding to Binary VLS | Thread:9420 | 2019-02-11 00:48:12 HD Server | Received login. Requesting authorization. | Username: Alan Sorrel. | Thread:9420 | 2019-02-11 00:48:12 HD Server | Login has been authorized. | Username: Alan Sorrel. | Thread:9420 | 2019-02-11 00:48:12 HD Server | HD Request #17 | Socket: 4 | Symbol: F.US.YMH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2019-02-11 06:17:23 | ClientRequestID: 17 | Username: Alan Sorrel. | Thread:9420 | 2019-02-11 00:48:12 HD Server | HD Request #17 | Socket: 4 | Symbol: F.US.YMH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 1 | ClientRequestID: 17 | Username: Alan Sorrel. | Thread:9420 | 2019-02-11 00:48:12 HD Server | Thread:9420 (4) | Socket gracefully closed by remote side. | 2019-02-11 00:48:12 HD Server | Thread:9420 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-02-11 00:48:12 HD Server | Thread:9420 (4) | Closed. | 2019-02-11 00:48:12 HD Server | Server thread ending. Closing socket. | Username: Alan Sorrel. | Thread:9420 | 2019-02-11 00:48:12 HD Server Manager | Current server count=1 | 2019-02-11 00:48:12 HD Server | Server thread ending. Closing socket. | Username: Alan Sorrel. | Thread:5144 | 2019-02-11 00:48:12 HD Server Manager | Current server count=0 | 2019-02-11 00:48:12 DTC client #8. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.ENQH19 | 2019-02-11 00:48:12 DTC client #8. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.YMH19 | 2019-02-11 00:48:12 DTCServer (3) | Creating socket. | 2019-02-11 00:53:06 DTCServer (3) | Connecting to IP: 0.0.0.0. | 2019-02-11 00:53:06 DTCServer (3) | Error connecting. Address Family: 2. IP: 0.0.0.0. Windows error code 10049: The requested address is not valid in its context. | 2019-02-11 00:53:06 * DTCServer (3) | Connect event error. Windows error code 10049: The requested address is not valid in its context. | 2019-02-11 00:53:06 * DTCServer (3) | Shutdown error. Windows error code 10057: A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied. | 2019-02-11 00:53:06 * DTCServer (3) | Shutdown started. Waiting for graceful close. | 2019-02-11 00:53:06 Deleting individual DTC server: DTC client #8. Sierra Chart. 127.0.0.1 | 2019-02-11 00:53:06 DTCServer (3) | Socket receive error. Windows error code 10057: A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied. | 2019-02-11 00:53:07 DTCServer (3) | Closed. | 2019-02-11 00:53:07 DTC Protocol server | Incoming connection from 127.0.0.1. | 2019-02-11 00:54:09 DTCServer (3) | Creating socket. | 2019-02-11 00:54:09 DTC client #9. 127.0.0.1 | Set DTC encoding to Binary VLS | 2019-02-11 00:54:09 DTC client #9. 127.0.0.1 | Requested heartbeat interval: 20 | 2019-02-11 00:54:09 DTC client #9. Sierra Chart. 127.0.0.1 | Received logon request. | 2019-02-11 00:54:09 DTC client #9. Sierra Chart. 127.0.0.1 | Sent successful Logon response message to client. Username: Alan Sorrel. Result text: Connected to SC DTC Protocol server. Service=cqgfix|SymbolSettings=cqg | 2019-02-11 00:54:09 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2019-02-11 00:54:14 HD Server Manager | Started new historical data server. Count=1 | 2019-02-11 00:54:14 HD Server | Thread:1988 (4) | Creating socket. | 2019-02-11 00:54:14 HD Server | Setting DTC encoding to Binary VLS | Thread:1988 | 2019-02-11 00:54:14 HD Server | Received login. Requesting authorization. | Username: Alan Sorrel. | Thread:1988 | 2019-02-11 00:54:14 HD Server | Login has been authorized. | Username: Alan Sorrel. | Thread:1988 | 2019-02-11 00:54:14 HD Server | HD Request #18 | Socket: 4 | Symbol: F.US.YMH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2019-02-11 06:17:23 | ClientRequestID: 18 | Username: Alan Sorrel. | Thread:1988 | 2019-02-11 00:54:14 HD Server | HD Request #18 | Socket: 4 | Symbol: F.US.YMH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 1 | ClientRequestID: 18 | Username: Alan Sorrel. | Thread:1988 | 2019-02-11 00:54:14 HD Server | Thread:1988 (4) | Socket gracefully closed by remote side. | 2019-02-11 00:54:14 HD Server | Thread:1988 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-02-11 00:54:14 HD Server | Thread:1988 (4) | Closed. | 2019-02-11 00:54:14 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2019-02-11 00:54:14 HD Server Manager | Started new historical data server. Count=2 | 2019-02-11 00:54:14 HD Server | Thread:10896 (4) | Creating socket. | 2019-02-11 00:54:14 HD Server | Setting DTC encoding to Binary VLS | Thread:10896 | 2019-02-11 00:54:14 HD Server | Received login. Requesting authorization. | Username: Alan Sorrel. | Thread:10896 | 2019-02-11 00:54:14 HD Server | Login has been authorized. | Username: Alan Sorrel. | Thread:10896 | 2019-02-11 00:54:14 HD Server | HD Request #19 | Socket: 4 | Symbol: F.US.ENQH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2019-02-11 07:53:07 | ClientRequestID: 19 | Username: Alan Sorrel. | Thread:10896 | 2019-02-11 00:54:14 HD Server | HD Request #19 | Socket: 4 | Symbol: F.US.ENQH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 30 | ClientRequestID: 19 | Username: Alan Sorrel. | Thread:10896 | 2019-02-11 00:54:14 HD Server | Thread:10896 (4) | Socket gracefully closed by remote side. | 2019-02-11 00:54:14 HD Server | Thread:10896 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-02-11 00:54:14 HD Server | Thread:10896 (4) | Closed. | 2019-02-11 00:54:14 DTC client #9. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.ENQH19 | 2019-02-11 00:54:14 DTC client #9. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.YMH19 | 2019-02-11 00:54:14 HD Server | Server thread ending. Closing socket. | Username: Alan Sorrel. | Thread:10896 | 2019-02-11 00:54:14 HD Server Manager | Current server count=1 | 2019-02-11 00:54:14 HD Server | Server thread ending. Closing socket. | Username: Alan Sorrel. | Thread:1988 | 2019-02-11 00:54:14 HD Server Manager | Current server count=0 | 2019-02-11 00:54:14 DTCServer (3) | Creating socket. | 2019-02-11 01:09:06 DTCServer (3) | Connecting to IP: 0.0.0.0. | 2019-02-11 01:09:06 DTCServer (3) | Error connecting. Address Family: 2. IP: 0.0.0.0. Windows error code 10049: The requested address is not valid in its context. | 2019-02-11 01:09:06 * DTCServer (3) | Connect event error. Windows error code 10049: The requested address is not valid in its context. | 2019-02-11 01:09:06 * DTCServer (3) | Shutdown error. Windows error code 10057: A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied. | 2019-02-11 01:09:06 * DTCServer (3) | Shutdown started. Waiting for graceful close. | 2019-02-11 01:09:06 Deleting individual DTC server: DTC client #9. Sierra Chart. 127.0.0.1 | 2019-02-11 01:09:06 DTCServer (3) | Socket receive error. Windows error code 10057: A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied. | 2019-02-11 01:09:09 DTCServer (3) | Closed. | 2019-02-11 01:09:09 DTC Protocol server | Incoming connection from 127.0.0.1. | 2019-02-11 01:10:09 DTCServer (3) | Creating socket. | 2019-02-11 01:10:09 DTC client #10. 127.0.0.1 | Set DTC encoding to Binary VLS | 2019-02-11 01:10:09 DTC client #10. 127.0.0.1 | Requested heartbeat interval: 20 | 2019-02-11 01:10:09 DTC client #10. Sierra Chart. 127.0.0.1 | Received logon request. | 2019-02-11 01:10:09 DTC client #10. Sierra Chart. 127.0.0.1 | Sent successful Logon response message to client. Username: Alan Sorrel. Result text: Connected to SC DTC Protocol server. Service=cqgfix|SymbolSettings=cqg | 2019-02-11 01:10:09 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2019-02-11 01:10:14 HD Server Manager | Started new historical data server. Count=1 | 2019-02-11 01:10:14 HD Server | Thread:11200 (4) | Creating socket. | 2019-02-11 01:10:14 HD Server | Setting DTC encoding to Binary VLS | Thread:11200 | 2019-02-11 01:10:14 HD Server | Received login. Requesting authorization. | Username: Alan Sorrel. | Thread:11200 | 2019-02-11 01:10:14 HD Server | Login has been authorized. | Username: Alan Sorrel. | Thread:11200 | 2019-02-11 01:10:14 HD Server | HD Request #20 | Socket: 4 | Symbol: F.US.YMH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2019-02-11 06:17:23 | ClientRequestID: 20 | Username: Alan Sorrel. | Thread:11200 | 2019-02-11 01:10:14 HD Server | HD Request #20 | Socket: 4 | Symbol: F.US.YMH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 1 | ClientRequestID: 20 | Username: Alan Sorrel. | Thread:11200 | 2019-02-11 01:10:14 HD Server | Thread:11200 (4) | Socket gracefully closed by remote side. | 2019-02-11 01:10:14 HD Server | Thread:11200 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-02-11 01:10:14 HD Server | Thread:11200 (4) | Closed. | 2019-02-11 01:10:14 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2019-02-11 01:10:14 HD Server Manager | Started new historical data server. Count=2 | 2019-02-11 01:10:14 HD Server | Thread:11800 (4) | Creating socket. | 2019-02-11 01:10:14 HD Server | Setting DTC encoding to Binary VLS | Thread:11800 | 2019-02-11 01:10:14 HD Server | Received login. Requesting authorization. | Username: Alan Sorrel. | Thread:11800 | 2019-02-11 01:10:14 HD Server | Login has been authorized. | Username: Alan Sorrel. | Thread:11800 | 2019-02-11 01:10:14 HD Server | HD Request #21 | Socket: 4 | Symbol: F.US.ENQH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2019-02-11 08:09:03 | ClientRequestID: 21 | Username: Alan Sorrel. | Thread:11800 | 2019-02-11 01:10:14 HD Server | HD Request #21 | Socket: 4 | Symbol: F.US.ENQH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 264 | ClientRequestID: 21 | Username: Alan Sorrel. | Thread:11800 | 2019-02-11 01:10:14 HD Server | Thread:11800 (4) | Socket gracefully closed by remote side. | 2019-02-11 01:10:14 HD Server | Thread:11800 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-02-11 01:10:14 HD Server | Thread:11800 (4) | Closed. | 2019-02-11 01:10:14 DTC client #10. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.ENQH19 | 2019-02-11 01:10:14 DTC client #10. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.YMH19 | 2019-02-11 01:10:14 HD Server | Server thread ending. Closing socket. | Username: Alan Sorrel. | Thread:11800 | 2019-02-11 01:10:14 HD Server Manager | Current server count=1 | 2019-02-11 01:10:14 HD Server | Server thread ending. Closing socket. | Username: Alan Sorrel. | Thread:11200 | 2019-02-11 01:10:14 HD Server Manager | Current server count=0 | 2019-02-11 01:10:14 DTCServer (3) | Creating socket. | 2019-02-11 01:25:06 DTCServer (3) | Connecting to IP: 0.0.0.0. | 2019-02-11 01:25:06 DTCServer (3) | Error connecting. Address Family: 2. IP: 0.0.0.0. Windows error code 10049: The requested address is not valid in its context. | 2019-02-11 01:25:06 * DTCServer (3) | Connect event error. Windows error code 10049: The requested address is not valid in its context. | 2019-02-11 01:25:06 * DTCServer (3) | Shutdown error. Windows error code 10057: A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied. | 2019-02-11 01:25:06 * DTCServer (3) | Shutdown started. Waiting for graceful close. | 2019-02-11 01:25:06 Deleting individual DTC server: DTC client #10. Sierra Chart. 127.0.0.1 | 2019-02-11 01:25:06 DTCServer (3) | Socket receive error. Windows error code 10057: A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied. | 2019-02-11 01:25:09 DTCServer (3) | Closed. | 2019-02-11 01:25:09 DTC Protocol server | Incoming connection from 127.0.0.1. | 2019-02-11 01:26:10 DTCServer (3) | Creating socket. | 2019-02-11 01:26:10 DTC client #11. 127.0.0.1 | Set DTC encoding to Binary VLS | 2019-02-11 01:26:10 DTC client #11. 127.0.0.1 | Requested heartbeat interval: 20 | 2019-02-11 01:26:10 DTC client #11. Sierra Chart. 127.0.0.1 | Received logon request. | 2019-02-11 01:26:10 DTC client #11. Sierra Chart. 127.0.0.1 | Sent successful Logon response message to client. Username: Alan Sorrel. Result text: Connected to SC DTC Protocol server. Service=cqgfix|SymbolSettings=cqg | 2019-02-11 01:26:10 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2019-02-11 01:26:15 HD Server Manager | Started new historical data server. Count=1 | 2019-02-11 01:26:15 HD Server | Thread:5992 (4) | Creating socket. | 2019-02-11 01:26:15 HD Server | Setting DTC encoding to Binary VLS | Thread:5992 | 2019-02-11 01:26:15 HD Server | Received login. Requesting authorization. | Username: Alan Sorrel. | Thread:5992 | 2019-02-11 01:26:15 HD Server | Login has been authorized. | Username: Alan Sorrel. | Thread:5992 | 2019-02-11 01:26:15 HD Server | HD Request #22 | Socket: 4 | Symbol: F.US.ENQH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2019-02-11 08:25:07 | ClientRequestID: 22 | Username: Alan Sorrel. | Thread:5992 | 2019-02-11 01:26:15 HD Server | HD Request #22 | Socket: 4 | Symbol: F.US.ENQH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 257 | ClientRequestID: 22 | Username: Alan Sorrel. | Thread:5992 | 2019-02-11 01:26:15 HD Server | Thread:5992 (4) | Socket gracefully closed by remote side. | 2019-02-11 01:26:15 HD Server | Thread:5992 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-02-11 01:26:15 HD Server | Thread:5992 (4) | Closed. | 2019-02-11 01:26:15 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2019-02-11 01:26:15 HD Server Manager | Started new historical data server. Count=2 | 2019-02-11 01:26:15 HD Server | Thread:1636 (4) | Creating socket. | 2019-02-11 01:26:15 HD Server | Setting DTC encoding to Binary VLS | Thread:1636 | 2019-02-11 01:26:15 HD Server | Received login. Requesting authorization. | Username: Alan Sorrel. | Thread:1636 | 2019-02-11 01:26:15 HD Server | Login has been authorized. | Username: Alan Sorrel. | Thread:1636 | 2019-02-11 01:26:15 HD Server | HD Request #23 | Socket: 4 | Symbol: F.US.YMH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2019-02-11 06:17:23 | ClientRequestID: 23 | Username: Alan Sorrel. | Thread:1636 | 2019-02-11 01:26:15 HD Server | HD Request #23 | Socket: 4 | Symbol: F.US.YMH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 1 | ClientRequestID: 23 | Username: Alan Sorrel. | Thread:1636 | 2019-02-11 01:26:15 HD Server | Thread:1636 (4) | Socket gracefully closed by remote side. | 2019-02-11 01:26:15 HD Server | Thread:1636 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-02-11 01:26:15 HD Server | Thread:1636 (4) | Closed. | 2019-02-11 01:26:15 DTC client #11. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.ENQH19 | 2019-02-11 01:26:15 DTC client #11. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.YMH19 | 2019-02-11 01:26:15 HD Server | Server thread ending. Closing socket. | Username: Alan Sorrel. | Thread:1636 | 2019-02-11 01:26:15 HD Server Manager | Current server count=1 | 2019-02-11 01:26:15 HD Server | Server thread ending. Closing socket. | Username: Alan Sorrel. | Thread:5992 | 2019-02-11 01:26:15 HD Server Manager | Current server count=0 | 2019-02-11 01:26:15 DTCServer (3) | Creating socket. | 2019-02-11 01:41:06 DTCServer (3) | Connecting to IP: 0.0.0.0. | 2019-02-11 01:41:06 DTCServer (3) | Error connecting. Address Family: 2. IP: 0.0.0.0. Windows error code 10049: The requested address is not valid in its context. | 2019-02-11 01:41:06 * DTCServer (3) | Connect event error. Windows error code 10049: The requested address is not valid in its context. | 2019-02-11 01:41:06 * DTCServer (3) | Shutdown error. Windows error code 10057: A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied. | 2019-02-11 01:41:06 * DTCServer (3) | Shutdown started. Waiting for graceful close. | 2019-02-11 01:41:06 Deleting individual DTC server: DTC client #11. Sierra Chart. 127.0.0.1 | 2019-02-11 01:41:06 DTCServer (3) | Socket receive error. Windows error code 10057: A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied. | 2019-02-11 01:41:10 DTCServer (3) | Closed. | 2019-02-11 01:41:10 DTC Protocol server | Incoming connection from 127.0.0.1. | 2019-02-11 01:42:10 DTCServer (3) | Creating socket. | 2019-02-11 01:42:10 DTC client #12. 127.0.0.1 | Set DTC encoding to Binary VLS | 2019-02-11 01:42:10 DTC client #12. 127.0.0.1 | Requested heartbeat interval: 20 | 2019-02-11 01:42:10 DTC client #12. Sierra Chart. 127.0.0.1 | Received logon request. | 2019-02-11 01:42:10 DTC client #12. Sierra Chart. 127.0.0.1 | Sent successful Logon response message to client. Username: Alan Sorrel. Result text: Connected to SC DTC Protocol server. Service=cqgfix|SymbolSettings=cqg | 2019-02-11 01:42:10 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2019-02-11 01:42:15 HD Server Manager | Started new historical data server. Count=1 | 2019-02-11 01:42:15 HD Server | Thread:10588 (4) | Creating socket. | 2019-02-11 01:42:15 HD Server | Setting DTC encoding to Binary VLS | Thread:10588 | 2019-02-11 01:42:15 HD Server | Received login. Requesting authorization. | Username: Alan Sorrel. | Thread:10588 | 2019-02-11 01:42:15 HD Server | Login has been authorized. | Username: Alan Sorrel. | Thread:10588 | 2019-02-11 01:42:15 HD Server | HD Request #24 | Socket: 4 | Symbol: F.US.ENQH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2019-02-11 08:41:07 | ClientRequestID: 24 | Username: Alan Sorrel. | Thread:10588 | 2019-02-11 01:42:15 HD Server | HD Request #24 | Socket: 4 | Symbol: F.US.ENQH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 61 | ClientRequestID: 24 | Username: Alan Sorrel. | Thread:10588 | 2019-02-11 01:42:15 HD Server | Thread:10588 (4) | Socket gracefully closed by remote side. | 2019-02-11 01:42:15 HD Server | Thread:10588 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-02-11 01:42:15 HD Server | Thread:10588 (4) | Closed. | 2019-02-11 01:42:15 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2019-02-11 01:42:15 HD Server Manager | Started new historical data server. Count=2 | 2019-02-11 01:42:15 HD Server | Thread:1128 (4) | Creating socket. | 2019-02-11 01:42:15 HD Server | Setting DTC encoding to Binary VLS | Thread:1128 | 2019-02-11 01:42:15 HD Server | Received login. Requesting authorization. | Username: Alan Sorrel. | Thread:1128 | 2019-02-11 01:42:15 HD Server | Login has been authorized. | Username: Alan Sorrel. | Thread:1128 | 2019-02-11 01:42:15 HD Server | HD Request #25 | Socket: 4 | Symbol: F.US.YMH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2019-02-11 06:17:23 | ClientRequestID: 25 | Username: Alan Sorrel. | Thread:1128 | 2019-02-11 01:42:15 HD Server | HD Request #25 | Socket: 4 | Symbol: F.US.YMH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 1 | ClientRequestID: 25 | Username: Alan Sorrel. | Thread:1128 | 2019-02-11 01:42:15 HD Server | Thread:1128 (4) | Socket gracefully closed by remote side. | 2019-02-11 01:42:15 HD Server | Thread:1128 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-02-11 01:42:15 HD Server | Thread:1128 (4) | Closed. | 2019-02-11 01:42:15 DTC client #12. