Date/Time: Wed, 09 Sep 2026 19:24:25 +0000
Connect Event Error. Windows Error code 10060.
View Count: 1059
| [2019-02-11 14:16:52] |
| User476868 - Posts: 5 |
Hi, I received this upon starting Sierra Chart. I was prompted to sign-in to my CQG web portal to complete the EULA. After doing that and restarting, I still have the same problem. Msg Log is below. Not sure how to fix so all suggestions welcome. Thanks, ........ Reading Internal Order ID file. | 2019-02-11 13:58:02 Reading Trade Orders file. | 2019-02-11 13:58:02 Reading Trade Positions file. | 2019-02-11 13:58:02 Account Balance file. | 2019-02-11 13:58:02 UDPListener (1364). Port 22904 | Listening on UDP port 22904. | 2019-02-11 13:58:02 Software version: 1872 32-bit | 2019-02-11 13:58:02 Enabled for: Advanced Features. | 2019-02-11 13:58:02 Enabled for: Advanced Features 2. | 2019-02-11 13:58:02 Enabled for: Sierra Chart Historical Data Service. | 2019-02-11 13:58:02 Allow Support for Sierra Chart Data Feeds is enabled. | 2019-02-11 13:58:02 Current selected Data/Trading service: CQG FIX Trading | 2019-02-11 13:58:02 Chart Update Interval: 500 | 2019-02-11 13:58:02 Intraday Data Storage Time Unit: 0 | 2019-02-11 13:58:02 Data/Trade Service Settings automatically set. | 2019-02-11 13:58:02 Time Zone: +00:00:00 (UTC+00) | 2019-02-11 13:58:02 2019-02-11 13:58:01 Local computer time | 2019-02-11 13:58:02 2019-02-11 13:58:01 Local computer time in UTC | 2019-02-11 13:58:02 2019-02-11 13:58:01 Local computer time in SC Time Zone | 2019-02-11 13:58:02 2019-02-11 13:58:01 Server time in UTC | 2019-02-11 13:58:02 Local computer UTC time and Server UTC time difference: 1 seconds. | 2019-02-11 13:58:02 Program path: C:\SierraChart\ | 2019-02-11 13:58:02 Data Files path: C:\SierraChart\Data\ | 2019-02-11 13:58:02 OS Version Number: 10.0 | 2019-02-11 13:58:02 Locale Setting: C | 2019-02-11 13:58:02 DLLs: UserContributedStudies.dll, UserContributedStudies_64.dll | 2019-02-11 13:58:02 Created the DTC Protocol server. | 2019-02-11 13:58:02 DTC Protocol Server listening on port 11099. | 2019-02-11 13:58:02 Created the DTC Protocol historical data server. | 2019-02-11 13:58:02 HD Server Manager | Listening on port 11098 | 2019-02-11 13:58:02 Checking for new symbol settings. Requested symbol settings MD5 for service code cqg. Request ID: 1. | 2019-02-11 13:58:02 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (4) | Creating socket. Using TLS 1.2. | 2019-02-11 13:58:02 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (4) | Connecting to IP: 46.4.97.203. | 2019-02-11 13:58:02 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2019-02-11 13:58:02 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2019-02-11 13:58:02 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2019-02-11 13:58:02 Received 5 login tokens. | 2019-02-11 13:58:02 Symbol settings MD5 received. Request ID: 1. | 2019-02-11 13:58:02 Symbol settings are up-to-date for cqg. | 2019-02-11 13:58:02 HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (2) | Shutdown started. Waiting for graceful close. | 2019-02-11 13:58:02 HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (2) | Socket gracefully closed by remote side. | 2019-02-11 13:58:02 HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (2) | Closed. | 2019-02-11 13:58:02 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (4) | Shutdown started. Waiting for graceful close. | 2019-02-11 13:58:02 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (4) | Socket gracefully closed by remote side. | 2019-02-11 13:58:02 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (4) | Closed. | 2019-02-11 13:58:02 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Creating socket. Using TLS 1.2. | 2019-02-11 13:58:04 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Connecting to IP: 46.4.97.203. | 2019-02-11 13:58:04 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2019-02-11 13:58:04 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2019-02-11 13:58:04 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Closed. | 2019-02-11 13:58:04 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2019-02-11 13:58:07 CQG FIX socket (1) | Creating socket. Using TLS 1.2. | 2019-02-11 13:58:07 CQG FIX