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.ENQH19 | 2019-02-11 01:42:15 DTC client #12. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.YMH19 | 2019-02-11 01:42:15 HD Server | Server thread ending. Closing socket. | Username: Alan Sorrel. | Thread:1128 | 2019-02-11 01:42:15 HD Server Manager | Current server count=1 | 2019-02-11 01:42:15 HD Server | Server thread ending. Closing socket. | Username: Alan Sorrel. | Thread:10588 | 2019-02-11 01:42:15 HD Server Manager | Current server count=0 | 2019-02-11 01:42:15 DTCServer (3) | Creating socket. | 2019-02-11 01:57:06 DTCServer (3) | Connecting to IP: 0.0.0.0. | 2019-02-11 01:57:06 DTCServer (3) | Error connecting. Address Family: 2. IP: 0.0.0.0. Windows error code 10049: The requested address is not valid in its context. | 2019-02-11 01:57:06 * DTCServer (3) | Connect event error. Windows error code 10049: The requested address is not valid in its context. | 2019-02-11 01:57:06 * DTCServer (3) | Shutdown error. Windows error code 10057: A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied. | 2019-02-11 01:57:06 * DTCServer (3) | Shutdown started. Waiting for graceful close. | 2019-02-11 01:57:06 Deleting individual DTC server: DTC client #12. Sierra Chart. 127.0.0.1 | 2019-02-11 01:57:06 DTCServer (3) | Socket receive error. Windows error code 10057: A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied. | 2019-02-11 01:57:10 DTCServer (3) | Closed. | 2019-02-11 01:57:10 DTC Protocol server | Incoming connection from 127.0.0.1. | 2019-02-11 01:58:09 DTCServer (3) | Creating socket. | 2019-02-11 01:58:09 DTC client #13. 127.0.0.1 | Set DTC encoding to Binary VLS | 2019-02-11 01:58:09 DTC client #13. 127.0.0.1 | Requested heartbeat interval: 20 | 2019-02-11 01:58:09 DTC client #13. Sierra Chart. 127.0.0.1 | Received logon request. | 2019-02-11 01:58:09 DTC client #13. Sierra Chart. 127.0.0.1 | Sent successful Logon response message to client. Username: Alan Sorrel. Result text: Connected to SC DTC Protocol server. Service=cqgfix|SymbolSettings=cqg | 2019-02-11 01:58:09 DTC client #13. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.ENQH19 | 2019-02-11 01:58:14 DTC client #13. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.YMH19 | 2019-02-11 01:58:14 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2019-02-11 01:58:15 HD Server Manager | Started new historical data server. Count=1 | 2019-02-11 01:58:15 HD Server | Thread:3464 (4) | Creating socket. | 2019-02-11 01:58:15 HD Server | Setting DTC encoding to Binary VLS | Thread:3464 | 2019-02-11 01:58:15 HD Server | Received login. Requesting authorization. | Username: Alan Sorrel. | Thread:3464 | 2019-02-11 01:58:15 HD Server | Login has been authorized. | Username: Alan Sorrel. | Thread:3464 | 2019-02-11 01:58:15 HD Server | HD Request #26 | Socket: 4 | Symbol: F.US.YMH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2019-02-11 06:17:23 | ClientRequestID: 26 | Username: Alan Sorrel. | Thread:3464 | 2019-02-11 01:58:15 HD Server | HD Request #26 | Socket: 4 | Symbol: F.US.YMH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 1 | ClientRequestID: 26 | Username: Alan Sorrel. | Thread:3464 | 2019-02-11 01:58:15 HD Server | Thread:3464 (4) | Socket gracefully closed by remote side. | 2019-02-11 01:58:15 HD Server | Thread:3464 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-02-11 01:58:15 HD Server | Thread:3464 (4) | Closed. | 2019-02-11 01:58:15 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2019-02-11 01:58:15 HD Server Manager | Started new historical data server. Count=2 | 2019-02-11 01:58:15 HD Server | Thread:11800 (4) | Creating socket. | 2019-02-11 01:58:15 HD Server | Setting DTC encoding to Binary VLS | Thread:11800 | 2019-02-11 01:58:15 HD Server | Received login. Requesting authorization. | Username: Alan Sorrel. | Thread:11800 | 2019-02-11 01:58:15 HD Server | Login has been authorized. | Username: Alan Sorrel. | Thread:11800 | 2019-02-11 01:58:15 HD Server | HD Request #27 | Socket: 4 | Symbol: F.US.ENQH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2019-02-11 08:57:06 | ClientRequestID: 27 | Username: Alan Sorrel. | Thread:11800 | 2019-02-11 01:58:15 HD Server | HD Request #27 | Socket: 4 | Symbol: F.US.ENQH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 206 | ClientRequestID: 27 | Username: Alan Sorrel. | Thread:11800 | 2019-02-11 01:58:15 HD Server | Thread:11800 (4) | Socket gracefully closed by remote side. | 2019-02-11 01:58:15 HD Server | Thread:11800 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-02-11 01:58:15 HD Server | Thread:11800 (4) | Closed. | 2019-02-11 01:58:15 HD Server | Server thread ending. Closing socket. | Username: Alan Sorrel. | Thread:11800 | 2019-02-11 01:58:15 HD Server Manager | Current server count=1 | 2019-02-11 01:58:15 HD Server | Server thread ending. Closing socket. | Username: Alan Sorrel. | Thread:3464 | 2019-02-11 01:58:15 HD Server Manager | Current server count=0 | 2019-02-11 01:58:15 DTCServer (3) | Creating socket. | 2019-02-11 02:13:06 DTCServer (3) | Connecting to IP: 0.0.0.0. | 2019-02-11 02:13:06 DTCServer (3) | Error connecting. Address Family: 2. IP: 0.0.0.0. Windows error code 10049: The requested address is not valid in its context. | 2019-02-11 02:13:06 * DTCServer (3) | Connect event error. Windows error code 10049: The requested address is not valid in its context. | 2019-02-11 02:13:06 * DTCServer (3) | Shutdown error. Windows error code 10057: A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied. | 2019-02-11 02:13:06 * DTCServer (3) | Shutdown started. Waiting for graceful close. | 2019-02-11 02:13:06 Deleting individual DTC server: DTC client #13. Sierra Chart. 127.0.0.1 | 2019-02-11 02:13:06 DTCServer (3) | Socket receive error. Windows error code 10057: A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied. | 2019-02-11 02:13:09 DTCServer (3) | Closed. | 2019-02-11 02:13:09 DTC Protocol server | Incoming connection from 127.0.0.1. | 2019-02-11 02:14:10 DTCServer (3) | Creating socket. | 2019-02-11 02:14:10 DTC client #14. 127.0.0.1 | Set DTC encoding to Binary VLS | 2019-02-11 02:14:10 DTC client #14. 127.0.0.1 | Requested heartbeat interval: 20 | 2019-02-11 02:14:10 DTC client #14. Sierra Chart. 127.0.0.1 | Received logon request. | 2019-02-11 02:14:10 DTC client #14. Sierra Chart. 127.0.0.1 | Sent successful Logon response message to client. Username: Alan Sorrel. Result text: Connected to SC DTC Protocol server. Service=cqgfix|SymbolSettings=cqg | 2019-02-11 02:14:10 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2019-02-11 02:14:14 HD Server Manager | Started new historical data server. Count=1 | 2019-02-11 02:14:14 HD Server | Thread:9196 (4) | Creating socket. | 2019-02-11 02:14:14 HD Server | Setting DTC encoding to Binary VLS | Thread:9196 | 2019-02-11 02:14:14 HD Server | Received login. Requesting authorization. | Username: Alan Sorrel. | Thread:9196 | 2019-02-11 02:14:14 HD Server | Login has been authorized. | Username: Alan Sorrel. | Thread:9196 | 2019-02-11 02:14:14 HD Server | HD Request #28 | Socket: 4 | Symbol: F.US.ENQH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2019-02-11 09:13:06 | ClientRequestID: 28 | Username: Alan Sorrel. | Thread:9196 | 2019-02-11 02:14:14 HD Server | HD Request #28 | Socket: 4 | Symbol: F.US.ENQH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 175 | ClientRequestID: 28 | Username: Alan Sorrel. | Thread:9196 | 2019-02-11 02:14:14 HD Server | Thread:9196 (4) | Socket gracefully closed by remote side. | 2019-02-11 02:14:14 HD Server | Thread:9196 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-02-11 02:14:14 HD Server | Thread:9196 (4) | Closed. | 2019-02-11 02:14:14 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2019-02-11 02:14:14 HD Server Manager | Started new historical data server. Count=2 | 2019-02-11 02:14:14 HD Server | Thread:11092 (4) | Creating socket. | 2019-02-11 02:14:14 HD Server | Setting DTC encoding to Binary VLS | Thread:11092 | 2019-02-11 02:14:14 HD Server | Received login. Requesting authorization. | Username: Alan Sorrel. | Thread:11092 | 2019-02-11 02:14:14 HD Server | Login has been authorized. | Username: Alan Sorrel. | Thread:11092 | 2019-02-11 02:14:14 HD Server | HD Request #29 | Socket: 4 | Symbol: F.US.YMH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2019-02-11 06:17:23 | ClientRequestID: 29 | Username: Alan Sorrel. | Thread:11092 | 2019-02-11 02:14:14 HD Server | HD Request #29 | Socket: 4 | Symbol: F.US.YMH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 1 | ClientRequestID: 29 | Username: Alan Sorrel. | Thread:11092 | 2019-02-11 02:14:14 HD Server | Thread:11092 (4) | Socket gracefully closed by remote side. | 2019-02-11 02:14:14 HD Server | Thread:11092 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-02-11 02:14:14 HD Server | Thread:11092 (4) | Closed. | 2019-02-11 02:14:14 HD Server | Server thread ending. Closing socket. | Username: Alan Sorrel. | Thread:11092 | 2019-02-11 02:14:14 HD Server Manager | Current server count=1 | 2019-02-11 02:14:14 HD Server | Server thread ending. Closing socket. | Username: Alan Sorrel. | Thread:9196 | 2019-02-11 02:14:14 HD Server Manager | Current server count=0 | 2019-02-11 02:14:14 DTC client #14. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.ENQH19 | 2019-02-11 02:14:15 DTC client #14. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.YMH19 | 2019-02-11 02:14:15 DTCServer (3) | Creating socket. | 2019-02-11 02:17:06 DTCServer (3) | Connecting to IP: 0.0.0.0. | 2019-02-11 02:17:06 DTCServer (3) | Error connecting. Address Family: 2. IP: 0.0.0.0. Windows error code 10049: The requested address is not valid in its context. | 2019-02-11 02:17:06 * DTCServer (3) | Connect event error. Windows error code 10049: The requested address is not valid in its context. | 2019-02-11 02:17:06 * DTCServer (3) | Shutdown error. Windows error code 10057: A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied. | 2019-02-11 02:17:06 * DTCServer (3) | Shutdown started. Waiting for graceful close. | 2019-02-11 02:17:06 Deleting individual DTC server: DTC client #14. Sierra Chart. 127.0.0.1 | 2019-02-11 02:17:06 DTCServer (3) | Socket receive error. Windows error code 10057: A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied. | 2019-02-11 02:17:10 DTCServer (3) | Closed. | 2019-02-11 02:17:10 DTC Protocol server | Incoming connection from 127.0.0.1. | 2019-02-11 02:18:10 DTCServer (3) | Creating socket. | 2019-02-11 02:18:10 DTC client #15. 127.0.0.1 | Set DTC encoding to Binary VLS | 2019-02-11 02:18:10 DTC client #15. 127.0.0.1 | Requested heartbeat interval: 20 | 2019-02-11 02:18:10 DTC client #15. Sierra Chart. 127.0.0.1 | Received logon request. | 2019-02-11 02:18:10 DTC client #15. Sierra Chart. 127.0.0.1 | Sent successful Logon response message to client. Username: Alan Sorrel. Result text: Connected to SC DTC Protocol server. Service=cqgfix|SymbolSettings=cqg | 2019-02-11 02:18:10 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2019-02-11 02:18:14 HD Server Manager | Started new historical data server. Count=1 | 2019-02-11 02:18:14 HD Server | Thread:11080 (4) | Creating socket. | 2019-02-11 02:18:14 HD Server | Setting DTC encoding to Binary VLS | Thread:11080 | 2019-02-11 02:18:14 HD Server | Received login. Requesting authorization. | Username: Alan Sorrel. | Thread:11080 | 2019-02-11 02:18:14 HD Server | Login has been authorized. | Username: Alan Sorrel. | Thread:11080 | 2019-02-11 02:18:14 HD Server | HD Request #30 | Socket: 4 | Symbol: F.US.YMH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2019-02-11 06:17:23 | ClientRequestID: 30 | Username: Alan Sorrel. | Thread:11080 | 2019-02-11 02:18:14 HD Server | HD Request #30 | Socket: 4 | Symbol: F.US.YMH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 1 | ClientRequestID: 30 | Username: Alan Sorrel. | Thread:11080 | 2019-02-11 02:18:14 HD Server | Thread:11080 (4) | Socket gracefully closed by remote side. | 2019-02-11 02:18:14 HD Server | Thread:11080 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-02-11 02:18:14 HD Server | Thread:11080 (4) | Closed. | 2019-02-11 02:18:14 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2019-02-11 02:18:14 HD Server Manager | Started new historical data server. Count=2 | 2019-02-11 02:18:14 HD Server | Thread:5428 (4) | Creating socket. | 2019-02-11 02:18:14 HD Server | Setting DTC encoding to Binary VLS | Thread:5428 | 2019-02-11 02:18:14 HD Server | Received login. Requesting authorization. | Username: Alan Sorrel. | Thread:5428 | 2019-02-11 02:18:14 HD Server | Login has been authorized. | Username: Alan Sorrel. | Thread:5428 | 2019-02-11 02:18:14 HD Server | HD Request #31 | Socket: 4 | Symbol: F.US.ENQH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2019-02-11 09:17:07 | ClientRequestID: 31 | Username: Alan Sorrel. | Thread:5428 | 2019-02-11 02:18:14 HD Server | HD Request #31 | Socket: 4 | Symbol: F.US.ENQH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 185 | ClientRequestID: 31 | Username: Alan Sorrel. | Thread:5428 | 2019-02-11 02:18:14 HD Server | Thread:5428 (4) | Socket gracefully closed by remote side. | 2019-02-11 02:18:14 HD Server | Thread:5428 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-02-11 02:18:14 HD Server | Thread:5428 (4) | Closed. | 2019-02-11 02:18:14 HD Server | Server thread ending. Closing socket. | Username: Alan Sorrel. | Thread:5428 | 2019-02-11 02:18:15 HD Server Manager | Current server count=1 | 2019-02-11 02:18:15 HD Server | Server thread ending. Closing socket. | Username: Alan Sorrel. | Thread:11080 | 2019-02-11 02:18:15 HD Server Manager | Current server count=0 | 2019-02-11 02:18:15 DTC client #15. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.ENQH19 | 2019-02-11 02:18:15 DTC client #15. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.YMH19 | 2019-02-11 02:18:15 DTCServer (3) | Creating socket. | 2019-02-11 02:29:06 DTCServer (3) | Connecting to IP: 0.0.0.0. | 2019-02-11 02:29:06 DTCServer (3) | Error connecting. Address Family: 2. IP: 0.0.0.0. Windows error code 10049: The requested address is not valid in its context. | 2019-02-11 02:29:06 * DTCServer (3) | Connect event error. Windows error code 10049: The requested address is not valid in its context. | 2019-02-11 02:29:06 * DTCServer (3) | Shutdown error. Windows error code 10057: A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied. | 2019-02-11 02:29:06 * DTCServer (3) | Shutdown started. Waiting for graceful close. | 2019-02-11 02:29:06 Deleting individual DTC server: DTC client #15. Sierra Chart. 127.0.0.1 | 2019-02-11 02:29:06 DTCServer (3) | Socket receive error. Windows error code 10057: A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied. | 2019-02-11 02:29:10 DTCServer (3) | Closed. | 2019-02-11 02:29:10 DTC Protocol server | Incoming connection from 127.0.0.1. | 2019-02-11 02:30:10 DTCServer (3) | Creating socket. | 2019-02-11 02:30:10 DTC client #16. 127.0.0.1 | Set DTC encoding to Binary VLS | 2019-02-11 02:30:10 DTC client #16. 127.0.0.1 | Requested heartbeat interval: 20 | 2019-02-11 02:30:10 DTC client #16. Sierra Chart. 127.0.0.1 | Received logon request. | 2019-02-11 02:30:10 DTC client #16. Sierra Chart. 127.0.0.1 | Sent successful Logon response message to client. Username: Alan Sorrel. Result text: Connected to SC DTC Protocol server. Service=cqgfix|SymbolSettings=cqg | 2019-02-11 02:30:10 DTC client #16. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.ENQH19 | 2019-02-11 02:30:15 DTC client #16. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.YMH19 | 2019-02-11 02:30:15 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2019-02-11 02:30:16 HD Server Manager | Started new historical data server. Count=1 | 2019-02-11 02:30:16 HD Server | Thread:13164 (4) | Creating socket. | 2019-02-11 02:30:16 HD Server | Setting DTC encoding to Binary VLS | Thread:13164 | 2019-02-11 02:30:16 HD Server | Received login. Requesting authorization. | Username: Alan Sorrel. | Thread:13164 | 2019-02-11 02:30:16 HD Server | Login has been authorized. | Username: Alan Sorrel. | Thread:13164 | 2019-02-11 02:30:16 HD Server | HD Request #32 | Socket: 4 | Symbol: F.US.YMH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2019-02-11 06:17:23 | ClientRequestID: 32 | Username: Alan Sorrel. | Thread:13164 | 2019-02-11 02:30:16 HD Server | HD Request #32 | Socket: 4 | Symbol: F.US.YMH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 1 | ClientRequestID: 32 | Username: Alan Sorrel. | Thread:13164 | 2019-02-11 02:30:16 HD Server | Thread:13164 (4) | Socket gracefully closed by remote side. | 2019-02-11 02:30:16 HD Server | Thread:13164 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-02-11 02:30:16 HD Server | Thread:13164 (4) | Closed. | 2019-02-11 02:30:16 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2019-02-11 02:30:16 HD Server Manager | Started new historical data server. Count=2 | 2019-02-11 02:30:16 HD Server | Thread:4392 (4) | Creating socket. | 2019-02-11 02:30:16 HD Server | Setting DTC encoding to Binary VLS | Thread:4392 | 2019-02-11 02:30:16 HD Server | Received login. Requesting authorization. | Username: Alan Sorrel. | Thread:4392 | 2019-02-11 02:30:16 HD Server | Login has been authorized. | Username: Alan Sorrel. | Thread:4392 | 2019-02-11 02:30:16 HD Server | HD Request #33 | Socket: 4 | Symbol: F.US.ENQH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2019-02-11 09:29:06 | ClientRequestID: 33 | Username: Alan Sorrel. | Thread:4392 | 2019-02-11 02:30:16 HD Server | HD Request #33 | Socket: 4 | Symbol: F.US.ENQH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 84 | ClientRequestID: 33 | Username: Alan Sorrel. | Thread:4392 | 2019-02-11 02:30:16 HD Server | Thread:4392 (4) | Socket gracefully closed by remote side. | 2019-02-11 02:30:16 HD Server | Thread:4392 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-02-11 02:30:16 HD Server | Thread:4392 (4) | Closed. | 2019-02-11 02:30:16 HD Server | Server thread ending. Closing socket. | Username: Alan Sorrel. | Thread:4392 | 2019-02-11 02:30:16 HD Server Manager | Current server count=1 | 2019-02-11 02:30:16 HD Server | Server thread ending. Closing socket. | Username: Alan Sorrel. | Thread:13164 | 2019-02-11 02:30:16 HD Server Manager | Current server count=0 | 2019-02-11 02:30:16 DTCServer (3) | Creating socket. | 2019-02-11 02:45:06 DTCServer (3) | Connecting to IP: 0.0.0.0. | 2019-02-11 02:45:06 DTCServer (3) | Error connecting. Address Family: 2. IP: 0.0.0.0. Windows error code 10049: The requested address is not valid in its context. | 2019-02-11 02:45:06 * DTCServer (3) | Connect event error. Windows error code 10049: The requested address is not valid in its context. | 2019-02-11 02:45:06 * DTCServer (3) | Shutdown error. Windows error code 10057: A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied. | 2019-02-11 02:45:06 * DTCServer (3) | Shutdown started. Waiting for graceful close. | 2019-02-11 02:45:06 Deleting individual DTC server: DTC client #16. Sierra Chart. 