socket (1) | Connecting to IP: 208.48.16.214. | 2019-02-11 13:58:07 CQG FIX socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2019-02-11 13:58:28 * CQG FIX: Socket connection was closed without any logout messages sent or received. | 2019-02-11 13:58:28 CQG FIX Trading | Disconnected. | 2019-02-11 13:58:28 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-02-11 13:58:28 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-11 13:58:28 CQG FIX socket (1) | Closed. | 2019-02-11 13:58:28 CQG FIX Trading | Disconnected. | 2019-02-11 13:58:28 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-11 13:58:28 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2019-02-11 13:58:31 CQG FIX socket (1) | Creating socket. Using TLS 1.2. | 2019-02-11 13:58:31 CQG FIX socket (1) | Connecting to IP: 208.48.16.214. | 2019-02-11 13:58:31 CQG FIX socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2019-02-11 13:58:52 * CQG FIX: Socket connection was closed without any logout messages sent or received. | 2019-02-11 13:58:52 CQG FIX Trading | Disconnected. | 2019-02-11 13:58:52 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-02-11 13:58:52 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-11 13:58:52 CQG FIX socket (1) | Closed. | 2019-02-11 13:58:52 CQG FIX Trading | Disconnected. | 2019-02-11 13:58:52 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-11 13:58:52 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2019-02-11 13:58:55 CQG FIX socket (1) | Creating socket. Using TLS 1.2. | 2019-02-11 13:58:55 CQG FIX socket (1) | Connecting to IP: 208.48.16.214. | 2019-02-11 13:58:55 CQG FIX socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2019-02-11 13:59:16 * CQG FIX: Socket connection was closed without any logout messages sent or received. | 2019-02-11 13:59:16 CQG FIX Trading | Disconnected. | 2019-02-11 13:59:16 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-02-11 13:59:16 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-11 13:59:16 CQG FIX socket (1) | Closed. | 2019-02-11 13:59:16 CQG FIX Trading | Disconnected. | 2019-02-11 13:59:16 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-11 13:59:16 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2019-02-11 13:59:19 CQG FIX socket (1) | Creating socket. Using TLS 1.2. | 2019-02-11 13:59:19 CQG FIX socket (1) | Connecting to IP: 208.48.16.214. | 2019-02-11 13:59:19 CQG FIX socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2019-02-11 13:59:40 * CQG FIX: Socket connection was closed without any logout messages sent or received. | 2019-02-11 13:59:40 CQG FIX socket (1) | Closed. | 2019-02-11 13:59:40 CQG FIX Trading | Disconnected. | 2019-02-11 13:59:40 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-02-11 13:59:40 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-11 13:59:40 CQG FIX Trading | Disconnected. | 2019-02-11 13:59:40 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-11 13:59:40 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2019-02-11 13:59:43 CQG FIX socket (1) | Creating socket. Using TLS 1.2. | 2019-02-11 13:59:43 CQG FIX socket (1) | Connecting to IP: 208.48.16.214. | 2019-02-11 13:59:43 CQG FIX socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2019-02-11 14:00:04 * CQG FIX: Socket connection was closed without any logout messages sent or received. | 2019-02-11 14:00:04 CQG FIX Trading | Disconnected. | 2019-02-11 14:00:04 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-02-11 14:00:04 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-11 14:00:04 CQG FIX socket (1) | Closed. | 2019-02-11 14:00:04 CQG FIX Trading | Disconnected. | 2019-02-11 14:00:04 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-11 14:00:04 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2019-02-11 14:00:07 CQG FIX socket (1) | Creating socket. Using TLS 1.2. | 2019-02-11 14:00:07 CQG FIX socket (1) | Connecting to IP: 208.48.16.214. | 2019-02-11 14:00:07 CQG FIX socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2019-02-11 14:00:28 * CQG FIX: Socket connection was closed without any logout messages sent or received. | 2019-02-11 14:00:28 CQG FIX Trading | Disconnected. | 2019-02-11 14:00:28 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-02-11 