127.0.0.1 | 2019-02-11 02:45:06 DTCServer (3) | Socket receive error. Windows error code 10057: A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied. | 2019-02-11 02:45:10 DTCServer (3) | Closed. | 2019-02-11 02:45:10 DTC Protocol server | Incoming connection from 127.0.0.1. | 2019-02-11 02:46:09 DTCServer (3) | Creating socket. | 2019-02-11 02:46:09 DTC client #17. 127.0.0.1 | Set DTC encoding to Binary VLS | 2019-02-11 02:46:09 DTC client #17. 127.0.0.1 | Requested heartbeat interval: 20 | 2019-02-11 02:46:09 DTC client #17. Sierra Chart. 127.0.0.1 | Received logon request. | 2019-02-11 02:46:09 DTC client #17. Sierra Chart. 127.0.0.1 | Sent successful Logon response message to client. Username: Alan Sorrel. Result text: Connected to SC DTC Protocol server. Service=cqgfix|SymbolSettings=cqg | 2019-02-11 02:46:09 DTC client #17. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.ENQH19 | 2019-02-11 02:46:14 DTC client #17. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.YMH19 | 2019-02-11 02:46:14 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2019-02-11 02:46:14 HD Server Manager | Started new historical data server. Count=1 | 2019-02-11 02:46:14 HD Server | Thread:6036 (4) | Creating socket. | 2019-02-11 02:46:14 HD Server | Setting DTC encoding to Binary VLS | Thread:6036 | 2019-02-11 02:46:14 HD Server | Received login. Requesting authorization. | Username: Alan Sorrel. | Thread:6036 | 2019-02-11 02:46:14 HD Server | Login has been authorized. | Username: Alan Sorrel. | Thread:6036 | 2019-02-11 02:46:14 HD Server | HD Request #34 | Socket: 4 | Symbol: F.US.ENQH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2019-02-11 09:45:05 | ClientRequestID: 34 | Username: Alan Sorrel. | Thread:6036 | 2019-02-11 02:46:14 HD Server | HD Request #34 | Socket: 4 | Symbol: F.US.ENQH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 105 | ClientRequestID: 34 | Username: Alan Sorrel. | Thread:6036 | 2019-02-11 02:46:14 HD Server | Thread:6036 (4) | Socket gracefully closed by remote side. | 2019-02-11 02:46:14 HD Server | Thread:6036 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-02-11 02:46:14 HD Server | Thread:6036 (4) | Closed. | 2019-02-11 02:46:14 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2019-02-11 02:46:14 HD Server Manager | Started new historical data server. Count=2 | 2019-02-11 02:46:14 HD Server | Thread:324 (4) | Creating socket. | 2019-02-11 02:46:14 HD Server | Setting DTC encoding to Binary VLS | Thread:324 | 2019-02-11 02:46:14 HD Server | Received login. Requesting authorization. | Username: Alan Sorrel. | Thread:324 | 2019-02-11 02:46:14 HD Server | Login has been authorized. | Username: Alan Sorrel. | Thread:324 | 2019-02-11 02:46:14 HD Server | HD Request #35 | Socket: 4 | Symbol: F.US.YMH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2019-02-11 06:17:23 | ClientRequestID: 35 | Username: Alan Sorrel. | Thread:324 | 2019-02-11 02:46:14 HD Server | HD Request #35 | Socket: 4 | Symbol: F.US.YMH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 1 | ClientRequestID: 35 | Username: Alan Sorrel. | Thread:324 | 2019-02-11 02:46:14 HD Server | Thread:324 (4) | Socket gracefully closed by remote side. | 2019-02-11 02:46:14 HD Server | Thread:324 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-02-11 02:46:14 HD Server | Thread:324 (4) | Closed. | 2019-02-11 02:46:14 HD Server | Server thread ending. Closing socket. | Username: Alan Sorrel. | Thread:324 | 2019-02-11 02:46:14 HD Server Manager | Current server count=1 | 2019-02-11 02:46:14 HD Server | Server thread ending. Closing socket. | Username: Alan Sorrel. | Thread:6036 | 2019-02-11 02:46:14 HD Server Manager | Current server count=0 | 2019-02-11 02:46:14 DTCServer (3) | Creating socket. | 2019-02-11 03:01:06 DTCServer (3) | Connecting to IP: 0.0.0.0. | 2019-02-11 03:01:06 DTCServer (3) | Error connecting. Address Family: 2. IP: 0.0.0.0. Windows error code 10049: The requested address is not valid in its context. | 2019-02-11 03:01:06 * DTCServer (3) | Connect event error. Windows error code 10049: The requested address is not valid in its context. | 2019-02-11 03:01:06 * DTCServer (3) | Shutdown error. Windows error code 10057: A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied. | 2019-02-11 03:01:06 * DTCServer (3) | Shutdown started. Waiting for graceful close. | 2019-02-11 03:01:06 Deleting individual DTC server: DTC client #17. Sierra Chart. 127.0.0.1 | 2019-02-11 03:01:06 DTCServer (3) | Socket receive error. Windows error code 10057: A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied. | 2019-02-11 03:01:09 DTCServer (3) | Closed. | 2019-02-11 03:01:09 DTC Protocol server | Incoming connection from 127.0.0.1. | 2019-02-11 03:02:10 DTCServer (3) | Creating socket. | 2019-02-11 03:02:10 DTC client #18. 127.0.0.1 | Set DTC encoding to Binary VLS | 2019-02-11 03:02:10 DTC client #18. 127.0.0.1 | Requested heartbeat interval: 20 | 2019-02-11 03:02:10 DTC client #18. Sierra Chart. 127.0.0.1 | Received logon request. | 2019-02-11 03:02:10 DTC client #18. Sierra Chart. 127.0.0.1 | Sent successful Logon response message to client. Username: Alan Sorrel. Result text: Connected to SC DTC Protocol server. Service=cqgfix|SymbolSettings=cqg | 2019-02-11 03:02:10 DTC client #18. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.ENQH19 | 2019-02-11 03:02:15 DTC client #18. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.YMH19 | 2019-02-11 03:02:15 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2019-02-11 03:02:16 HD Server Manager | Started new historical data server. Count=1 | 2019-02-11 03:02:16 HD Server | Thread:3284 (4) | Creating socket. | 2019-02-11 03:02:16 HD Server | Setting DTC encoding to Binary VLS | Thread:3284 | 2019-02-11 03:02:16 HD Server | Received login. Requesting authorization. | Username: Alan Sorrel. | Thread:3284 | 2019-02-11 03:02:16 HD Server | Login has been authorized. | Username: Alan Sorrel. | Thread:3284 | 2019-02-11 03:02:16 HD Server | HD Request #36 | Socket: 4 | Symbol: F.US.YMH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2019-02-11 06:17:23 | ClientRequestID: 36 | Username: Alan Sorrel. | Thread:3284 | 2019-02-11 03:02:16 HD Server | HD Request #36 | Socket: 4 | Symbol: F.US.YMH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 1 | ClientRequestID: 36 | Username: Alan Sorrel. | Thread:3284 | 2019-02-11 03:02:16 HD Server | Thread:3284 (4) | Socket gracefully closed by remote side. | 2019-02-11 03:02:16 HD Server | Thread:3284 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-02-11 03:02:16 HD Server | Thread:3284 (4) | Closed. | 2019-02-11 03:02:16 HD Server | Server thread ending. Closing socket. | Username: Alan Sorrel. | Thread:3284 | 2019-02-11 03:02:16 HD Server Manager | Current server count=0 | 2019-02-11 03:02:16 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2019-02-11 03:02:16 HD Server Manager | Started new historical data server. Count=1 | 2019-02-11 03:02:16 HD Server | Thread:2208 (4) | Creating socket. | 2019-02-11 03:02:16 HD Server | Setting DTC encoding to Binary VLS | Thread:2208 | 2019-02-11 03:02:16 HD Server | Received login. Requesting authorization. | Username: Alan Sorrel. | Thread:2208 | 2019-02-11 03:02:16 HD Server | Login has been authorized. | Username: Alan Sorrel. | Thread:2208 | 2019-02-11 03:02:16 HD Server | HD Request #37 | Socket: 4 | Symbol: F.US.ENQH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2019-02-11 10:01:04 | ClientRequestID: 37 | Username: Alan Sorrel. | Thread:2208 | 2019-02-11 03:02:16 HD Server | HD Request #37 | Socket: 4 | Symbol: F.US.ENQH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 122 | ClientRequestID: 37 | Username: Alan Sorrel. | Thread:2208 | 2019-02-11 03:02:16 HD Server | Thread:2208 (4) | Socket gracefully closed by remote side. | 2019-02-11 03:02:16 HD Server | Thread:2208 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-02-11 03:02:16 HD Server | Thread:2208 (4) | Closed. | 2019-02-11 03:02:16 HD Server | Server thread ending. Closing socket. | Username: Alan Sorrel. | Thread:2208 | 2019-02-11 03:02:16 HD Server Manager | Current server count=0 | 2019-02-11 03:02:16 DTCServer (3) | Creating socket. | 2019-02-11 03:17:06 DTCServer (3) | Connecting to IP: 0.0.0.0. | 2019-02-11 03:17:06 DTCServer (3) | Error connecting. Address Family: 2. IP: 0.0.0.0. Windows error code 10049: The requested address is not valid in its context. | 2019-02-11 03:17:06 * DTCServer (3) | Connect event error. Windows error code 10049: The requested address is not valid in its context. | 2019-02-11 03:17:06 * DTCServer (3) | Shutdown error. Windows error code 10057: A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied. | 2019-02-11 03:17:06 * DTCServer (3) | Shutdown started. Waiting for graceful close. | 2019-02-11 03:17:06 Deleting individual DTC server: DTC client #18. Sierra Chart. 127.0.0.1 | 2019-02-11 03:17:07 DTCServer (3) | Socket receive error. Windows error code 10057: A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied. | 2019-02-11 03:17:10 DTCServer (3) | Closed. | 2019-02-11 03:17:10 DTC Protocol server | Incoming connection from 127.0.0.1. | 2019-02-11 03:18:08 DTCServer (3) | Creating socket. | 2019-02-11 03:18:08 DTC client #19. 127.0.0.1 | Set DTC encoding to Binary VLS | 2019-02-11 03:18:08 DTC client #19. 127.0.0.1 | Requested heartbeat interval: 20 | 2019-02-11 03:18:08 DTC client #19. Sierra Chart. 127.0.0.1 | Received logon request. | 2019-02-11 03:18:08 DTC client #19. Sierra Chart. 127.0.0.1 | Sent successful Logon response message to client. Username: Alan Sorrel. Result text: Connected to SC DTC Protocol server. Service=cqgfix|SymbolSettings=cqg | 2019-02-11 03:18:08 DTC client #19. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.ENQH19 | 2019-02-11 03:18:13 DTC client #19. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.YMH19 | 2019-02-11 03:18:13 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2019-02-11 03:18:14 HD Server Manager | Started new historical data server. Count=1 | 2019-02-11 03:18:14 HD Server | Thread:6136 (4) | Creating socket. | 2019-02-11 03:18:14 HD Server | Setting DTC encoding to Binary VLS | Thread:6136 | 2019-02-11 03:18:14 HD Server | Received login. Requesting authorization. | Username: Alan Sorrel. | Thread:6136 | 2019-02-11 03:18:14 HD Server | Login has been authorized. | Username: Alan Sorrel. | Thread:6136 | 2019-02-11 03:18:14 HD Server | HD Request #38 | Socket: 4 | Symbol: F.US.YMH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2019-02-11 06:17:23 | ClientRequestID: 38 | Username: Alan Sorrel. | Thread:6136 | 2019-02-11 03:18:14 HD Server | HD Request #38 | Socket: 4 | Symbol: F.US.YMH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 1 | ClientRequestID: 38 | Username: Alan Sorrel. | Thread:6136 | 2019-02-11 03:18:14 HD Server | Thread:6136 (4) | Socket gracefully closed by remote side. | 2019-02-11 03:18:14 HD Server | Thread:6136 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-02-11 03:18:14 HD Server | Thread:6136 (4) | Closed. | 2019-02-11 03:18:14 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2019-02-11 03:18:14 HD Server Manager | Started new historical data server. Count=2 | 2019-02-11 03:18:14 HD Server | Thread:6508 (4) | Creating socket. | 2019-02-11 03:18:14 HD Server | Setting DTC encoding to Binary VLS | Thread:6508 | 2019-02-11 03:18:14 HD Server | Received login. Requesting authorization. | Username: Alan Sorrel. | Thread:6508 | 2019-02-11 03:18:14 HD Server | Login has been authorized. | Username: Alan Sorrel. | Thread:6508 | 2019-02-11 03:18:14 HD Server | HD Request #39 | Socket: 4 | Symbol: F.US.ENQH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2019-02-11 10:17:03 | ClientRequestID: 39 | Username: Alan Sorrel. | Thread:6508 | 2019-02-11 03:18:14 HD Server | HD Request #39 | Socket: 4 | Symbol: F.US.ENQH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 57 | ClientRequestID: 39 | Username: Alan Sorrel. | Thread:6508 | 2019-02-11 03:18:14 HD Server | Thread:6508 (4) | Socket gracefully closed by remote side. | 2019-02-11 03:18:14 HD Server | Thread:6508 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-02-11 03:18:14 HD Server | Thread:6508 (4) | Closed. | 2019-02-11 03:18:14 HD Server | Server thread ending. Closing socket. | Username: Alan Sorrel. | Thread:6508 | 2019-02-11 03:18:14 HD Server Manager | Current server count=1 | 2019-02-11 03:18:14 HD Server | Server thread ending. Closing socket. | Username: Alan Sorrel. | Thread:6136 | 2019-02-11 03:18:14 HD Server Manager | Current server count=0 | 2019-02-11 03:18:14 DTCServer (3) | Creating socket. | 2019-02-11 03:33:06 DTCServer (3) | Connecting to IP: 0.0.0.0. | 2019-02-11 03:33:06 DTCServer (3) | Error connecting. Address Family: 2. IP: 0.0.0.0. Windows error code 10049: The requested address is not valid in its context. | 2019-02-11 03:33:06 * DTCServer (3) | Connect event error. Windows error code 10049: The requested address is not valid in its context. | 2019-02-11 03:33:06 * DTCServer (3) | Shutdown error. Windows error code 10057: A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied. | 2019-02-11 03:33:06 * DTCServer (3) | Shutdown started. Waiting for graceful close. | 2019-02-11 03:33:06 Deleting individual DTC server: DTC client #19. Sierra Chart. 127.0.0.1 | 2019-02-11 03:33:07 DTCServer (3) | Socket receive error. Windows error code 10057: A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied. | 2019-02-11 03:33:08 DTCServer (3) | Closed. | 2019-02-11 03:33:08 DTC Protocol server | Incoming connection from 127.0.0.1. | 2019-02-11 03:34:09 DTCServer (3) | Creating socket. | 2019-02-11 03:34:09 DTC client #20. 127.0.0.1 | Set DTC encoding to Binary VLS | 2019-02-11 03:34:09 DTC client #20. 127.0.0.1 | Requested heartbeat interval: 20 | 2019-02-11 03:34:09 DTC client #20. Sierra Chart. 127.0.0.1 | Received logon request. | 2019-02-11 03:34:09 DTC client #20. Sierra Chart. 127.0.0.1 | Sent successful Logon response message to client. Username: Alan Sorrel. Result text: Connected to SC DTC Protocol server. Service=cqgfix|SymbolSettings=cqg | 2019-02-11 03:34:09 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2019-02-11 03:34:13 HD Server Manager | Started new historical data server. Count=1 | 2019-02-11 03:34:13 HD Server | Thread:11104 (4) | Creating socket. | 2019-02-11 03:34:13 HD Server | Setting DTC encoding to Binary VLS | Thread:11104 | 2019-02-11 03:34:13 HD Server | Received login. Requesting authorization. | Username: Alan Sorrel. | Thread:11104 | 2019-02-11 03:34:13 HD Server | Login has been authorized. | Username: Alan Sorrel. | Thread:11104 | 2019-02-11 03:34:13 HD Server | HD Request #40 | Socket: 4 | Symbol: F.US.YMH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2019-02-11 06:17:23 | ClientRequestID: 40 | Username: Alan Sorrel. | Thread:11104 | 2019-02-11 03:34:13 HD Server | HD Request #40 | Socket: 4 | Symbol: F.US.YMH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 1 | ClientRequestID: 40 | Username: Alan Sorrel. | Thread:11104 | 2019-02-11 03:34:13 HD Server | Thread:11104 (4) | Socket gracefully closed by remote side. | 2019-02-11 03:34:13 HD Server | Thread:11104 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-02-11 03:34:13 HD Server | Thread:11104 (4) | Closed. | 2019-02-11 03:34:13 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2019-02-11 03:34:13 HD Server Manager | Started new historical data server. Count=2 | 2019-02-11 03:34:13 HD Server | Thread:7288 (4) | Creating socket. | 2019-02-11 03:34:13 HD Server | Setting DTC encoding to Binary VLS | Thread:7288 | 2019-02-11 03:34:13 HD Server | Received login. Requesting authorization. | Username: Alan Sorrel. | Thread:7288 | 2019-02-11 03:34:13 HD Server | Login has been authorized. | Username: Alan Sorrel. | Thread:7288 | 2019-02-11 03:34:13 HD Server | HD Request #41 | Socket: 4 | Symbol: F.US.ENQH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2019-02-11 10:33:04 | ClientRequestID: 41 | Username: Alan Sorrel. | Thread:7288 | 2019-02-11 03:34:13 HD Server | HD Request #41 | Socket: 4 | Symbol: F.US.ENQH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 66 | ClientRequestID: 41 | Username: Alan Sorrel. | Thread:7288 | 2019-02-11 03:34:13 HD Server | Thread:7288 (4) | Socket gracefully closed by remote side. | 2019-02-11 03:34:13 HD Server | Thread:7288 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-02-11 03:34:13 HD Server | Thread:7288 (4) | Closed. | 2019-02-11 03:34:13 HD Server | Server thread ending. Closing socket. | Username: Alan Sorrel. | Thread:7288 | 2019-02-11 03:34:13 HD Server Manager | Current server count=1 | 2019-02-11 03:34:13 HD Server | Server thread ending. Closing socket. | Username: Alan Sorrel. | Thread:11104 | 2019-02-11 03:34:13 HD Server Manager | Current server count=0 | 2019-02-11 03:34:13 DTC client #20. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.ENQH19 | 2019-02-11 03:34:14 DTC client #20. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.YMH19 | 2019-02-11 03:34:14 DTCServer (3) | Creating socket. | 2019-02-11 03:47:06 DTCServer (3) | Connecting to IP: 0.0.0.0. | 2019-02-11 03:47:06 DTCServer (3) | Error connecting. Address Family: 2. IP: 0.0.0.0. Windows error code 10049: The requested address is not valid in its context. | 2019-02-11 03:47:06 * DTCServer (3) | Connect event error. Windows error code 10049: The requested address is not valid in its context. | 2019-02-11 03:47:06 * DTCServer (3) | Shutdown error. Windows error code 10057: A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied. | 2019-02-11 03:47:06 * DTCServer (3) | Shutdown started. Waiting for graceful close. | 2019-02-11 03:47:06 Deleting individual DTC server: DTC client #20. Sierra Chart. 127.0.0.1 | 2019-02-11 03:47:07 DTCServer (3) | Socket receive error. Windows error code 10057: A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied. | 2019-02-11 03:47:09 DTCServer (3) | Closed. | 2019-02-11 03:47:09 DTC Protocol server | Incoming connection from 127.0.0.1. | 2019-02-11 03:48:08 DTCServer (3) | Creating socket. | 2019-02-11 03:48:08 DTC client #21. 127.0.0.1 | Set DTC encoding to Binary VLS | 2019-02-11 03:48:08 DTC client #21. 127.0.0.1 | Requested heartbeat interval: 20 | 2019-02-11 03:48:08 DTC client #21. Sierra Chart. 