14:00:28 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-11 14:00:28 CQG FIX socket (1) | Closed. | 2019-02-11 14:00:28 CQG FIX Trading | Disconnected. | 2019-02-11 14:00:28 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-11 14:00:28 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2019-02-11 14:00:31 CQG FIX socket (1) | Creating socket. Using TLS 1.2. | 2019-02-11 14:00:31 CQG FIX socket (1) | Connecting to IP: 208.48.16.214. | 2019-02-11 14:00:31 CQG FIX socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2019-02-11 14:00:52 * CQG FIX: Socket connection was closed without any logout messages sent or received. | 2019-02-11 14:00:52 CQG FIX Trading | Disconnected. | 2019-02-11 14:00:52 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-02-11 14:00:52 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-11 14:00:52 CQG FIX socket (1) | Closed. | 2019-02-11 14:00:52 CQG FIX Trading | Disconnected. | 2019-02-11 14:00:52 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-11 14:00:52 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2019-02-11 14:00:55 CQG FIX socket (1) | Creating socket. Using TLS 1.2. | 2019-02-11 14:00:55 CQG FIX socket (1) | Connecting to IP: 208.48.16.214. | 2019-02-11 14:00:55 CQG FIX socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2019-02-11 14:01:16 * CQG FIX: Socket connection was closed without any logout messages sent or received. | 2019-02-11 14:01:16 CQG FIX Trading | Disconnected. | 2019-02-11 14:01:16 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-02-11 14:01:16 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-11 14:01:16 CQG FIX socket (1) | Closed. | 2019-02-11 14:01:16 CQG FIX Trading | Disconnected. | 2019-02-11 14:01:16 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-11 14:01:16 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2019-02-11 14:01:19 CQG FIX socket (1) | Creating socket. Using TLS 1.2. | 2019-02-11 14:01:19 CQG FIX socket (1) | Connecting to IP: 208.48.16.214. | 2019-02-11 14:01:19 CQG FIX socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2019-02-11 14:01:40 * CQG FIX: Socket connection was closed without any logout messages sent or received. | 2019-02-11 14:01:40 CQG FIX Trading | Disconnected. | 2019-02-11 14:01:40 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-02-11 14:01:40 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-11 14:01:40 CQG FIX socket (1) | Closed. | 2019-02-11 14:01:40 CQG FIX Trading | Disconnected. | 2019-02-11 14:01:40 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-11 14:01:40 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2019-02-11 14:01:43 CQG FIX socket (1) | Creating socket. Using TLS 1.2. | 2019-02-11 14:01:43 CQG FIX socket (1) | Connecting to IP: 208.48.16.214. | 2019-02-11 14:01:43 CQG FIX socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2019-02-11 14:02:04 * CQG FIX: Socket connection was closed without any logout messages sent or received. | 2019-02-11 14:02:04 CQG FIX Trading | Disconnected. | 2019-02-11 14:02:04 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-02-11 14:02:04 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-11 14:02:04 CQG FIX socket (1) | Closed. | 2019-02-11 14:02:04 CQG FIX Trading | Disconnected. | 2019-02-11 14:02:04 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-11 14:02:04 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2019-02-11 14:02:07 CQG FIX socket (1) | Creating socket. Using TLS 1.2. | 2019-02-11 14:02:07 CQG FIX socket (1) | Connecting to IP: 208.48.16.214. | 2019-02-11 14:02:07 CQG FIX socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2019-02-11 14:02:28 * CQG FIX: Socket connection was closed without any logout messages sent or received. | 2019-02-11 14:02:28 CQG FIX Trading | Disconnected. | 2019-02-11 14:02:28 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-02-11 14:02:28 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-11 14:02:28 CQG FIX socket (1) | Closed. | 2019-02-11 14:02:28 CQG FIX Trading | Disconnected. | 2019-02-11 14:02:28 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-11 14:02:28 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2019-02-11 14:02:31 CQG FIX socket (1) | Creating socket. Using TLS 1.2. | 2019-02-11 14:02:31 CQG FIX socket (1) | Connecting to IP: 208.48.16.214. | 2019-02-11 14:02:31 CQG FIX socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2019-02-11 14:02:52 * CQG FIX: Socket connection was closed without any logout messages sent or received. | 2019-02-11 14:02:52 CQG FIX Trading | Disconnected. | 2019-02-11 14:02:52 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-02-11 14:02:52 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-11 14:02:52 CQG FIX socket (1) | Closed. | 2019-02-11 14:02:52 CQG FIX Trading | Disconnected. | 2019-02-11 14:02:52 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-11 14:02:52 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2019-02-11 14:02:55 CQG FIX socket (1) | Creating socket. Using TLS 1.2. | 2019-02-11 14:02:55 CQG FIX socket (1) | Connecting to IP: 208.48.16.214. | 2019-02-11 14:02:55 CQG FIX socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2019-02-11 14:03:16 * CQG FIX: Socket connection was closed without any logout messages sent or received. | 2019-02-11 14:03:16 CQG FIX Trading | Disconnected. | 2019-02-11 14:03:16 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-02-11 14:03:16 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-11 14:03:16 CQG FIX socket (1) | Closed. | 2019-02-11 14:03:16 CQG FIX Trading | Disconnected. | 2019-02-11 14:03:17 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-11 14:03:17 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2019-02-11 14:03:20 CQG FIX socket (1) | Creating socket. Using TLS 1.2. | 2019-02-11 14:03:20 CQG FIX socket (1) | Connecting to IP: 208.48.16.214. | 2019-02-11 14:03:20 CQG FIX socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2019-02-11 14:03:41 * CQG FIX: Socket connection was closed without any logout messages sent or received. | 2019-02-11 14:03:41 CQG FIX Trading | Disconnected. | 2019-02-11 14:03:41 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-02-11 14:03:41 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-11 14:03:41 CQG FIX socket (1) | Closed. | 2019-02-11 14:03:41 CQG FIX Trading | Disconnected. | 2019-02-11 14:03:41 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-11 14:03:41 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2019-02-11 14:03:44 CQG FIX socket (1) | Creating socket. Using TLS 1.2. | 2019-02-11 14:03:44 CQG FIX socket (1) | Connecting to IP: 208.48.16.214. | 2019-02-11 14:03:44 CQG FIX socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2019-02-11 14:04:05 * CQG FIX: Socket connection was closed without any logout messages sent or received. | 2019-02-11 14:04:05 CQG FIX Trading | Disconnected. | 2019-02-11 14:04:05 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-02-11 14:04:05 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-11 14:04:05 CQG FIX socket (1) | Closed. | 2019-02-11 14:04:05 CQG FIX Trading | Disconnected. | 2019-02-11 14:04:05 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-11 14:04:05 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2019-02-11 14:04:08 CQG FIX socket (1) | Creating socket. Using TLS 1.2. | 2019-02-11 14:04:08 CQG FIX socket (1) | Connecting to IP: 208.48.16.214. | 2019-02-11 14:04:08 CQG FIX socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2019-02-11 14:04:29 * CQG FIX: Socket connection was closed without any logout messages sent or received. | 2019-02-11 14:04:29 CQG FIX socket (1) | Closed. | 2019-02-11 14:04:29 CQG FIX Trading | Disconnected. | 2019-02-11 14:04:29 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-02-11 14:04:29 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-11 14:04:29 CQG FIX Trading | Disconnected. | 2019-02-11 14:04:29 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-11 14:04:29 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2019-02-11 14:04:32 CQG FIX socket (1) | Creating socket. Using TLS 1.2. | 2019-02-11 14:04:32 CQG FIX socket (1) | Connecting to IP: 208.48.16.214. | 2019-02-11 14:04:32 CQG FIX socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2019-02-11 14:04:53 * CQG FIX: Socket connection was closed without any logout messages sent or received. | 2019-02-11 14:04:53 CQG FIX Trading | Disconnected. | 2019-02-11 