127.0.0.1 | Received logon request. | 2019-02-11 03:48:08 DTC client #21. Sierra Chart. 127.0.0.1 | Sent successful Logon response message to client. Username: Alan Sorrel. Result text: Connected to SC DTC Protocol server. Service=cqgfix|SymbolSettings=cqg | 2019-02-11 03:48:08 DTC client #21. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.ENQH19 | 2019-02-11 03:48:13 DTC client #21. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.YMH19 | 2019-02-11 03:48:13 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2019-02-11 03:48:14 HD Server Manager | Started new historical data server. Count=1 | 2019-02-11 03:48:14 HD Server | Thread:11912 (4) | Creating socket. | 2019-02-11 03:48:14 HD Server | Setting DTC encoding to Binary VLS | Thread:11912 | 2019-02-11 03:48:14 HD Server | Received login. Requesting authorization. | Username: Alan Sorrel. | Thread:11912 | 2019-02-11 03:48:14 HD Server | Login has been authorized. | Username: Alan Sorrel. | Thread:11912 | 2019-02-11 03:48:14 HD Server | HD Request #42 | Socket: 4 | Symbol: F.US.ENQH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2019-02-11 10:47:05 | ClientRequestID: 42 | Username: Alan Sorrel. | Thread:11912 | 2019-02-11 03:48:14 HD Server | HD Request #42 | Socket: 4 | Symbol: F.US.ENQH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 27 | ClientRequestID: 42 | Username: Alan Sorrel. | Thread:11912 | 2019-02-11 03:48:14 HD Server | Thread:11912 (4) | Socket gracefully closed by remote side. | 2019-02-11 03:48:14 HD Server | Thread:11912 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-02-11 03:48:14 HD Server | Thread:11912 (4) | Closed. | 2019-02-11 03:48:14 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2019-02-11 03:48:14 HD Server Manager | Started new historical data server. Count=2 | 2019-02-11 03:48:14 HD Server | Thread:6988 (4) | Creating socket. | 2019-02-11 03:48:14 HD Server | Setting DTC encoding to Binary VLS | Thread:6988 | 2019-02-11 03:48:14 HD Server | Received login. Requesting authorization. | Username: Alan Sorrel. | Thread:6988 | 2019-02-11 03:48:14 HD Server | Login has been authorized. | Username: Alan Sorrel. | Thread:6988 | 2019-02-11 03:48:14 HD Server | HD Request #43 | Socket: 4 | Symbol: F.US.YMH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2019-02-11 06:17:23 | ClientRequestID: 43 | Username: Alan Sorrel. | Thread:6988 | 2019-02-11 03:48:14 HD Server | HD Request #43 | Socket: 4 | Symbol: F.US.YMH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 1 | ClientRequestID: 43 | Username: Alan Sorrel. | Thread:6988 | 2019-02-11 03:48:14 HD Server | Thread:6988 (4) | Socket gracefully closed by remote side. | 2019-02-11 03:48:14 HD Server | Thread:6988 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-02-11 03:48:14 HD Server | Thread:6988 (4) | Closed. | 2019-02-11 03:48:14 HD Server | Server thread ending. Closing socket. | Username: Alan Sorrel. | Thread:6988 | 2019-02-11 03:48:14 HD Server Manager | Current server count=1 | 2019-02-11 03:48:14 HD Server | Server thread ending. Closing socket. | Username: Alan Sorrel. | Thread:11912 | 2019-02-11 03:48:14 HD Server Manager | Current server count=0 | 2019-02-11 03:48:14 DTCServer (3) | Creating socket. | 2019-02-11 03:49:06 DTCServer (3) | Connecting to IP: 0.0.0.0. | 2019-02-11 03:49:06 DTCServer (3) | Error connecting. Address Family: 2. IP: 0.0.0.0. Windows error code 10049: The requested address is not valid in its context. | 2019-02-11 03:49:06 * DTCServer (3) | Connect event error. Windows error code 10049: The requested address is not valid in its context. | 2019-02-11 03:49:06 * DTCServer (3) | Shutdown error. Windows error code 10057: A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied. | 2019-02-11 03:49:06 * DTCServer (3) | Shutdown started. Waiting for graceful close. | 2019-02-11 03:49:06 Deleting individual DTC server: DTC client #21. Sierra Chart. 127.0.0.1 | 2019-02-11 03:49:07 DTCServer (3) | Socket receive error. Windows error code 10057: A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied. | 2019-02-11 03:49:08 DTCServer (3) | Closed. | 2019-02-11 03:49:08 DTC Protocol server | Incoming connection from 127.0.0.1. | 2019-02-11 03:50:09 DTCServer (3) | Creating socket. | 2019-02-11 03:50:09 DTC client #22. 127.0.0.1 | Set DTC encoding to Binary VLS | 2019-02-11 03:50:09 DTC client #22. 127.0.0.1 | Requested heartbeat interval: 20 | 2019-02-11 03:50:09 DTC client #22. Sierra Chart. 127.0.0.1 | Received logon request. | 2019-02-11 03:50:09 DTC client #22. Sierra Chart. 127.0.0.1 | Sent successful Logon response message to client. Username: Alan Sorrel. Result text: Connected to SC DTC Protocol server. Service=cqgfix|SymbolSettings=cqg | 2019-02-11 03:50:09 DTC client #22. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.ENQH19 | 2019-02-11 03:50:14 DTC client #22. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.YMH19 | 2019-02-11 03:50:14 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2019-02-11 03:50:15 HD Server Manager | Started new historical data server. Count=1 | 2019-02-11 03:50:15 HD Server | Thread:8000 (4) | Creating socket. | 2019-02-11 03:50:15 HD Server | Setting DTC encoding to Binary VLS | Thread:8000 | 2019-02-11 03:50:15 HD Server | Received login. Requesting authorization. | Username: Alan Sorrel. | Thread:8000 | 2019-02-11 03:50:15 HD Server | Login has been authorized. | Username: Alan Sorrel. | Thread:8000 | 2019-02-11 03:50:15 HD Server | HD Request #44 | Socket: 4 | Symbol: F.US.ENQH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2019-02-11 10:49:06 | ClientRequestID: 44 | Username: Alan Sorrel. | Thread:8000 | 2019-02-11 03:50:15 HD Server | HD Request #44 | Socket: 4 | Symbol: F.US.ENQH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 62 | ClientRequestID: 44 | Username: Alan Sorrel. | Thread:8000 | 2019-02-11 03:50:15 HD Server | Thread:8000 (4) | Socket gracefully closed by remote side. | 2019-02-11 03:50:15 HD Server | Thread:8000 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-02-11 03:50:15 HD Server | Thread:8000 (4) | Closed. | 2019-02-11 03:50:15 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2019-02-11 03:50:15 HD Server Manager | Started new historical data server. Count=2 | 2019-02-11 03:50:15 HD Server | Thread:13152 (4) | Creating socket. | 2019-02-11 03:50:15 HD Server | Setting DTC encoding to Binary VLS | Thread:13152 | 2019-02-11 03:50:15 HD Server | Received login. Requesting authorization. | Username: Alan Sorrel. | Thread:13152 | 2019-02-11 03:50:15 HD Server | Login has been authorized. | Username: Alan Sorrel. | Thread:13152 | 2019-02-11 03:50:15 HD Server | HD Request #45 | Socket: 4 | Symbol: F.US.YMH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2019-02-11 06:17:23 | ClientRequestID: 45 | Username: Alan Sorrel. | Thread:13152 | 2019-02-11 03:50:15 HD Server | HD Request #45 | Socket: 4 | Symbol: F.US.YMH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 1 | ClientRequestID: 45 | Username: Alan Sorrel. | Thread:13152 | 2019-02-11 03:50:15 HD Server | Thread:13152 (4) | Socket gracefully closed by remote side. | 2019-02-11 03:50:15 HD Server | Thread:13152 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-02-11 03:50:15 HD Server | Thread:13152 (4) | Closed. | 2019-02-11 03:50:15 HD Server | Server thread ending. Closing socket. | Username: Alan Sorrel. | Thread:13152 | 2019-02-11 03:50:15 HD Server Manager | Current server count=1 | 2019-02-11 03:50:15 HD Server | Server thread ending. Closing socket. | Username: Alan Sorrel. | Thread:8000 | 2019-02-11 03:50:15 HD Server Manager | Current server count=0 | 2019-02-11 03:50:15 DTCServer (3) | Creating socket. | 2019-02-11 04:05:06 DTCServer (3) | Connecting to IP: 0.0.0.0. | 2019-02-11 04:05:06 DTCServer (3) | Error connecting. Address Family: 2. IP: 0.0.0.0. Windows error code 10049: The requested address is not valid in its context. | 2019-02-11 04:05:06 * DTCServer (3) | Connect event error. Windows error code 10049: The requested address is not valid in its context. | 2019-02-11 04:05:06 * DTCServer (3) | Shutdown error. Windows error code 10057: A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied. | 2019-02-11 04:05:06 * DTCServer (3) | Shutdown started. Waiting for graceful close. | 2019-02-11 04:05:06 Deleting individual DTC server: DTC client #22. Sierra Chart. 127.0.0.1 | 2019-02-11 04:05:07 DTCServer (3) | Socket receive error. Windows error code 10057: A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied. | 2019-02-11 04:05:09 DTCServer (3) | Closed. | 2019-02-11 04:05:09 DTC Protocol server | Incoming connection from 127.0.0.1. | 2019-02-11 04:06:10 DTCServer (3) | Creating socket. | 2019-02-11 04:06:10 DTC client #23. 127.0.0.1 | Set DTC encoding to Binary VLS | 2019-02-11 04:06:10 DTC client #23. 127.0.0.1 | Requested heartbeat interval: 20 | 2019-02-11 04:06:10 DTC client #23. Sierra Chart. 127.0.0.1 | Received logon request. | 2019-02-11 04:06:10 DTC client #23. Sierra Chart. 127.0.0.1 | Sent successful Logon response message to client. Username: Alan Sorrel. Result text: Connected to SC DTC Protocol server. Service=cqgfix|SymbolSettings=cqg | 2019-02-11 04:06:10 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2019-02-11 04:06:15 HD Server Manager | Started new historical data server. Count=1 | 2019-02-11 04:06:15 HD Server | Thread:6332 (4) | Creating socket. | 2019-02-11 04:06:15 HD Server | Setting DTC encoding to Binary VLS | Thread:6332 | 2019-02-11 04:06:15 HD Server | Received login. Requesting authorization. | Username: Alan Sorrel. | Thread:6332 | 2019-02-11 04:06:15 HD Server | Login has been authorized. | Username: Alan Sorrel. | Thread:6332 | 2019-02-11 04:06:15 HD Server | HD Request #46 | Socket: 4 | Symbol: F.US.ENQH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2019-02-11 11:05:06 | ClientRequestID: 46 | Username: Alan Sorrel. | Thread:6332 | 2019-02-11 04:06:15 HD Server | HD Request #46 | Socket: 4 | Symbol: F.US.ENQH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 42 | ClientRequestID: 46 | Username: Alan Sorrel. | Thread:6332 | 2019-02-11 04:06:15 HD Server | Thread:6332 (4) | Socket gracefully closed by remote side. | 2019-02-11 04:06:15 HD Server | Thread:6332 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-02-11 04:06:15 HD Server | Thread:6332 (4) | Closed. | 2019-02-11 04:06:15 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2019-02-11 04:06:15 HD Server Manager | Started new historical data server. Count=2 | 2019-02-11 04:06:15 HD Server | Thread:3140 (4) | Creating socket. | 2019-02-11 04:06:15 HD Server | Setting DTC encoding to Binary VLS | Thread:3140 | 2019-02-11 04:06:15 HD Server | Received login. Requesting authorization. | Username: Alan Sorrel. | Thread:3140 | 2019-02-11 04:06:15 HD Server | Login has been authorized. | Username: Alan Sorrel. | Thread:3140 | 2019-02-11 04:06:15 HD Server | HD Request #47 | Socket: 4 | Symbol: F.US.YMH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2019-02-11 06:17:23 | ClientRequestID: 47 | Username: Alan Sorrel. | Thread:3140 | 2019-02-11 04:06:15 HD Server | HD Request #47 | Socket: 4 | Symbol: F.US.YMH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 1 | ClientRequestID: 47 | Username: Alan Sorrel. | Thread:3140 | 2019-02-11 04:06:15 HD Server | Thread:3140 (4) | Socket gracefully closed by remote side. | 2019-02-11 04:06:15 HD Server | Thread:3140 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-02-11 04:06:15 HD Server | Thread:3140 (4) | Closed. | 2019-02-11 04:06:15 DTC client #23. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.ENQH19 | 2019-02-11 04:06:15 DTC client #23. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.YMH19 | 2019-02-11 04:06:15 HD Server | Server thread ending. Closing socket. | Username: Alan Sorrel. | Thread:3140 | 2019-02-11 04:06:15 HD Server Manager | Current server count=1 | 2019-02-11 04:06:15 HD Server | Server thread ending. Closing socket. | Username: Alan Sorrel. | Thread:6332 | 2019-02-11 04:06:15 HD Server Manager | Current server count=0 | 2019-02-11 04:06:15 DTCServer (3) | Creating socket. | 2019-02-11 04:21:06 DTCServer (3) | Connecting to IP: 0.0.0.0. | 2019-02-11 04:21:06 DTCServer (3) | Error connecting. Address Family: 2. IP: 0.0.0.0. Windows error code 10049: The requested address is not valid in its context. | 2019-02-11 04:21:06 * DTCServer (3) | Connect event error. Windows error code 10049: The requested address is not valid in its context. | 2019-02-11 04:21:06 * DTCServer (3) | Shutdown error. Windows error code 10057: A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied. | 2019-02-11 04:21:06 * DTCServer (3) | Shutdown started. Waiting for graceful close. | 2019-02-11 04:21:06 Deleting individual DTC server: DTC client #23. Sierra Chart. 127.0.0.1 | 2019-02-11 04:21:07 DTCServer (3) | Socket receive error. Windows error code 10057: A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied. | 2019-02-11 04:21:10 DTCServer (3) | Closed. | 2019-02-11 04:21:10 DTC Protocol server | Incoming connection from 127.0.0.1. | 2019-02-11 04:22:09 DTCServer (3) | Creating socket. | 2019-02-11 04:22:09 DTC client #24. 127.0.0.1 | Set DTC encoding to Binary VLS | 2019-02-11 04:22:09 DTC client #24. 127.0.0.1 | Requested heartbeat interval: 20 | 2019-02-11 04:22:09 DTC client #24. Sierra Chart. 127.0.0.1 | Received logon request. | 2019-02-11 04:22:09 DTC client #24. Sierra Chart. 127.0.0.1 | Sent successful Logon response message to client. Username: Alan Sorrel. Result text: Connected to SC DTC Protocol server. Service=cqgfix|SymbolSettings=cqg | 2019-02-11 04:22:09 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2019-02-11 04:22:14 HD Server Manager | Started new historical data server. Count=1 | 2019-02-11 04:22:14 HD Server | Thread:13248 (4) | Creating socket. | 2019-02-11 04:22:14 HD Server | Setting DTC encoding to Binary VLS | Thread:13248 | 2019-02-11 04:22:14 HD Server | Received login. Requesting authorization. | Username: Alan Sorrel. | Thread:13248 | 2019-02-11 04:22:14 HD Server | Login has been authorized. | Username: Alan Sorrel. | Thread:13248 | 2019-02-11 04:22:14 HD Server | HD Request #48 | Socket: 4 | Symbol: F.US.YMH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2019-02-11 06:17:23 | ClientRequestID: 48 | Username: Alan Sorrel. | Thread:13248 | 2019-02-11 04:22:14 HD Server | HD Request #48 | Socket: 4 | Symbol: F.US.YMH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 1 | ClientRequestID: 48 | Username: Alan Sorrel. | Thread:13248 | 2019-02-11 04:22:14 HD Server | Thread:13248 (4) | Socket gracefully closed by remote side. | 2019-02-11 04:22:14 HD Server | Thread:13248 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-02-11 04:22:14 HD Server | Thread:13248 (4) | Closed. | 2019-02-11 04:22:14 HD Server | Server thread ending. Closing socket. | Username: Alan Sorrel. | Thread:13248 | 2019-02-11 04:22:14 HD Server Manager | Current server count=0 | 2019-02-11 04:22:14 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2019-02-11 04:22:14 HD Server Manager | Started new historical data server. Count=1 | 2019-02-11 04:22:14 HD Server | Thread:12728 (4) | Creating socket. | 2019-02-11 04:22:14 HD Server | Setting DTC encoding to Binary VLS | Thread:12728 | 2019-02-11 04:22:14 HD Server | Received login. Requesting authorization. | Username: Alan Sorrel. | Thread:12728 | 2019-02-11 04:22:14 HD Server | Login has been authorized. | Username: Alan Sorrel. | Thread:12728 | 2019-02-11 04:22:14 HD Server | HD Request #49 | Socket: 4 | Symbol: F.US.ENQH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2019-02-11 11:21:06 | ClientRequestID: 49 | Username: Alan Sorrel. | Thread:12728 | 2019-02-11 04:22:14 HD Server | HD Request #49 | Socket: 4 | Symbol: F.US.ENQH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 101 | ClientRequestID: 49 | Username: Alan Sorrel. | Thread:12728 | 2019-02-11 04:22:14 HD Server | Thread:12728 (4) | Socket gracefully closed by remote side. | 2019-02-11 04:22:14 HD Server | Thread:12728 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-02-11 04:22:14 HD Server | Thread:12728 (4) | Closed. | 2019-02-11 04:22:14 DTC client #24. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.ENQH19 | 2019-02-11 04:22:14 DTC client #24. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.YMH19 | 2019-02-11 04:22:14 HD Server | Server thread ending. Closing socket. | Username: Alan Sorrel. | Thread:12728 | 2019-02-11 04:22:14 HD Server Manager | Current server count=0 | 2019-02-11 04:22:14 DTCServer (3) | Creating socket. | 2019-02-11 04:37:06 DTCServer (3) | Connecting to IP: 0.0.0.0. | 2019-02-11 04:37:06 DTCServer (3) | Error connecting. Address Family: 2. IP: 0.0.0.0. Windows error code 10049: The requested address is not valid in its context. | 2019-02-11 04:37:06 * DTCServer (3) | Connect event error. Windows error code 10049: The requested address is not valid in its context. | 2019-02-11 04:37:06 * DTCServer (3) | Shutdown error. Windows error code 10057: A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied. | 2019-02-11 04:37:06 * DTCServer (3) | Shutdown started. Waiting for graceful close. | 2019-02-11 04:37:06 Deleting individual DTC server: DTC client #24. Sierra Chart. 127.0.0.1 | 2019-02-11 04:37:07 DTCServer (3) | Socket receive error. Windows error code 10057: A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied. | 2019-02-11 04:37:09 DTCServer (3) | Closed. | 2019-02-11 04:37:09 DTC Protocol server | Incoming connection from 127.0.0.1. | 2019-02-11 04:38:09 DTCServer (3) | Creating socket. | 2019-02-11 04:38:09 DTC client #25. 127.0.0.1 | Set DTC encoding to Binary VLS | 2019-02-11 04:38:09 DTC client #25. 127.0.0.1 | Requested heartbeat interval: 20 | 2019-02-11 04:38:09 DTC client #25. Sierra Chart. 127.0.0.1 | Received logon request. | 2019-02-11 04:38:09 DTC client #25. Sierra Chart. 