14:04:53 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-02-11 14:04:53 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-11 14:04:53 CQG FIX socket (1) | Closed. | 2019-02-11 14:04:53 CQG FIX Trading | Disconnected. | 2019-02-11 14:04:53 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-11 14:04:53 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2019-02-11 14:04:56 CQG FIX socket (1) | Creating socket. Using TLS 1.2. | 2019-02-11 14:04:56 CQG FIX socket (1) | Connecting to IP: 208.48.16.214. | 2019-02-11 14:04:56 CQG FIX socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2019-02-11 14:05:17 * CQG FIX: Socket connection was closed without any logout messages sent or received. | 2019-02-11 14:05:17 CQG FIX socket (1) | Closed. | 2019-02-11 14:05:17 CQG FIX Trading | Disconnected. | 2019-02-11 14:05:17 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-02-11 14:05:17 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-11 14:05:17 CQG FIX Trading | Disconnected. | 2019-02-11 14:05:17 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-11 14:05:17 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2019-02-11 14:05:20 CQG FIX socket (1) | Creating socket. Using TLS 1.2. | 2019-02-11 14:05:20 CQG FIX socket (1) | Connecting to IP: 208.48.16.214. | 2019-02-11 14:05:20 CQG FIX socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2019-02-11 14:05:41 * CQG FIX: Socket connection was closed without any logout messages sent or received. | 2019-02-11 14:05:41 CQG FIX socket (1) | Closed. | 2019-02-11 14:05:41 CQG FIX Trading | Disconnected. | 2019-02-11 14:05:41 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-02-11 14:05:41 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-11 14:05:41 CQG FIX Trading | Disconnected. | 2019-02-11 14:05:41 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-11 14:05:41 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2019-02-11 14:05:44 CQG FIX socket (1) | Creating socket. Using TLS 1.2. | 2019-02-11 14:05:44 CQG FIX socket (1) | Connecting to IP: 208.48.16.214. | 2019-02-11 14:05:44 CQG FIX socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2019-02-11 14:06:05 * CQG FIX: Socket connection was closed without any logout messages sent or received. | 2019-02-11 14:06:05 CQG FIX Trading | Disconnected. | 2019-02-11 14:06:05 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-02-11 14:06:05 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-11 14:06:05 CQG FIX socket (1) | Closed. | 2019-02-11 14:06:05 CQG FIX Trading | Disconnected. | 2019-02-11 14:06:05 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-11 14:06:05 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2019-02-11 14:06:08 CQG FIX socket (1) | Creating socket. Using TLS 1.2. | 2019-02-11 14:06:08 CQG FIX socket (1) | Connecting to IP: 208.48.16.214. | 2019-02-11 14:06:08 CQG FIX socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2019-02-11 14:06:29 * CQG FIX: Socket connection was closed without any logout messages sent or received. | 2019-02-11 14:06:29 CQG FIX Trading | Disconnected. | 2019-02-11 14:06:29 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-02-11 14:06:29 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-11 14:06:29 CQG FIX socket (1) | Closed. | 2019-02-11 14:06:29 CQG FIX Trading | Disconnected. | 2019-02-11 14:06:29 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-11 14:06:29 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2019-02-11 14:06:32 CQG FIX socket (1) | Creating socket. Using TLS 1.2. | 2019-02-11 14:06:32 CQG FIX socket (1) | Connecting to IP: 208.48.16.214. | 2019-02-11 14:06:32 CQG FIX socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2019-02-11 14:06:53 * CQG FIX: Socket connection was closed without any logout messages sent or received. | 2019-02-11 14:06:53 CQG FIX Trading | Disconnected. | 2019-02-11 14:06:53 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-02-11 14:06:53 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-11 14:06:53 CQG FIX socket (1) | Closed. | 2019-02-11 14:06:53 CQG FIX Trading | Disconnected. | 2019-02-11 14:06:53 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-11 14:06:53 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2019-02-11 