127.0.0.1 | Sent successful Logon response message to client. Username: Alan Sorrel. Result text: Connected to SC DTC Protocol server. Service=cqgfix|SymbolSettings=cqg | 2019-02-11 04:38:10 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2019-02-11 04:38:14 HD Server Manager | Started new historical data server. Count=1 | 2019-02-11 04:38:14 HD Server | Thread:7732 (4) | Creating socket. | 2019-02-11 04:38:14 HD Server | Setting DTC encoding to Binary VLS | Thread:7732 | 2019-02-11 04:38:14 HD Server | Received login. Requesting authorization. | Username: Alan Sorrel. | Thread:7732 | 2019-02-11 04:38:14 HD Server | Login has been authorized. | Username: Alan Sorrel. | Thread:7732 | 2019-02-11 04:38:14 HD Server | HD Request #50 | Socket: 4 | Symbol: F.US.YMH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2019-02-11 06:17:23 | ClientRequestID: 50 | Username: Alan Sorrel. | Thread:7732 | 2019-02-11 04:38:14 HD Server | HD Request #50 | Socket: 4 | Symbol: F.US.YMH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 1 | ClientRequestID: 50 | Username: Alan Sorrel. | Thread:7732 | 2019-02-11 04:38:14 HD Server | Thread:7732 (4) | Socket gracefully closed by remote side. | 2019-02-11 04:38:15 HD Server | Thread:7732 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-02-11 04:38:15 HD Server | Thread:7732 (4) | Closed. | 2019-02-11 04:38:15 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2019-02-11 04:38:15 HD Server Manager | Started new historical data server. Count=2 | 2019-02-11 04:38:15 HD Server | Thread:11064 (4) | Creating socket. | 2019-02-11 04:38:15 HD Server | Setting DTC encoding to Binary VLS | Thread:11064 | 2019-02-11 04:38:15 HD Server | Received login. Requesting authorization. | Username: Alan Sorrel. | Thread:11064 | 2019-02-11 04:38:15 HD Server | Login has been authorized. | Username: Alan Sorrel. | Thread:11064 | 2019-02-11 04:38:15 HD Server | HD Request #51 | Socket: 4 | Symbol: F.US.ENQH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2019-02-11 11:37:07 | ClientRequestID: 51 | Username: Alan Sorrel. | Thread:11064 | 2019-02-11 04:38:15 HD Server | HD Request #51 | Socket: 4 | Symbol: F.US.ENQH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 79 | ClientRequestID: 51 | Username: Alan Sorrel. | Thread:11064 | 2019-02-11 04:38:15 HD Server | Thread:11064 (4) | Socket gracefully closed by remote side. | 2019-02-11 04:38:15 HD Server | Thread:11064 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-02-11 04:38:15 HD Server | Thread:11064 (4) | Closed. | 2019-02-11 04:38:15 DTC client #25. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.ENQH19 | 2019-02-11 04:38:15 DTC client #25. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.YMH19 | 2019-02-11 04:38:15 HD Server | Server thread ending. Closing socket. | Username: Alan Sorrel. | Thread:11064 | 2019-02-11 04:38:15 HD Server Manager | Current server count=1 | 2019-02-11 04:38:15 HD Server | Server thread ending. Closing socket. | Username: Alan Sorrel. | Thread:7732 | 2019-02-11 04:38:15 HD Server Manager | Current server count=0 | 2019-02-11 04:38:15 DTCServer (3) | Creating socket. | 2019-02-11 04:53:06 DTCServer (3) | Connecting to IP: 0.0.0.0. | 2019-02-11 04:53:06 DTCServer (3) | Error connecting. Address Family: 2. IP: 0.0.0.0. Windows error code 10049: The requested address is not valid in its context. | 2019-02-11 04:53:06 * DTCServer (3) | Connect event error. Windows error code 10049: The requested address is not valid in its context. | 2019-02-11 04:53:06 * DTCServer (3) | Shutdown error. Windows error code 10057: A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied. | 2019-02-11 04:53:06 * DTCServer (3) | Shutdown started. Waiting for graceful close. | 2019-02-11 04:53:06 Deleting individual DTC server: DTC client #25. Sierra Chart. 127.0.0.1 | 2019-02-11 04:53:07 DTCServer (3) | Socket receive error. Windows error code 10057: A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied. | 2019-02-11 04:53:10 DTCServer (3) | Closed. | 2019-02-11 04:53:10 DTC Protocol server | Incoming connection from 127.0.0.1. | 2019-02-11 04:54:09 DTCServer (3) | Creating socket. | 2019-02-11 04:54:09 DTC client #26. 127.0.0.1 | Set DTC encoding to Binary VLS | 2019-02-11 04:54:09 DTC client #26. 127.0.0.1 | Requested heartbeat interval: 20 | 2019-02-11 04:54:09 DTC client #26. Sierra Chart. 127.0.0.1 | Received logon request. | 2019-02-11 04:54:09 DTC client #26. Sierra Chart. 127.0.0.1 | Sent successful Logon response message to client. Username: Alan Sorrel. Result text: Connected to SC DTC Protocol server. Service=cqgfix|SymbolSettings=cqg | 2019-02-11 04:54:09 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2019-02-11 04:54:14 HD Server Manager | Started new historical data server. Count=1 | 2019-02-11 04:54:14 HD Server | Thread:11800 (4) | Creating socket. | 2019-02-11 04:54:14 HD Server | Setting DTC encoding to Binary VLS | Thread:11800 | 2019-02-11 04:54:14 HD Server | Received login. Requesting authorization. | Username: Alan Sorrel. | Thread:11800 | 2019-02-11 04:54:14 HD Server | Login has been authorized. | Username: Alan Sorrel. | Thread:11800 | 2019-02-11 04:54:14 HD Server | HD Request #52 | Socket: 4 | Symbol: F.US.ENQH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2019-02-11 11:53:01 | ClientRequestID: 52 | Username: Alan Sorrel. | Thread:11800 | 2019-02-11 04:54:14 HD Server | HD Request #52 | Socket: 4 | Symbol: F.US.ENQH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 86 | ClientRequestID: 52 | Username: Alan Sorrel. | Thread:11800 | 2019-02-11 04:54:14 HD Server | Thread:11800 (4) | Socket gracefully closed by remote side. | 2019-02-11 04:54:14 HD Server | Thread:11800 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-02-11 04:54:14 HD Server | Thread:11800 (4) | Closed. | 2019-02-11 04:54:14 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2019-02-11 04:54:14 HD Server Manager | Started new historical data server. Count=2 | 2019-02-11 04:54:14 HD Server | Thread:3360 (4) | Creating socket. | 2019-02-11 04:54:14 HD Server | Setting DTC encoding to Binary VLS | Thread:3360 | 2019-02-11 04:54:14 HD Server | Received login. Requesting authorization. | Username: Alan Sorrel. | Thread:3360 | 2019-02-11 04:54:14 HD Server | Login has been authorized. | Username: Alan Sorrel. | Thread:3360 | 2019-02-11 04:54:14 HD Server | HD Request #53 | Socket: 4 | Symbol: F.US.YMH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2019-02-11 06:17:23 | ClientRequestID: 53 | Username: Alan Sorrel. | Thread:3360 | 2019-02-11 04:54:14 HD Server | HD Request #53 | Socket: 4 | Symbol: F.US.YMH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 1 | ClientRequestID: 53 | Username: Alan Sorrel. | Thread:3360 | 2019-02-11 04:54:14 HD Server | Thread:3360 (4) | Socket gracefully closed by remote side. | 2019-02-11 04:54:14 HD Server | Thread:3360 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-02-11 04:54:14 HD Server | Thread:3360 (4) | Closed. | 2019-02-11 04:54:14 DTC client #26. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.ENQH19 | 2019-02-11 04:54:14 DTC client #26. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.YMH19 | 2019-02-11 04:54:14 HD Server | Server thread ending. Closing socket. | Username: Alan Sorrel. | Thread:3360 | 2019-02-11 04:54:14 HD Server Manager | Current server count=1 | 2019-02-11 04:54:14 HD Server | Server thread ending. Closing socket. | Username: Alan Sorrel. | Thread:11800 | 2019-02-11 04:54:14 HD Server Manager | Current server count=0 | 2019-02-11 04:54:14 DTCServer (3) | Creating socket. | 2019-02-11 05:09:06 DTCServer (3) | Connecting to IP: 0.0.0.0. | 2019-02-11 05:09:06 DTCServer (3) | Error connecting. Address Family: 2. IP: 0.0.0.0. Windows error code 10049: The requested address is not valid in its context. | 2019-02-11 05:09:06 * DTCServer (3) | Connect event error. Windows error code 10049: The requested address is not valid in its context. | 2019-02-11 05:09:06 * DTCServer (3) | Shutdown error. Windows error code 10057: A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied. | 2019-02-11 05:09:06 * DTCServer (3) | Shutdown started. Waiting for graceful close. | 2019-02-11 05:09:06 Deleting individual DTC server: DTC client #26. Sierra Chart. 127.0.0.1 | 2019-02-11 05:09:07 DTCServer (3) | Socket receive error. Windows error code 10057: A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied. | 2019-02-11 05:09:09 DTCServer (3) | Closed. | 2019-02-11 05:09:09 DTC Protocol server | Incoming connection from 127.0.0.1. | 2019-02-11 05:10:08 DTCServer (3) | Creating socket. | 2019-02-11 05:10:08 DTC client #27. 127.0.0.1 | Set DTC encoding to Binary VLS | 2019-02-11 05:10:08 DTC client #27. 127.0.0.1 | Requested heartbeat interval: 20 | 2019-02-11 05:10:08 DTC client #27. Sierra Chart. 127.0.0.1 | Received logon request. | 2019-02-11 05:10:08 DTC client #27. Sierra Chart. 127.0.0.1 | Sent successful Logon response message to client. Username: Alan Sorrel. Result text: Connected to SC DTC Protocol server. Service=cqgfix|SymbolSettings=cqg | 2019-02-11 05:10:08 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2019-02-11 05:10:13 HD Server Manager | Started new historical data server. Count=1 | 2019-02-11 05:10:13 HD Server | Thread:10536 (4) | Creating socket. | 2019-02-11 05:10:13 HD Server | Setting DTC encoding to Binary VLS | Thread:10536 | 2019-02-11 05:10:13 HD Server | Received login. Requesting authorization. | Username: Alan Sorrel. | Thread:10536 | 2019-02-11 05:10:13 HD Server | Login has been authorized. | Username: Alan Sorrel. | Thread:10536 | 2019-02-11 05:10:13 HD Server | HD Request #54 | Socket: 4 | Symbol: F.US.YMH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2019-02-11 06:17:23 | ClientRequestID: 54 | Username: Alan Sorrel. | Thread:10536 | 2019-02-11 05:10:13 HD Server | HD Request #54 | Socket: 4 | Symbol: F.US.YMH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 1 | ClientRequestID: 54 | Username: Alan Sorrel. | Thread:10536 | 2019-02-11 05:10:13 HD Server | Thread:10536 (4) | Socket gracefully closed by remote side. | 2019-02-11 05:10:13 HD Server | Thread:10536 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-02-11 05:10:13 HD Server | Thread:10536 (4) | Closed. | 2019-02-11 05:10:13 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2019-02-11 05:10:13 HD Server Manager | Started new historical data server. Count=2 | 2019-02-11 05:10:13 HD Server | Thread:4952 (4) | Creating socket. | 2019-02-11 05:10:13 HD Server | Setting DTC encoding to Binary VLS | Thread:4952 | 2019-02-11 05:10:13 HD Server | Received login. Requesting authorization. | Username: Alan Sorrel. | Thread:4952 | 2019-02-11 05:10:13 HD Server | Login has been authorized. | Username: Alan Sorrel. | Thread:4952 | 2019-02-11 05:10:13 HD Server | HD Request #55 | Socket: 4 | Symbol: F.US.ENQH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2019-02-11 12:09:04 | ClientRequestID: 55 | Username: Alan Sorrel. | Thread:4952 | 2019-02-11 05:10:13 HD Server | HD Request #55 | Socket: 4 | Symbol: F.US.ENQH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 127 | ClientRequestID: 55 | Username: Alan Sorrel. | Thread:4952 | 2019-02-11 05:10:13 HD Server | Thread:4952 (4) | Socket gracefully closed by remote side. | 2019-02-11 05:10:13 HD Server | Thread:4952 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-02-11 05:10:13 HD Server | Thread:4952 (4) | Closed. | 2019-02-11 05:10:13 HD Server | Server thread ending. Closing socket. | Username: Alan Sorrel. | Thread:4952 | 2019-02-11 05:10:13 HD Server Manager | Current server count=1 | 2019-02-11 05:10:13 HD Server | Server thread ending. Closing socket. | Username: Alan Sorrel. | Thread:10536 | 2019-02-11 05:10:13 HD Server Manager | Current server count=0 | 2019-02-11 05:10:13 DTC client #27. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.ENQH19 | 2019-02-11 05:10:13 DTC client #27. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.YMH19 | 2019-02-11 05:10:13 DTCServer (3) | Creating socket. | 2019-02-11 05:17:06 DTCServer (3) | Connecting to IP: 0.0.0.0. | 2019-02-11 05:17:06 DTCServer (3) | Error connecting. Address Family: 2. IP: 0.0.0.0. Windows error code 10049: The requested address is not valid in its context. | 2019-02-11 05:17:06 * DTCServer (3) | Connect event error. Windows error code 10049: The requested address is not valid in its context. | 2019-02-11 05:17:06 * DTCServer (3) | Shutdown error. Windows error code 10057: A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied. | 2019-02-11 05:17:06 * DTCServer (3) | Shutdown started. Waiting for graceful close. | 2019-02-11 05:17:06 Deleting individual DTC server: DTC client #27. Sierra Chart. 127.0.0.1 | 2019-02-11 05:17:07 DTCServer (3) | Socket receive error. Windows error code 10057: A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied. | 2019-02-11 05:17:08 DTCServer (3) | Closed. | 2019-02-11 05:17:08 DTC Protocol server | Incoming connection from 127.0.0.1. | 2019-02-11 05:18:09 DTCServer (3) | Creating socket. | 2019-02-11 05:18:09 DTC client #28. 127.0.0.1 | Set DTC encoding to Binary VLS | 2019-02-11 05:18:09 DTC client #28. 127.0.0.1 | Requested heartbeat interval: 20 | 2019-02-11 05:18:09 DTC client #28. Sierra Chart. 127.0.0.1 | Received logon request. | 2019-02-11 05:18:09 DTC client #28. Sierra Chart. 127.0.0.1 | Sent successful Logon response message to client. Username: Alan Sorrel. Result text: Connected to SC DTC Protocol server. Service=cqgfix|SymbolSettings=cqg | 2019-02-11 05:18:09 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2019-02-11 05:18:14 HD Server Manager | Started new historical data server. Count=1 | 2019-02-11 05:18:14 HD Server | Thread:8112 (4) | Creating socket. | 2019-02-11 05:18:14 HD Server | Setting DTC encoding to Binary VLS | Thread:8112 | 2019-02-11 05:18:14 HD Server | Received login. Requesting authorization. | Username: Alan Sorrel. | Thread:8112 | 2019-02-11 05:18:14 HD Server | Login has been authorized. | Username: Alan Sorrel. | Thread:8112 | 2019-02-11 05:18:14 HD Server | HD Request #56 | Socket: 4 | Symbol: F.US.ENQH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2019-02-11 12:17:04 | ClientRequestID: 56 | Username: Alan Sorrel. | Thread:8112 | 2019-02-11 05:18:14 HD Server | HD Request #56 | Socket: 4 | Symbol: F.US.ENQH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 202 | ClientRequestID: 56 | Username: Alan Sorrel. | Thread:8112 | 2019-02-11 05:18:14 HD Server | Thread:8112 (4) | Socket gracefully closed by remote side. | 2019-02-11 05:18:14 HD Server | Thread:8112 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-02-11 05:18:14 HD Server | Thread:8112 (4) | Closed. | 2019-02-11 05:18:14 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2019-02-11 05:18:14 HD Server Manager | Started new historical data server. Count=2 | 2019-02-11 05:18:14 HD Server | Thread:12780 (4) | Creating socket. | 2019-02-11 05:18:14 HD Server | Setting DTC encoding to Binary VLS | Thread:12780 | 2019-02-11 05:18:14 HD Server | Received login. Requesting authorization. | Username: Alan Sorrel. | Thread:12780 | 2019-02-11 05:18:14 HD Server | Login has been authorized. | Username: Alan Sorrel. | Thread:12780 | 2019-02-11 05:18:14 HD Server | HD Request #57 | Socket: 4 | Symbol: F.US.YMH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2019-02-11 06:17:23 | ClientRequestID: 57 | Username: Alan Sorrel. | Thread:12780 | 2019-02-11 05:18:14 HD Server | HD Request #57 | Socket: 4 | Symbol: F.US.YMH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 1 | ClientRequestID: 57 | Username: Alan Sorrel. | Thread:12780 | 2019-02-11 05:18:14 HD Server | Thread:12780 (4) | Socket gracefully closed by remote side. | 2019-02-11 05:18:14 HD Server | Thread:12780 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-02-11 05:18:14 HD Server | Thread:12780 (4) | Closed. | 2019-02-11 05:18:14 HD Server | Server thread ending. Closing socket. | Username: Alan Sorrel. | Thread:12780 | 2019-02-11 05:18:14 HD Server Manager | Current server count=1 | 2019-02-11 05:18:14 HD Server | Server thread ending. Closing socket. | Username: Alan Sorrel. | Thread:8112 | 2019-02-11 05:18:14 HD Server Manager | Current server count=0 | 2019-02-11 05:18:14 DTC client #28. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.ENQH19 | 2019-02-11 05:18:14 DTC client #28. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.YMH19 | 2019-02-11 05:18:14 DTCServer (3) | Creating socket. | 2019-02-11 05:25:06 DTCServer (3) | Connecting to IP: 0.0.0.0. | 2019-02-11 05:25:06 DTCServer (3) | Error connecting. Address Family: 2. IP: 0.0.0.0. Windows error code 10049: The requested address is not valid in its context. | 2019-02-11 05:25:06 * DTCServer (3) | Connect event error. Windows error code 10049: The requested address is not valid in its context. | 2019-02-11 05:25:06 * DTCServer (3) | Shutdown error. Windows error code 10057: A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied. | 2019-02-11 05:25:06 * DTCServer (3) | Shutdown started. Waiting for graceful close. | 2019-02-11 05:25:06 Deleting individual DTC server: DTC client #28. Sierra Chart. 127.0.0.1 | 2019-02-11 05:25:07 DTCServer (3) | Socket receive error. Windows error code 10057: A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied. | 2019-02-11 05:25:09 DTCServer (3) | Closed. | 2019-02-11 05:25:09 DTC Protocol server | Incoming connection from 127.0.0.1. | 2019-02-11 05:26:10 DTCServer (3) | Creating socket. | 2019-02-11 05:26:10 DTC client #29. 127.0.0.1 | Set DTC encoding to Binary VLS | 2019-02-11 05:26:10 DTC client #29. 127.0.0.1 | Requested heartbeat interval: 20 | 2019-02-11 05:26:10 DTC client #29. Sierra Chart. 127.0.0.1 | Received logon request. | 2019-02-11 05:26:10 DTC client #29. Sierra Chart. 127.0.0.1 | Sent successful Logon response message to client. Username: Alan Sorrel. Result text: Connected to SC DTC Protocol server. Service=cqgfix|SymbolSettings=cqg | 2019-02-11 05:26:10 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2019-02-11 05:26:15 HD Server Manager | Started new historical data server. Count=1 | 2019-02-11 05:26:15 HD Server | Thread:4644 (4) | Creating socket. | 2019-02-11 05:26:15 HD Server | Setting DTC encoding to Binary VLS | Thread:4644 | 2019-02-11 05:26:15 HD Server | Received login. Requesting authorization. | Username: Alan Sorrel. | Thread:4644 | 2019-02-11 05:26:15 HD Server | Login has been authorized. | Username: Alan Sorrel. | Thread:4644 | 2019-02-11 05:26:15 HD Server | HD Request #58 | Socket: 4 | Symbol: F.US.YMH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2019-02-11 06:17:23 | ClientRequestID: 58 | Username: Alan Sorrel. | Thread:4644 | 2019-02-11 05:26:15 HD Server | HD Request #58 | Socket: 4 | Symbol: F.US.YMH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 1 | ClientRequestID: 58 | Username: Alan Sorrel. | Thread:4644 | 2019-02-11 05:26:15 HD Server | Thread:4644 (4) | Socket gracefully closed by remote side. | 2019-02-11 05:26:15 HD Server | Thread:4644 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-02-11 05:26:15 HD Server | Thread:4644 (4) | Closed. | 2019-02-11 05:26:15 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2019-02-11 05:26:15 HD Server Manager | Started new historical data server. Count=2 | 2019-02-11 05:26:15 HD Server | Thread:1248 (4) | Creating socket. | 2019-02-11 05:26:15 HD Server | Setting DTC encoding to Binary VLS | Thread:1248 | 2019-02-11 05:26:15 HD Server | Received login. Requesting authorization. | Username: Alan Sorrel. | Thread:1248 | 2019-02-11 05:26:15 HD Server | Login has been authorized. | Username: Alan Sorrel. | Thread:1248 | 2019-02-11 05:26:15 HD Server | HD Request #59 | Socket: 4 | Symbol: F.US.ENQH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2019-02-11 12:24:56 | ClientRequestID: 59 | Username: Alan Sorrel. | Thread:1248 | 2019-02-11 05:26:15 HD Server | HD Request #59 | Socket: 4 | Symbol: F.US.ENQH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 56 | ClientRequestID: 59 | Username: Alan Sorrel. | Thread:1248 | 2019-02-11 05:26:15 HD Server | Thread:1248 (4) | Socket gracefully closed by remote side. | 2019-02-11 05:26:15 HD Server | Thread:1248 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-02-11 05:26:15 HD Server | Thread:1248 (4) | Closed. | 2019-02-11 05:26:15 HD Server | Server thread ending. Closing socket. | Username: Alan Sorrel. | Thread:1248 | 2019-02-11 05:26:15 HD Server Manager | Current server count=1 | 2019-02-11 05:26:15 HD Server | Server thread ending. Closing socket. | Username: Alan Sorrel. | Thread:4644 | 2019-02-11 05:26:15 HD Server Manager | Current server count=0 | 2019-02-11 05:26:15 DTC client #29. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.ENQH19 | 2019-02-11 05:26:15 DTC client #29. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.YMH19 | 2019-02-11 05:26:15 DTCServer (3) | Creating socket. | 2019-02-11 05:41:06 DTCServer (3) | Connecting to IP: 0.0.0.0. | 2019-02-11 05:41:06 DTCServer (3) | Error connecting. Address Family: 2. IP: 0.0.0.0. Windows error code 10049: The requested address is not valid in its context. | 2019-02-11 05:41:06 * DTCServer (3) | Connect event error. Windows error code 10049: The requested address is not valid in its context. | 2019-02-11 05:41:06 * DTCServer (3) | Shutdown error. Windows error code 10057: A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied. | 2019-02-11 05:41:07 * DTCServer (3) | Shutdown started. Waiting for graceful close. | 2019-02-11 05:41:07 Deleting individual DTC server: DTC client #29. Sierra Chart. 127.0.0.1 | 2019-02-11 05:41:07 DTCServer (3) | Socket receive error. Windows error code 10057: A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied. | 2019-02-11 05:41:10 DTCServer (3) | Closed. | 2019-02-11 05:41:10 DTC Protocol server | Incoming connection from 127.0.0.1. | 2019-02-11 05:42:10 DTCServer (3) | Creating socket. | 2019-02-11 05:42:10 DTC client #30. 127.0.0.1 | Set DTC encoding to Binary VLS | 2019-02-11 05:42:10 DTC client #30. 127.0.0.1 | Requested heartbeat interval: 20 | 2019-02-11 05:42:10 DTC client #30. Sierra Chart. 127.0.0.1 | Received logon request. | 2019-02-11 05:42:10 DTC client #30. Sierra Chart. 127.0.0.1 | Sent successful Logon response message to client. Username: Alan Sorrel. Result text: Connected to SC DTC Protocol server. Service=cqgfix|SymbolSettings=cqg | 2019-02-11 05:42:10 DTC client #30. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.ENQH19 | 2019-02-11 05:42:15 DTC client #30. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.YMH19 | 2019-02-11 05:42:15 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2019-02-11 05:42:16 HD Server Manager | Started new historical data server. Count=1 | 2019-02-11 05:42:16 HD Server | Thread:8744 (4) | Creating socket. | 2019-02-11 05:42:16 HD Server | Setting DTC encoding to Binary VLS | Thread:8744 | 2019-02-11 05:42:16 HD Server | Received login. Requesting authorization. | Username: Alan Sorrel. | Thread:8744 | 2019-02-11 05:42:16 HD Server | Login has been authorized. | Username: Alan Sorrel. | Thread:8744 | 2019-02-11 05:42:16 HD Server | HD Request #60 | Socket: 4 | Symbol: F.US.YMH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2019-02-11 06:17:23 | ClientRequestID: 60 | Username: Alan Sorrel. | Thread:8744 | 2019-02-11 05:42:16 HD Server | HD Request #60 | Socket: 4 | Symbol: F.US.YMH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 1 | ClientRequestID: 60 | Username: Alan Sorrel. | Thread:8744 | 2019-02-11 05:42:16 HD Server | Thread:8744 (4) | Socket gracefully closed by remote side. | 2019-02-11 05:42:16 HD Server | Thread:8744 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-02-11 05:42:16 HD Server | Thread:8744 (4) | Closed. | 2019-02-11 05:42:16 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2019-02-11 05:42:16 HD Server Manager | Started new historical data server. Count=2 | 2019-02-11 05:42:16 HD Server | Thread:10752 (4) | Creating socket. | 2019-02-11 05:42:16 HD Server | Setting DTC encoding to Binary VLS | Thread:10752 | 2019-02-11 05:42:16 HD Server | Received login. Requesting authorization. | Username: Alan Sorrel. | Thread:10752 | 2019-02-11 05:42:16 HD Server | Login has been authorized. | Username: Alan Sorrel. | Thread:10752 | 2019-02-11 05:42:16 HD Server | HD Request #61 | Socket: 4 | Symbol: F.US.ENQH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2019-02-11 12:41:05 | ClientRequestID: 61 | Username: Alan Sorrel. | Thread:10752 | 2019-02-11 05:42:16 HD Server | HD Request #61 | Socket: 4 | Symbol: F.US.ENQH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 33 | ClientRequestID: 61 | Username: Alan Sorrel. | Thread:10752 | 2019-02-11 05:42:16 HD Server | Thread:10752 (4) | Socket gracefully closed by remote side. | 2019-02-11 05:42:16 HD Server | Thread:10752 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-02-11 05:42:16 HD Server | Thread:10752 (4) | Closed. | 2019-02-11 05:42:16 HD Server | Server thread ending. Closing socket. | Username: Alan Sorrel. | Thread:10752 | 2019-02-11 05:42:16 HD Server Manager | Current server count=1 | 2019-02-11 05:42:16 HD Server | Server thread ending. Closing socket. | Username: Alan Sorrel. | Thread:8744 | 2019-02-11 05:42:16 HD Server Manager | Current server count=0 | 2019-02-11 05:42:16 DTCServer (3) | Creating socket. | 2019-02-11 05:57:06 DTCServer (3) | Connecting to IP: 0.0.0.0. | 2019-02-11 05:57:06 DTCServer (3) | Error connecting. Address Family: 2. IP: 0.0.0.0. Windows error code 10049: The requested address is not valid in its context. | 2019-02-11 05:57:06 * DTCServer (3) | Connect event error. Windows error code 10049: The requested address is not valid in its context. | 2019-02-11 05:57:06 * DTCServer (3) | Shutdown error. Windows error code 10057: A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied. | 2019-02-11 05:57:06 * DTCServer (3) | Shutdown started. Waiting for graceful close. | 2019-02-11 05:57:06 Deleting individual DTC server: DTC client #30. Sierra Chart. 127.0.0.1 | 2019-02-11 05:57:07 DTCServer (3) | Socket receive error. Windows error code 10057: A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied. | 2019-02-11 05:57:10 DTCServer (3) | Closed. | 2019-02-11 05:57:10 DTC Protocol server | Incoming connection from 127.0.0.1. | 2019-02-11 05:58:07 DTCServer (4) | Creating socket. | 2019-02-11 05:58:07 DTC client #31. 127.0.0.1 | Set DTC encoding to Binary VLS | 2019-02-11 05:58:07 DTC client #31. 127.0.0.1 | Requested heartbeat interval: 20 | 2019-02-11 05:58:07 DTC client #31. Sierra Chart. 127.0.0.1 | Received logon request. | 2019-02-11 05:58:07 DTC client #31. Sierra Chart. 127.0.0.1 | Sent successful Logon response message to client. Username: Alan Sorrel. Result text: Connected to SC DTC Protocol server. Service=cqgfix|SymbolSettings=cqg | 2019-02-11 05:58:07 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2019-02-11 05:58:11 HD Server Manager | Started new historical data server. Count=1 | 2019-02-11 05:58:11 HD Server | Thread:6744 (3) | Creating socket. | 2019-02-11 05:58:11 HD Server | Setting DTC encoding to Binary VLS | Thread:6744 | 2019-02-11 05:58:11 HD Server | Received login. Requesting authorization. | Username: Alan Sorrel. | Thread:6744 | 2019-02-11 05:58:11 HD Server | Login has been authorized. | Username: Alan Sorrel. | Thread:6744 | 2019-02-11 05:58:11 HD Server | HD Request #62 | Socket: 3 | Symbol: F.US.YMH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2019-02-11 06:17:23 | ClientRequestID: 62 | Username: Alan Sorrel. | Thread:6744 | 2019-02-11 05:58:11 HD Server | HD Request #62 | Socket: 3 | Symbol: F.US.YMH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 1 | ClientRequestID: 62 | Username: Alan Sorrel. | Thread:6744 | 2019-02-11 05:58:11 HD Server | Thread:6744 (3) | Socket gracefully closed by remote side. | 2019-02-11 05:58:11 HD Server | Thread:6744 (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-02-11 05:58:11 HD Server | Thread:6744 (3) | Closed. | 2019-02-11 05:58:11 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2019-02-11 05:58:11 HD Server Manager | Started new historical data server. Count=2 | 2019-02-11 05:58:11 HD Server | Thread:2168 (3) | Creating socket. | 2019-02-11 05:58:11 HD Server | Setting DTC encoding to Binary VLS | Thread:2168 | 2019-02-11 05:58:11 HD Server | Received login. Requesting authorization. | Username: Alan Sorrel. | Thread:2168 | 2019-02-11 05:58:11 HD Server | Login has been authorized. | Username: Alan Sorrel. | Thread:2168 | 2019-02-11 05:58:11 HD Server | HD Request #63 | Socket: 3 | Symbol: F.US.ENQH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2019-02-11 12:56:59 | ClientRequestID: 63 | Username: Alan Sorrel. | Thread:2168 | 2019-02-11 05:58:11 HD Server | HD Request #63 | Socket: 3 | Symbol: F.US.ENQH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 145 | ClientRequestID: 63 | Username: Alan Sorrel. | Thread:2168 | 2019-02-11 05:58:11 HD Server | Thread:2168 (3) | Socket gracefully closed by remote side. | 2019-02-11 05:58:11 HD Server | Thread:2168 (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-02-11 05:58:11 HD Server | Thread:2168 (3) | Closed. | 2019-02-11 05:58:11 HD Server | Server thread ending. Closing socket. | Username: Alan Sorrel. | Thread:2168 | 2019-02-11 05:58:11 HD Server Manager | Current server count=1 | 2019-02-11 05:58:11 HD Server | Server thread ending. Closing socket. | Username: Alan Sorrel. | Thread:6744 | 2019-02-11 05:58:11 HD Server Manager | Current server count=0 | 2019-02-11 05:58:11 DTC client #31. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.ENQH19 | 2019-02-11 05:58:12 DTC client #31. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.YMH19 | 2019-02-11 05:58:12 DTCServer (4) | Creating socket. | 2019-02-11 06:13:07 DTCServer (4) | Connecting to IP: 0.0.0.0. | 2019-02-11 06:13:07 DTCServer (4) | Error connecting. Address Family: 2. IP: 0.0.0.0. Windows error code 10049: The requested address is not valid in its context. | 2019-02-11 06:13:07 * DTCServer (4) | Connect event error. Windows error code 10049: The requested address is not valid in its context. | 2019-02-11 06:13:07 * DTCServer (4) | Shutdown error. Windows error code 10057: A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied. | 2019-02-11 06:13:07 * DTCServer (4) | Shutdown started. Waiting for graceful close. | 2019-02-11 06:13:07 DTCServer (4) | Socket receive error. Windows error code 10057: A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied. | 2019-02-11 06:13:07 DTCServer (4) | Closed. | 2019-02-11 06:13:07 Deleting individual DTC server: DTC client #31. Sierra Chart. 127.0.0.1 | 2019-02-11 06:13:07 DTC Protocol server | Incoming connection from 127.0.0.1. | 2019-02-11 06:14:10 DTCServer (3) | Creating socket. | 2019-02-11 06:14:10 DTC client #32. 127.0.0.1 | Set DTC encoding to Binary VLS | 2019-02-11 06:14:10 DTC client #32. 127.0.0.1 | Requested heartbeat interval: 20 | 2019-02-11 06:14:10 DTC client #32. Sierra Chart. 127.0.0.1 | Received logon request. | 2019-02-11 06:14:10 DTC client #32. Sierra Chart. 127.0.0.1 | Sent successful Logon response message to client. Username: Alan Sorrel. Result text: Connected to SC DTC Protocol server. Service=cqgfix|SymbolSettings=cqg | 2019-02-11 06:14:10 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2019-02-11 06:14:15 HD Server Manager | Started new historical data server. Count=1 | 2019-02-11 06:14:15 HD Server | Thread:11932 (4) | Creating socket. | 2019-02-11 06:14:15 HD Server | Setting DTC encoding to Binary VLS | Thread:11932 | 2019-02-11 06:14:15 HD Server | Received login. Requesting authorization. | Username: Alan Sorrel. | Thread:11932 | 2019-02-11 06:14:15 HD Server | Login has been authorized. | Username: Alan Sorrel. | Thread:11932 | 2019-02-11 06:14:15 HD Server | HD Request #64 | Socket: 4 | Symbol: F.US.YMH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2019-02-11 06:17:23 | ClientRequestID: 64 | Username: Alan Sorrel. | Thread:11932 | 2019-02-11 06:14:15 HD Server | HD Request #64 | Socket: 4 | Symbol: F.US.YMH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 1 | ClientRequestID: 64 | Username: Alan Sorrel. | Thread:11932 | 2019-02-11 06:14:15 HD Server | Thread:11932 (4) | Socket gracefully closed by remote side. | 2019-02-11 06:14:15 HD Server | Thread:11932 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-02-11 06:14:15 HD Server | Thread:11932 (4) | Closed. | 2019-02-11 06:14:15 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2019-02-11 06:14:15 HD Server Manager | Started new historical data server. Count=2 | 2019-02-11 06:14:15 HD Server | Thread:6884 (4) | Creating socket. | 2019-02-11 06:14:15 HD Server | Setting DTC encoding to Binary VLS | Thread:6884 | 2019-02-11 06:14:15 HD Server | Received login. Requesting authorization. | Username: Alan Sorrel. | Thread:6884 | 2019-02-11 06:14:15 HD Server | Login has been authorized. | Username: Alan Sorrel. | Thread:6884 | 2019-02-11 06:14:15 HD Server | HD Request #65 | Socket: 4 | Symbol: F.US.ENQH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2019-02-11 13:13:07 | ClientRequestID: 65 | Username: Alan Sorrel. | Thread:6884 | 2019-02-11 06:14:15 HD Server | HD Request #65 | Socket: 4 | Symbol: F.US.ENQH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 72 | ClientRequestID: 65 | Username: Alan Sorrel. | Thread:6884 | 2019-02-11 06:14:15 HD Server | Thread:6884 (4) | Socket gracefully closed by remote side. | 2019-02-11 06:14:15 HD Server | Thread:6884 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-02-11 06:14:15 HD Server | Thread:6884 (4) | Closed. | 2019-02-11 06:14:15 DTC client #32. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.ENQH19 | 2019-02-11 06:14:15 DTC client #32. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.YMH19 | 2019-02-11 06:14:15 HD Server | Server thread ending. Closing socket. | Username: Alan Sorrel. | Thread:6884 | 2019-02-11 06:14:15 HD Server Manager | Current server count=1 | 2019-02-11 06:14:15 HD Server | Server thread ending. Closing socket. | Username: Alan Sorrel. | Thread:11932 | 2019-02-11 06:14:15 HD Server Manager | Current server count=0 | 2019-02-11 06:14:15 DTCServer (3) | Creating socket. | 2019-02-11 06:29:06 DTCServer (3) | Connecting to IP: 0.0.0.0. | 2019-02-11 06:29:06 DTCServer (3) | Error connecting. Address Family: 2. IP: 0.0.0.0. Windows error code 10049: The requested address is not valid in its context. | 2019-02-11 06:29:06 * DTCServer (3) | Connect event error. Windows error code 10049: The requested address is not valid in its context. | 2019-02-11 06:29:06 * DTCServer (3) | Shutdown error. Windows error code 10057: A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied. | 2019-02-11 06:29:06 * DTCServer (3) | Shutdown started. Waiting for graceful close. | 2019-02-11 06:29:06 Deleting individual DTC server: DTC client #32. Sierra Chart. 127.0.0.1 | 2019-02-11 06:29:07 DTCServer (3) | Socket receive error. Windows error code 10057: A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied. | 2019-02-11 06:29:10 DTCServer (3) | Closed. | 2019-02-11 06:29:10 DTC Protocol server | Incoming connection from 127.0.0.1. | 2019-02-11 06:30:10 DTCServer (3) | Creating socket. | 2019-02-11 06:30:10 DTC client #33. 127.0.0.1 | Set DTC encoding to Binary VLS | 2019-02-11 06:30:10 DTC client #33. 127.0.0.1 | Requested heartbeat interval: 20 | 2019-02-11 06:30:10 DTC client #33. Sierra Chart. 127.0.0.1 | Received logon request. | 2019-02-11 06:30:10 DTC client #33. Sierra Chart. 127.0.0.1 | Sent successful Logon response message to client. Username: Alan Sorrel. Result text: Connected to SC DTC Protocol server. Service=cqgfix|SymbolSettings=cqg | 2019-02-11 06:30:10 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2019-02-11 06:30:15 HD Server Manager | Started new historical data server. Count=1 | 2019-02-11 06:30:15 HD Server | Thread:2836 (4) | Creating socket. | 2019-02-11 06:30:15 HD Server | Setting DTC encoding to Binary VLS | Thread:2836 | 2019-02-11 06:30:15 HD Server | Received login. Requesting authorization. | Username: Alan Sorrel. | Thread:2836 | 2019-02-11 06:30:15 HD Server | Login has been authorized. | Username: Alan Sorrel. | Thread:2836 | 2019-02-11 06:30:15 HD Server | HD Request #66 | Socket: 4 | Symbol: F.US.YMH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2019-02-11 06:17:23 | ClientRequestID: 66 | Username: Alan Sorrel. | Thread:2836 | 2019-02-11 06:30:15 HD Server | HD Request #66 | Socket: 4 | Symbol: F.US.YMH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 1 | ClientRequestID: 66 | Username: Alan Sorrel. | Thread:2836 | 2019-02-11 06:30:15 HD Server | Thread:2836 (4) | Socket gracefully closed by remote side. | 2019-02-11 06:30:15 HD Server | Thread:2836 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-02-11 06:30:15 HD Server | Thread:2836 (4) | Closed. | 2019-02-11 06:30:15 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2019-02-11 06:30:15 HD Server Manager | Started new historical data server. Count=2 | 2019-02-11 06:30:15 HD Server | Thread:1028 (4) | Creating socket. | 2019-02-11 06:30:15 HD Server | Setting DTC encoding to Binary VLS | Thread:1028 | 2019-02-11 06:30:15 HD Server | Received login. Requesting authorization. | Username: Alan Sorrel. | Thread:1028 | 2019-02-11 06:30:15 HD Server | Login has been authorized. | Username: Alan Sorrel. | Thread:1028 | 2019-02-11 06:30:15 HD Server | HD Request #67 | Socket: 4 | Symbol: F.US.ENQH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2019-02-11 13:29:05 | ClientRequestID: 67 | Username: Alan Sorrel. | Thread:1028 | 2019-02-11 06:30:15 HD Server | HD Request #67 | Socket: 4 | Symbol: F.US.ENQH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 293 | ClientRequestID: 67 | Username: Alan Sorrel. | Thread:1028 | 2019-02-11 06:30:15 HD Server | Thread:1028 (4) | Socket gracefully closed by remote side. | 2019-02-11 06:30:15 HD Server | Thread:1028 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-02-11 06:30:15 HD Server | Thread:1028 (4) | Closed. | 2019-02-11 06:30:15 DTC client #33. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.ENQH19 | 2019-02-11 06:30:15 DTC client #33. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.YMH19 | 2019-02-11 06:30:15 HD Server | Server thread ending. Closing socket. | Username: Alan Sorrel. | Thread:1028 | 2019-02-11 06:30:15 HD Server Manager | Current server count=1 | 2019-02-11 06:30:15 HD Server | Server thread ending. Closing socket. | Username: Alan Sorrel. | Thread:2836 | 2019-02-11 06:30:15 HD Server Manager | Current server count=0 | 2019-02-11 06:30:15 DTCServer (3) | Creating socket. | 2019-02-11 06:45:06 DTCServer (3) | Connecting to IP: 0.0.0.0. | 2019-02-11 06:45:06 DTCServer (3) | Error connecting. Address Family: 2. IP: 0.0.0.0. Windows error code 10049: The requested address is not valid in its context. | 2019-02-11 06:45:06 * DTCServer (3) | Connect event error. Windows error code 10049: The requested address is not valid in its context. | 2019-02-11 06:45:06 * DTCServer (3) | Shutdown error. Windows error code 10057: A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied. | 2019-02-11 06:45:06 * DTCServer (3) | Shutdown started. Waiting for graceful close. | 2019-02-11 06:45:06 Deleting individual DTC server: DTC client #33. Sierra Chart. 127.0.0.1 | 2019-02-11 06:45:07 DTCServer (3) | Socket receive error. Windows error code 10057: A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied. | 2019-02-11 06:45:10 DTCServer (3) | Closed. | 2019-02-11 06:45:10 DTC Protocol server | Incoming connection from 127.0.0.1. | 2019-02-11 06:46:10 DTCServer (3) | Creating socket. | 2019-02-11 06:46:10 DTC client #34. 127.0.0.1 | Set DTC encoding to Binary VLS | 2019-02-11 06:46:10 DTC client #34. 127.0.0.1 | Requested heartbeat interval: 20 | 2019-02-11 06:46:10 DTC client #34. Sierra Chart. 127.0.0.1 | Received logon request. | 2019-02-11 06:46:10 DTC client #34. Sierra Chart. 127.0.0.1 | Sent successful Logon response message to client. Username: Alan Sorrel. Result text: Connected to SC DTC Protocol server. Service=cqgfix|SymbolSettings=cqg | 2019-02-11 06:46:10 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2019-02-11 06:46:15 HD Server Manager | Started new historical data server. Count=1 | 2019-02-11 06:46:15 HD Server | Thread:13304 (4) | Creating socket. | 2019-02-11 06:46:15 HD Server | Setting DTC encoding to Binary VLS | Thread:13304 | 2019-02-11 06:46:15 HD Server | Received login. Requesting authorization. | Username: Alan Sorrel. | Thread:13304 | 2019-02-11 06:46:15 HD Server | Login has been authorized. | Username: Alan Sorrel. | Thread:13304 | 2019-02-11 06:46:15 HD Server | HD Request #68 | Socket: 4 | Symbol: F.US.YMH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2019-02-11 06:17:23 | ClientRequestID: 68 | Username: Alan Sorrel. | Thread:13304 | 2019-02-11 06:46:15 HD Server | HD Request #68 | Socket: 4 | Symbol: F.US.YMH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 1 | ClientRequestID: 68 | Username: Alan Sorrel. | Thread:13304 | 2019-02-11 06:46:15 HD Server | Thread:13304 (4) | Socket gracefully closed by remote side. | 2019-02-11 06:46:15 HD Server | Thread:13304 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-02-11 06:46:15 HD Server | Thread:13304 (4) | Closed. | 2019-02-11 06:46:15 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2019-02-11 06:46:15 HD Server Manager | Started new historical data server. Count=2 | 2019-02-11 06:46:15 DTC client #34. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.ENQH19 | 2019-02-11 06:46:15 HD Server | Thread:8432 (4) | Creating socket. | 2019-02-11 06:46:15 DTC client #34. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.YMH19 | 2019-02-11 06:46:15 HD Server | Setting DTC encoding to Binary VLS | Thread:8432 | 2019-02-11 06:46:15 HD Server | Received login. Requesting authorization. | Username: Alan Sorrel. | Thread:8432 | 2019-02-11 06:46:15 HD Server | Login has been authorized. | Username: Alan Sorrel. | Thread:8432 | 2019-02-11 06:46:15 HD Server | HD Request #69 | Socket: 4 | Symbol: F.US.ENQH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2019-02-11 13:45:03 | ClientRequestID: 69 | Username: Alan Sorrel. | Thread:8432 | 2019-02-11 06:46:15 HD Server | HD Request #69 | Socket: 4 | Symbol: F.US.ENQH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 121 | ClientRequestID: 69 | Username: Alan Sorrel. | Thread:8432 | 2019-02-11 06:46:15 HD Server | Thread:8432 (4) | Socket gracefully closed by remote side. | 2019-02-11 06:46:15 HD Server | Thread:8432 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-02-11 06:46:15 HD Server | Thread:8432 (4) | Closed. | 2019-02-11 06:46:15 HD Server | Server thread ending. Closing socket. | Username: Alan Sorrel. | Thread:8432 | 2019-02-11 06:46:15 HD Server Manager | Current server count=1 | 2019-02-11 06:46:15 HD Server | Server thread ending. Closing socket. | Username: Alan Sorrel. | Thread:13304 | 2019-02-11 06:46:15 HD Server Manager | Current server count=0 | 2019-02-11 06:46:15 DTCServer (3) | Creating socket. | 2019-02-11 06:47:06 DTCServer (3) | Connecting to IP: 0.0.0.0. | 2019-02-11 06:47:06 DTCServer (3) | Error connecting. Address Family: 2. IP: 0.0.0.0. Windows error code 10049: The requested address is not valid in its context. | 2019-02-11 06:47:06 * DTCServer (3) | Connect event error. Windows error code 10049: The requested address is not valid in its context. | 2019-02-11 06:47:06 * DTCServer (3) | Shutdown error. Windows error code 10057: A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied. | 2019-02-11 06:47:06 * DTCServer (3) | Shutdown started. Waiting for graceful close. | 2019-02-11 06:47:06 Deleting individual DTC server: DTC client #34. Sierra Chart. 127.0.0.1 | 2019-02-11 06:47:07 DTCServer (3) | Socket receive error. Windows error code 10057: A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied. | 2019-02-11 06:47:10 DTCServer (3) | Closed. | 2019-02-11 06:47:10 DTC Protocol server | Incoming connection from 127.0.0.1. | 2019-02-11 06:48:09 DTCServer (3) | Creating socket. | 2019-02-11 06:48:09 DTC client #35. 127.0.0.1 | Set DTC encoding to Binary VLS | 2019-02-11 06:48:09 DTC client #35. 127.0.0.1 | Requested heartbeat interval: 20 | 2019-02-11 06:48:09 DTC client #35. Sierra Chart. 127.0.0.1 | Received logon request. | 2019-02-11 06:48:09 DTC client #35. Sierra Chart. 127.0.0.1 | Sent successful Logon response message to client. Username: Alan Sorrel. Result text: Connected to SC DTC Protocol server. Service=cqgfix|SymbolSettings=cqg | 2019-02-11 06:48:09 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2019-02-11 06:48:14 HD Server Manager | Started new historical data server. Count=1 | 2019-02-11 06:48:14 HD Server | Thread:9600 (4) | Creating socket. | 2019-02-11 06:48:14 HD Server | Setting DTC encoding to Binary VLS | Thread:9600 | 2019-02-11 06:48:14 HD Server | Received login. Requesting authorization. | Username: Alan Sorrel. | Thread:9600 | 2019-02-11 06:48:14 HD Server | Login has been authorized. | Username: Alan Sorrel. | Thread:9600 | 2019-02-11 06:48:14 HD Server | HD Request #70 | Socket: 4 | Symbol: F.US.ENQH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2019-02-11 13:47:05 | ClientRequestID: 70 | Username: Alan Sorrel. | Thread:9600 | 2019-02-11 06:48:14 HD Server | HD Request #70 | Socket: 4 | Symbol: F.US.ENQH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 81 | ClientRequestID: 70 | Username: Alan Sorrel. | Thread:9600 | 2019-02-11 06:48:14 HD Server | Thread:9600 (4) | Socket gracefully closed by remote side. | 2019-02-11 06:48:14 HD Server | Thread:9600 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-02-11 06:48:14 HD Server | Thread:9600 (4) | Closed. | 2019-02-11 06:48:14 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2019-02-11 06:48:14 HD Server Manager | Started new historical data server. Count=2 | 2019-02-11 06:48:14 HD Server | Thread:8848 (4) | Creating socket. | 2019-02-11 06:48:14 HD Server | Setting DTC encoding to Binary VLS | Thread:8848 | 2019-02-11 06:48:14 HD Server | Received login. Requesting authorization. | Username: Alan Sorrel. | Thread:8848 | 2019-02-11 06:48:14 HD Server | Login has been authorized. | Username: Alan Sorrel. | Thread:8848 | 2019-02-11 06:48:14 HD Server | HD Request #71 | Socket: 4 | Symbol: F.US.YMH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2019-02-11 06:17:23 | ClientRequestID: 71 | Username: Alan Sorrel. | Thread:8848 | 2019-02-11 06:48:14 HD Server | HD Request #71 | Socket: 4 | Symbol: F.US.YMH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 1 | ClientRequestID: 71 | Username: Alan Sorrel. | Thread:8848 | 2019-02-11 06:48:14 HD Server | Thread:8848 (4) | Socket gracefully closed by remote side. | 2019-02-11 06:48:14 HD Server | Thread:8848 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-02-11 06:48:14 HD Server | Thread:8848 (4) | Closed. | 2019-02-11 06:48:14 DTC client #35. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.ENQH19 | 2019-02-11 06:48:14 DTC client #35. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.YMH19 | 2019-02-11 06:48:14 HD Server | Server thread ending. Closing socket. | Username: Alan Sorrel. | Thread:8848 | 2019-02-11 06:48:14 HD Server Manager | Current server count=1 | 2019-02-11 06:48:14 HD Server | Server thread ending. Closing socket. | Username: Alan Sorrel. | Thread:9600 | 2019-02-11 06:48:14 HD Server Manager | Current server count=0 | 2019-02-11 06:48:14 DTCServer (3) | Creating socket. | 2019-02-11 07:01:06 DTCServer (3) | Connecting to IP: 0.0.0.0. | 2019-02-11 07:01:06 DTCServer (3) | Error connecting. Address Family: 2. IP: 0.0.0.0. Windows error code 10049: The requested address is not valid in its context. | 2019-02-11 07:01:06 * DTCServer (3) | Connect event error. Windows error code 10049: The requested address is not valid in its context. | 2019-02-11 07:01:06 * DTCServer (3) | Shutdown error. Windows error code 10057: A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied. | 2019-02-11 07:01:06 * DTCServer (3) | Shutdown started. Waiting for graceful close. | 2019-02-11 07:01:06 Deleting individual DTC server: DTC client #35. Sierra Chart. 127.0.0.1 | 2019-02-11 07:01:07 DTCServer (3) | Socket receive error. Windows error code 10057: A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied. | 2019-02-11 07:01:09 DTCServer (3) | Closed. | 2019-02-11 07:01:09 DTC Protocol server | Incoming connection from 127.0.0.1. | 2019-02-11 07:02:10 DTCServer (3) | Creating socket. | 2019-02-11 07:02:10 DTC client #36. 127.0.0.1 | Set DTC encoding to Binary VLS | 2019-02-11 07:02:10 DTC client #36. 127.0.0.1 | Requested heartbeat interval: 20 | 2019-02-11 07:02:10 DTC client #36. Sierra Chart. 127.0.0.1 | Received logon request. | 2019-02-11 07:02:10 DTC client #36. Sierra Chart. 127.0.0.1 | Sent successful Logon response message to client. Username: Alan Sorrel. Result text: Connected to SC DTC Protocol server. Service=cqgfix|SymbolSettings=cqg | 2019-02-11 07:02:10 DTC client #36. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.ENQH19 | 2019-02-11 07:02:15 DTC client #36. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.YMH19 | 2019-02-11 07:02:15 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2019-02-11 07:02:16 HD Server Manager | Started new historical data server. Count=1 | 2019-02-11 07:02:16 HD Server | Thread:9784 (4) | Creating socket. | 2019-02-11 07:02:16 HD Server | Setting DTC encoding to Binary VLS | Thread:9784 | 2019-02-11 07:02:16 HD Server | Received login. Requesting authorization. | Username: Alan Sorrel. | Thread:9784 | 2019-02-11 07:02:16 HD Server | Login has been authorized. | Username: Alan Sorrel. | Thread:9784 | 2019-02-11 07:02:16 HD Server | HD Request #72 | Socket: 4 | Symbol: F.US.YMH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2019-02-11 06:17:23 | ClientRequestID: 72 | Username: Alan Sorrel. | Thread:9784 | 2019-02-11 07:02:16 HD Server | HD Request #72 | Socket: 4 | Symbol: F.US.YMH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 1 | ClientRequestID: 72 | Username: Alan Sorrel. | Thread:9784 | 2019-02-11 07:02:16 HD Server | Thread:9784 (4) | Socket gracefully closed by remote side. | 2019-02-11 07:02:16 HD Server | Thread:9784 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-02-11 07:02:16 HD Server | Thread:9784 (4) | Closed. | 2019-02-11 07:02:16 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2019-02-11 07:02:16 HD Server Manager | Started new historical data server. Count=2 | 2019-02-11 07:02:16 HD Server | Thread:7632 (4) | Creating socket. | 2019-02-11 07:02:16 HD Server | Setting DTC encoding to Binary VLS | Thread:7632 | 2019-02-11 07:02:16 HD Server | Received login. Requesting authorization. | Username: Alan Sorrel. | Thread:7632 | 2019-02-11 07:02:16 HD Server | Login has been authorized. | Username: Alan Sorrel. | Thread:7632 | 2019-02-11 07:02:16 HD Server | HD Request #73 | Socket: 4 | Symbol: F.US.ENQH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2019-02-11 14:01:02 | ClientRequestID: 73 | Username: Alan Sorrel. | Thread:7632 | 2019-02-11 07:02:16 HD Server | HD Request #73 | Socket: 4 | Symbol: F.US.ENQH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 128 | ClientRequestID: 73 | Username: Alan Sorrel. | Thread:7632 | 2019-02-11 07:02:16 HD Server | Thread:7632 (4) | Socket gracefully closed by remote side. | 2019-02-11 07:02:16 HD Server | Thread:7632 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-02-11 07:02:16 HD Server | Thread:7632 (4) | Closed. | 2019-02-11 07:02:16 HD Server | Server thread ending. Closing socket. | Username: Alan Sorrel. | Thread:7632 | 2019-02-11 07:02:16 HD Server Manager | Current server count=1 | 2019-02-11 07:02:16 HD Server | Server thread ending. Closing socket. | Username: Alan Sorrel. | Thread:9784 | 2019-02-11 07:02:16 HD Server Manager | Current server count=0 | 2019-02-11 07:02:16 DTCServer (3) | Creating socket. | 2019-02-11 07:17:07 DTCServer (3) | Connecting to IP: 0.0.0.0. | 2019-02-11 07:17:07 DTCServer (3) | Error connecting. Address Family: 2. IP: 0.0.0.0. Windows error code 10049: The requested address is not valid in its context. | 2019-02-11 07:17:07 * DTCServer (3) | Connect event error. Windows error code 10049: The requested address is not valid in its context. | 2019-02-11 07:17:07 * DTCServer (3) | Shutdown error. Windows error code 10057: A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied. | 2019-02-11 07:17:07 * DTCServer (3) | Shutdown started. Waiting for graceful close. | 2019-02-11 07:17:07 Deleting individual DTC server: DTC client #36. Sierra Chart. 127.0.0.1 | 2019-02-11 07:17:07 DTCServer (3) | Socket receive error. Windows error code 10057: A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied. | 2019-02-11 07:17:10 DTCServer (3) | Closed. | 2019-02-11 07:17:10 DTC Protocol server | Incoming connection from 127.0.0.1. | 2019-02-11 07:18:10 DTCServer (3) | Creating socket. | 2019-02-11 07:18:10 DTC client #37. 127.0.0.1 | Set DTC encoding to Binary VLS | 2019-02-11 07:18:10 DTC client #37. 127.0.0.1 | Requested heartbeat interval: 20 | 2019-02-11 07:18:10 DTC client #37. Sierra Chart. 127.0.0.1 | Received logon request. | 2019-02-11 07:18:10 DTC client #37. Sierra Chart. 127.0.0.1 | Sent successful Logon response message to client. Username: Alan Sorrel. Result text: Connected to SC DTC Protocol server. Service=cqgfix|SymbolSettings=cqg | 2019-02-11 07:18:10 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2019-02-11 07:18:15 HD Server Manager | Started new historical data server. Count=1 | 2019-02-11 07:18:15 HD Server | Thread:1400 (4) | Creating socket. | 2019-02-11 07:18:15 HD Server | Setting DTC encoding to Binary VLS | Thread:1400 | 2019-02-11 07:18:15 HD Server | Received login. Requesting authorization. | Username: Alan Sorrel. | Thread:1400 | 2019-02-11 07:18:15 HD Server | Login has been authorized. | Username: Alan Sorrel. | Thread:1400 | 2019-02-11 07:18:15 HD Server | HD Request #74 | Socket: 4 | Symbol: F.US.ENQH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2019-02-11 14:17:07 | ClientRequestID: 74 | Username: Alan Sorrel. | Thread:1400 | 2019-02-11 07:18:15 HD Server | HD Request #74 | Socket: 4 | Symbol: F.US.ENQH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 208 | ClientRequestID: 74 | Username: Alan Sorrel. | Thread:1400 | 2019-02-11 07:18:15 HD Server | Thread:1400 (4) | Socket gracefully closed by remote side. | 2019-02-11 07:18:15 HD Server | Thread:1400 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-02-11 07:18:15 HD Server | Thread:1400 (4) | Closed. | 2019-02-11 07:18:15 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2019-02-11 07:18:15 HD Server Manager | Started new historical data server. Count=2 | 2019-02-11 07:18:15 HD Server | Thread:13296 (4) | Creating socket. | 2019-02-11 07:18:15 HD Server | Setting DTC encoding to Binary VLS | Thread:13296 | 2019-02-11 07:18:15 HD Server | Received login. Requesting authorization. | Username: Alan Sorrel. | Thread:13296 | 2019-02-11 07:18:15 HD Server | Login has been authorized. | Username: Alan Sorrel. | Thread:13296 | 2019-02-11 07:18:15 HD Server | HD Request #75 | Socket: 4 | Symbol: F.US.YMH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2019-02-11 06:17:23 | ClientRequestID: 75 | Username: Alan Sorrel. | Thread:13296 | 2019-02-11 07:18:15 HD Server | HD Request #75 | Socket: 4 | Symbol: F.US.YMH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 1 | ClientRequestID: 75 | Username: Alan Sorrel. | Thread:13296 | 2019-02-11 07:18:15 HD Server | Thread:13296 (4) | Socket gracefully closed by remote side. | 2019-02-11 07:18:15 HD Server | Thread:13296 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-02-11 07:18:15 HD Server | Thread:13296 (4) | Closed. | 2019-02-11 07:18:15 DTC client #37. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.ENQH19 | 2019-02-11 07:18:15 DTC client #37. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.YMH19 | 2019-02-11 07:18:15 HD Server | Server thread ending. Closing socket. | Username: Alan Sorrel. | Thread:13296 | 2019-02-11 07:18:15 HD Server Manager | Current server count=1 | 2019-02-11 07:18:15 HD Server | Server thread ending. Closing socket. | Username: Alan Sorrel. | Thread:1400 | 2019-02-11 07:18:15 HD Server Manager | Current server count=0 | 2019-02-11 07:18:15 F.US.ENQH19 10 Sec #1 | Reloading chart. | 2019-02-11 07:32:58 F.US.ENQH19 10 Sec #7 | Reloading chart. | 2019-02-11 07:32:58 F.US.ENQH19 20 Sec #1 | Reloading chart. | 2019-02-11 07:33:00 F.US.ENQH19 20 Sec #7 | Reloading chart. | 2019-02-11 07:33:00 F.US.ENQH19 30 Sec #1 | Reloading chart. | 2019-02-11 07:33:02 F.US.ENQH19 30 Sec #7 | Reloading chart. | 2019-02-11 07:33:02 DTCServer (3) | Creating socket. | 2019-02-11 07:33:06 DTCServer (3) | Connecting to IP: 0.0.0.0. | 2019-02-11 07:33:06 DTCServer (3) | Error connecting. Address Family: 2. IP: 0.0.0.0. Windows error code 10049: The requested address is not valid in its context. | 2019-02-11 07:33:06 * DTCServer (3) | Connect event error. Windows error code 10049: The requested address is not valid in its context. | 2019-02-11 07:33:06 * DTCServer (3) | Shutdown error. Windows error code 10057: A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied. | 2019-02-11 07:33:07 * DTCServer (3) | Shutdown started. Waiting for graceful close. | 2019-02-11 07:33:07 Deleting individual DTC server: DTC client #37. Sierra Chart. 127.0.0.1 | 2019-02-11 07:33:07 DTCServer (3) | Socket receive error. Windows error code 10057: A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied. | 2019-02-11 07:33:10 DTCServer (3) | Closed. | 2019-02-11 07:33:10 F.US.ENQH19 20 Sec #1 | Reloading chart. | 2019-02-11 07:33:43 F.US.ENQH19 20 Sec #7 | Reloading chart. | 2019-02-11 07:33:43 F.US.ENQH19 20 Sec #1 | Reloading chart. | 2019-02-11 07:33:48 F.US.ENQH19 10 Sec #1 | Reloading chart. | 2019-02-11 07:33:50 F.US.ENQH19 10 Sec #7 | Reloading chart. | 2019-02-11 07:33:50 F.US.ENQH19 25 Sec #1 | Reloading chart. | 2019-02-11 07:33:52 F.US.ENQH19 25 Sec #7 | Reloading chart. | 2019-02-11 07:33:52 F.US.ENQH19 30 Sec #1 | Reloading chart. | 2019-02-11 07:33:55 F.US.ENQH19 30 Sec #7 | Reloading chart. | 2019-02-11 07:33:55 F.US.ENQH19 1 Min 30 Sec #6 | Reloading chart. | 2019-02-11 07:34:06 Chart #6 has tagged chart #1 for full recalculation. Chartbook: March NQ - 1 to 1.Cht | 2019-02-11 07:34:07 Chart #6 has tagged chart #7 for full recalculation. Chartbook: March NQ - 1 to 1.Cht | 2019-02-11 07:34:07 Chart #6 has tagged chart #1 for full recalculation. Chartbook: March NQ - 1 to 1.Cht | 2019-02-11 07:34:07 Chart #6 has tagged chart #7 for full recalculation. Chartbook: March NQ - 1 to 1.Cht | 2019-02-11 07:34:07 F.US.ENQH19 30 Sec #1 | Performing a full recalculation because it has been tagged. Chartbook: March NQ - 1 to 1.Cht | 2019-02-11 07:34:07 F.US.ENQH19 30 Sec #7 | Performing a full recalculation because it has been tagged. Chartbook: March NQ - 1 to 1.Cht | 2019-02-11 07:34:07 DTC Protocol server | Incoming connection from 127.0.0.1. | 2019-02-11 07:34:10 DTCServer (3) | Creating socket. | 2019-02-11 07:34:10 DTC client #38. 127.0.0.1 | Set DTC encoding to Binary VLS | 2019-02-11 07:34:10 DTC client #38. 127.0.0.1 | Requested heartbeat interval: 20 | 2019-02-11 07:34:10 DTC client #38. Sierra Chart. 127.0.0.1 | Received logon request. | 2019-02-11 07:34:10 DTC client #38. Sierra Chart. 127.0.0.1 | Sent successful Logon response message to client. Username: Alan Sorrel. Result text: Connected to SC DTC Protocol server. Service=cqgfix|SymbolSettings=cqg | 2019-02-11 07:34:10 DTC client #38. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.ENQH19 | 2019-02-11 07:34:15 DTC client #38. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.YMH19 | 2019-02-11 07:34:15 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2019-02-11 07:34:16 HD Server Manager | Started new historical data server. Count=1 | 2019-02-11 07:34:16 HD Server | Thread:12692 (4) | Creating socket. | 2019-02-11 07:34:16 HD Server | Setting DTC encoding to Binary VLS | Thread:12692 | 2019-02-11 07:34:16 HD Server | Received login. Requesting authorization. | Username: Alan Sorrel. | Thread:12692 | 2019-02-11 07:34:16 HD Server | Login has been authorized. | Username: Alan Sorrel. | Thread:12692 | 2019-02-11 07:34:16 HD Server | HD Request #76 | Socket: 4 | Symbol: F.US.YMH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2019-02-11 06:17:23 | ClientRequestID: 76 | Username: Alan Sorrel. | Thread:12692 | 2019-02-11 07:34:16 HD Server | HD Request #76 | Socket: 4 | Symbol: F.US.YMH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 1 | ClientRequestID: 76 | Username: Alan Sorrel. | Thread:12692 | 2019-02-11 07:34:16 HD Server | Thread:12692 (4) | Socket gracefully closed by remote side. | 2019-02-11 07:34:16 HD Server | Thread:12692 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-02-11 07:34:16 HD Server | Thread:12692 (4) | Closed. | 2019-02-11 07:34:16 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2019-02-11 07:34:16 HD Server Manager | Started new historical data server. Count=2 | 2019-02-11 07:34:16 HD Server | Thread:13304 (4) | Creating socket. | 2019-02-11 07:34:16 HD Server | Setting DTC encoding to Binary VLS | Thread:13304 | 2019-02-11 07:34:16 HD Server | Received login. Requesting authorization. | Username: Alan Sorrel. | Thread:13304 | 2019-02-11 07:34:16 HD Server | Login has been authorized. | Username: Alan Sorrel. | Thread:13304 | 2019-02-11 07:34:16 HD Server | Server thread ending. Closing socket. | Username: Alan Sorrel. | Thread:12692 | 2019-02-11 07:34:16 HD Server | HD Request #77 | Socket: 4 | Symbol: F.US.ENQH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2019-02-11 14:33:07 | ClientRequestID: 77 | Username: Alan Sorrel. | Thread:13304 | 2019-02-11 07:34:16 HD Server Manager | Current server count=1 | 2019-02-11 07:34:16 HD Server | HD Request #77 | Socket: 4 | Symbol: F.US.ENQH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 2852 | ClientRequestID: 77 | Username: Alan Sorrel. | Thread:13304 | 2019-02-11 07:34:16 HD Server | Thread:13304 (4) | Socket gracefully closed by remote side. | 2019-02-11 07:34:16 HD Server | Thread:13304 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-02-11 07:34:16 HD Server | Thread:13304 (4) | Closed. | 2019-02-11 07:34:16 HD Server | Server thread ending. Closing socket. | Username: Alan Sorrel. | Thread:13304 | 2019-02-11 07:34:16 HD Server Manager | Current server count=0 | 2019-02-11 07:34:16 Successfully moved C:\SierraChart\Data\March 2019 NQ - ATR (bottom).scss.temp file to the folder C:\SierraChart\Data\ | 2019-02-11 07:38:46 Successfully moved C:\SierraChart\Data\March 2019 NQ - Potential Buy or Sell Signals.scss.temp file to the folder C:\SierraChart\Data\ | 2019-02-11 07:38:46 Successfully moved C:\SierraChart\Data\March 2019 NQ - LT %K vs %D.scss.temp file to the folder C:\SierraChart\Data\ | 2019-02-11 07:38:46 Successfully moved C:\SierraChart\Data\March 2019 NQ LT - High and Low 5 Bars.scss.temp file to the folder C:\SierraChart\Data\ | 2019-02-11 07:38:46 Successfully moved C:\SierraChart\Data\March 2019 NQ - Closing Prices.scss.temp file to the folder C:\SierraChart\Data\ | 2019-02-11 07:38:46 Successfully moved C:\SierraChart\Data\March 2019 NQ - ATR (bottom).scss.temp file to the folder C:\SierraChart\Data\ | 2019-02-11 07:39:29 Successfully moved C:\SierraChart\Data\March 2019 NQ - Potential Buy or Sell Signals.scss.temp file to the folder C:\SierraChart\Data\ | 2019-02-11 07:39:29 Successfully moved C:\SierraChart\Data\March 2019 NQ - LT %K vs %D.scss.temp file to the folder C:\SierraChart\Data\ | 2019-02-11 07:39:29 Successfully moved C:\SierraChart\Data\March 2019 NQ LT - High and Low 5 Bars.scss.temp file to the folder C:\SierraChart\Data\ | 2019-02-11 07:39:29 Successfully moved C:\SierraChart\Data\March 2019 NQ - Closing Prices.scss.temp file to the folder C:\SierraChart\Data\ | 2019-02-11 07:39:29 Successfully moved C:\SierraChart\Data\March 2019 NQ - ATR (bottom).scss.temp file to the folder C:\SierraChart\Data\ | 2019-02-11 07:40:12 Successfully moved C:\SierraChart\Data\March 2019 NQ - Potential Buy or Sell Signals.scss.temp file to the folder C:\SierraChart\Data\ | 2019-02-11 07:40:12 Successfully moved C:\SierraChart\Data\March 2019 NQ - LT %K vs %D.scss.temp file to the folder C:\SierraChart\Data\ | 2019-02-11 07:40:12 Successfully moved C:\SierraChart\Data\March 2019 NQ LT - High and Low 5 Bars.scss.temp file to the folder C:\SierraChart\Data\ | 2019-02-11 07:40:12 Successfully moved C:\SierraChart\Data\March 2019 NQ - Closing Prices.scss.temp file to the folder C:\SierraChart\Data\ | 2019-02-11 07:40:12 Successfully moved C:\SierraChart\Data\March 2019 NQ - ATR (bottom).scss.temp file to the folder C:\SierraChart\Data\ | 2019-02-11 07:42:23 Successfully moved C:\SierraChart\Data\March 2019 NQ - Potential Buy or Sell Signals.scss.temp file to the folder C:\SierraChart\Data\ | 2019-02-11 07:42:23 Successfully moved C:\SierraChart\Data\March 2019 NQ - LT %K vs %D.scss.temp file to the folder C:\SierraChart\Data\ | 2019-02-11 07:42:23 Successfully moved C:\SierraChart\Data\March 2019 NQ LT - High and Low 5 Bars.scss.temp file to the folder C:\SierraChart\Data\ | 2019-02-11 07:42:23 Successfully moved C:\SierraChart\Data\March 2019 NQ - Closing Prices.scss.temp file to the folder C:\SierraChart\Data\ | 2019-02-11 07:42:24 Successfully moved C:\SierraChart\Data\March 2019 NQ - ATR (bottom).scss.temp file to the folder C:\SierraChart\Data\ | 2019-02-11 07:43:40 Successfully moved C:\SierraChart\Data\March 2019 NQ - Potential Buy or Sell Signals.scss.temp file to the folder C:\SierraChart\Data\ | 2019-02-11 07:43:40 Successfully moved C:\SierraChart\Data\March 2019 NQ - LT %K vs %D.scss.temp file to the folder C:\SierraChart\Data\ | 2019-02-11 07:43:40 Successfully moved C:\SierraChart\Data\March 2019 NQ LT - High and Low 5 Bars.scss.temp file to the folder C:\SierraChart\Data\ | 2019-02-11 07:43:40 Successfully moved C:\SierraChart\Data\March 2019 NQ - Closing Prices.scss.temp file to the folder C:\SierraChart\Data\ | 2019-02-11 07:43:40 Successfully moved C:\SierraChart\Data\March 2019 NQ - ATR (bottom).scss.temp file to the folder C:\SierraChart\Data\ | 2019-02-11 07:43:52 Successfully moved C:\SierraChart\Data\March 2019 NQ - Potential Buy or Sell Signals.scss.temp file to the folder C:\SierraChart\Data\ | 2019-02-11 07:43:52 Successfully moved C:\SierraChart\Data\March 2019 NQ - LT %K vs %D.scss.temp file to the folder C:\SierraChart\Data\ | 2019-02-11 07:43:52 Successfully moved C:\SierraChart\Data\March 2019 NQ LT - High and Low 5 Bars.scss.temp file to the folder C:\SierraChart\Data\ | 2019-02-11 07:43:52 Successfully moved C:\SierraChart\Data\March 2019 NQ - Closing Prices.scss.temp file to the folder C:\SierraChart\Data\ | 2019-02-11 07:43:52 F.US.ENQH19 35 Sec #1 | Reloading chart. | 2019-02-11 07:48:52 F.US.ENQH19 35 Sec #7 | Reloading chart. | 2019-02-11 07:48:52 F.US.ENQH19 1 Min 45 Sec #6 | Reloading chart. | 2019-02-11 07:48:53 Chart #6 has tagged chart #1 for full recalculation. Chartbook: March NQ - 1 to 1.Cht | 2019-02-11 07:48:54 Chart #6 has tagged chart #7 for full recalculation. Chartbook: March NQ - 1 to 1.Cht | 2019-02-11 07:48:54 Chart #6 has tagged chart #1 for full recalculation. Chartbook: March NQ - 1 to 1.Cht | 2019-02-11 07:48:54 Chart #6 has tagged chart #7 for full recalculation. Chartbook: March NQ - 1 to 1.Cht | 2019-02-11 07:48:54 F.US.ENQH19 35 Sec #1 | Performing a full recalculation because it has been tagged. Chartbook: March NQ - 1 to 1.Cht | 2019-02-11 07:48:54 F.US.ENQH19 35 Sec #7 | Performing a full recalculation because it has been tagged. Chartbook: March NQ - 1 to 1.Cht | 2019-02-11 07:48:54 Successfully moved C:\SierraChart\Data\March 2019 NQ - ATR (bottom).scss.temp file to the folder C:\SierraChart\Data\ | 2019-02-11 07:49:05 Successfully moved C:\SierraChart\Data\March 2019 NQ - Potential Buy or Sell Signals.scss.temp file to the folder C:\SierraChart\Data\ | 2019-02-11 07:49:05 Successfully moved C:\SierraChart\Data\March 2019 NQ - LT %K vs %D.scss.temp file to the folder C:\SierraChart\Data\ | 2019-02-11 07:49:05 Successfully moved C:\SierraChart\Data\March 2019 NQ LT - High and Low 5 Bars.scss.temp file to the folder C:\SierraChart\Data\ | 2019-02-11 07:49:05 Successfully moved C:\SierraChart\Data\March 2019 NQ - Closing Prices.scss.temp file to the folder C:\SierraChart\Data\ | 2019-02-11 07:49:05 DTCServer (3) | Creating socket. | 2019-02-11 07:49:07 DTCServer (3) | Connecting to IP: 0.0.0.0. | 2019-02-11 07:49:07 DTCServer (3) | Error connecting. Address Family: 2. IP: 0.0.0.0. Windows error code 10049: The requested address is not valid in its context. | 2019-02-11 07:49:07 * DTCServer (3) | Connect event error. Windows error code 10049: The requested address is not valid in its context. | 2019-02-11 07:49:07 * DTCServer (3) | Shutdown error. Windows error code 10057: A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied. | 2019-02-11 07:49:07 * DTCServer (3) | Shutdown started. Waiting for graceful close. | 2019-02-11 07:49:07 Deleting individual DTC server: DTC client #38. Sierra Chart. 127.0.0.1 | 2019-02-11 07:49:07 DTCServer (3) | Socket receive error. Windows error code 10057: A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied. | 2019-02-11 07:49:10 DTCServer (3) | Closed. | 2019-02-11 07:49:10 DTC Protocol server | Incoming connection from 127.0.0.1. | 2019-02-11 07:50:10 DTCServer (3) | Creating socket. | 2019-02-11 07:50:10 DTC client #39. 127.0.0.1 | Set DTC encoding to Binary VLS | 2019-02-11 07:50:10 DTC client #39. 127.0.0.1 | Requested heartbeat interval: 20 | 2019-02-11 07:50:10 DTC client #39. Sierra Chart. 127.0.0.1 | Received logon request. | 2019-02-11 07:50:10 DTC client #39. Sierra Chart. 127.0.0.1 | Sent successful Logon response message to client. Username: Alan Sorrel. Result text: Connected to SC DTC Protocol server. Service=cqgfix|SymbolSettings=cqg | 2019-02-11 07:50:10 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2019-02-11 07:50:15 HD Server Manager | Started new historical data server. Count=1 | 2019-02-11 07:50:15 HD Server | Thread:3500 (4) | Creating socket. | 2019-02-11 07:50:15 HD Server | Setting DTC encoding to Binary VLS | Thread:3500 | 2019-02-11 07:50:15 HD Server | Received login. Requesting authorization. | Username: Alan Sorrel. | Thread:3500 | 2019-02-11 07:50:15 HD Server | Login has been authorized. | Username: Alan Sorrel. | Thread:3500 | 2019-02-11 07:50:15 HD Server | HD Request #78 | Socket: 4 | Symbol: F.US.ENQH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2019-02-11 14:49:07 | ClientRequestID: 78 | Username: Alan Sorrel. | Thread:3500 | 2019-02-11 07:50:15 HD Server | HD Request #78 | Socket: 4 | Symbol: F.US.ENQH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 1765 | ClientRequestID: 78 | Username: Alan Sorrel. | Thread:3500 | 2019-02-11 07:50:15 HD Server | Thread:3500 (4) | Socket gracefully closed by remote side. | 2019-02-11 07:50:15 HD Server | Thread:3500 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-02-11 07:50:15 HD Server | Thread:3500 (4) | Closed. | 2019-02-11 07:50:15 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2019-02-11 07:50:15 HD Server Manager | Started new historical data server. Count=2 | 2019-02-11 07:50:15 HD Server | Thread:8944 (4) | Creating socket. | 2019-02-11 07:50:15 HD Server | Setting DTC encoding to Binary VLS | Thread:8944 | 2019-02-11 07:50:15 HD Server | Received login. Requesting authorization. | Username: Alan Sorrel. | Thread:8944 | 2019-02-11 07:50:15 HD Server | Login has been authorized. | Username: Alan Sorrel. | Thread:8944 | 2019-02-11 07:50:15 HD Server | HD Request #79 | Socket: 4 | Symbol: F.US.YMH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2019-02-11 06:17:23 | ClientRequestID: 79 | Username: Alan Sorrel. | Thread:8944 | 2019-02-11 07:50:15 HD Server | HD Request #79 | Socket: 4 | Symbol: F.US.YMH19 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 1 | ClientRequestID: 79 | Username: Alan Sorrel. | Thread:8944 | 2019-02-11 07:50:15 HD Server | Thread:8944 (4) | Socket gracefully closed by remote side. | 2019-02-11 07:50:15 HD Server | Thread:8944 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-02-11 07:50:15 HD Server | Thread:8944 (4) | Closed. | 2019-02-11 07:50:15 HD Server | Server thread ending. Closing socket. | Username: Alan Sorrel. | Thread:8944 | 2019-02-11 07:50:15 HD Server Manager | Current server count=1 | 2019-02-11 07:50:15 HD Server | Server thread ending. Closing socket. | Username: Alan Sorrel. | Thread:3500 | 2019-02-11 07:50:15 HD Server Manager | Current server count=0 | 2019-02-11 07:50:15 DTC client #39. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.ENQH19 | 2019-02-11 07:50:15 DTC client #39. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.YMH19 | 2019-02-11 07:50:15 The message log has been sent to support. | 2019-02-11 07:51:45 * HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (4) | Creating socket. Using TLS 1.2. | 2019-02-11 07:51:45 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (4) | Connecting to IP: 46.4.97.203. | 2019-02-11 07:51:45 Sending of the Message Log is completed. The response was saved to C:\SierraChart\Data\MessageLogAnalysis.htm | 2019-02-11 07:51:47 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (4) | Shutdown started. Waiting for graceful close. | 2019-02-11 07:51:47 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (4) | Socket gracefully closed by remote side. | 2019-02-11 07:51:47 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (4) | Closed. | 2019-02-11 07:51:47 |
[2019-02-11 15:37:27] |
This has already been resolved. Update Sierra Chart again with Help >> Download Current Version and do the update on the main instance only and exit the sub instances before the update so that they are updated when they are run again. The version number will remain the same. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-02-11 17:16:11] |
User695658 - Posts: 7 |
Same issue here. I've tried the resolution as posted above (Close sub-instance, update Sierra in main instance) and the issue remains. Keeps trying to connect to the wrong IP. DTCServer (3) | Creating socket. | 2019-02-11 11:51:34 DTCServer (3) | Connecting to IP: 0.0.0.0. | 2019-02-11 11:51:34 DTCServer (3) | Error connecting. Address Family: 2. IP: 0.0.0.0. Windows error code 10049: The requested address is not valid in its context. | 2019-02-11 11:51:34 * DTCServer (3) | Connect event error. Windows error code 10049: The requested address is not valid in its context. | 2019-02-11 11:51:34 * DTCServer (3) | Shutdown error. Windows error code 10057: A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied. | 2019-02-11 11:51:34 * DTCServer (3) | Shutdown started. Waiting for graceful close. | 2019-02-11 11:51:34 Deleting individual DTC server: DTC client #2. Sierra Chart. 127.0.0.1 | 2019-02-11 11:51:35 DTCServer (3) | Socket receive error. Windows error code 10057: A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied. | 2019-02-11 11:51:37 DTCServer (3) | Closed. | 2019-02-11 11:51:37 |
[2019-02-11 17:26:56] |
User977098 - Posts: 28 |
Same issue for me also.
[2019-02-11 17:39:58] |
User75096 - Posts: 48 |
same here as well even after reinstall
[2019-02-11 17:41:01] |
went back to 1870
[2019-02-11 18:31:45] |
We apologize for this. We did resolve the problem with this, but the update went out as 1871 not 1872. 1872 has now been updated and corrected.