14:06:56 CQG FIX socket (1) | Creating socket. Using TLS 1.2. | 2019-02-11 14:06:56 CQG FIX socket (1) | Connecting to IP: 208.48.16.214. | 2019-02-11 14:06:56 CQG FIX socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2019-02-11 14:07:17 * CQG FIX: Socket connection was closed without any logout messages sent or received. | 2019-02-11 14:07:17 CQG FIX Trading | Disconnected. | 2019-02-11 14:07:17 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-02-11 14:07:17 CQG FIX socket (1) | Closed. | 2019-02-11 14:07:17 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-11 14:07:17 CQG FIX Trading | Disconnected. | 2019-02-11 14:07:17 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-11 14:07:17 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2019-02-11 14:07:20 CQG FIX socket (1) | Creating socket. Using TLS 1.2. | 2019-02-11 14:07:20 CQG FIX socket (1) | Connecting to IP: 208.48.16.214. | 2019-02-11 14:07:20 CQG FIX socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2019-02-11 14:07:41 * CQG FIX: Socket connection was closed without any logout messages sent or received. | 2019-02-11 14:07:41 CQG FIX socket (1) | Closed. | 2019-02-11 14:07:41 CQG FIX Trading | Disconnected. | 2019-02-11 14:07:41 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-02-11 14:07:41 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-11 14:07:41 CQG FIX Trading | Disconnected. | 2019-02-11 14:07:41 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-11 14:07:41 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2019-02-11 14:07:44 CQG FIX socket (1) | Creating socket. Using TLS 1.2. | 2019-02-11 14:07:44 CQG FIX socket (1) | Connecting to IP: 208.48.16.214. | 2019-02-11 14:07:44 CQG FIX socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2019-02-11 14:08:05 * CQG FIX: Socket connection was closed without any logout messages sent or received. | 2019-02-11 14:08:05 CQG FIX Trading | Disconnected. | 2019-02-11 14:08:05 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-02-11 14:08:05 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-11 14:08:05 CQG FIX socket (1) | Closed. | 2019-02-11 14:08:05 CQG FIX Trading | Disconnected. | 2019-02-11 14:08:05 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-11 14:08:05 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2019-02-11 14:08:08 CQG FIX socket (1) | Creating socket. Using TLS 1.2. | 2019-02-11 14:08:08 CQG FIX socket (1) | Connecting to IP: 208.48.16.214. | 2019-02-11 14:08:08 CQG FIX socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2019-02-11 14:08:29 * CQG FIX: Socket connection was closed without any logout messages sent or received. | 2019-02-11 14:08:29 CQG FIX Trading | Disconnected. | 2019-02-11 14:08:29 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-02-11 14:08:29 CQG FIX socket (1) | Closed. | 2019-02-11 14:08:29 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-11 14:08:29 CQG FIX Trading | Disconnected. | 2019-02-11 14:08:29 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-11 14:08:29 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2019-02-11 14:08:32 CQG FIX socket (1) | Creating socket. Using TLS 1.2. | 2019-02-11 14:08:32 CQG FIX socket (1) | Connecting to IP: 208.48.16.214. | 2019-02-11 14:08:32 CQG FIX socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2019-02-11 14:08:53 * CQG FIX: Socket connection was closed without any logout messages sent or received. | 2019-02-11 14:08:53 CQG FIX Trading | Disconnected. | 2019-02-11 14:08:53 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-02-11 14:08:53 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-11 14:08:53 CQG FIX socket (1) | Closed. | 2019-02-11 14:08:53 CQG FIX Trading | Disconnected. | 2019-02-11 14:08:53 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-11 14:08:53 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2019-02-11 14:08:56 CQG FIX socket (1) | Creating socket. Using TLS 1.2. | 2019-02-11 14:08:56 CQG FIX socket (1) | Connecting to IP: 208.48.16.214. | 2019-02-11 14:08:56 CQG FIX socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2019-02-11 14:09:17 * CQG FIX: Socket connection was closed without any logout messages sent or received. | 2019-02-11 14:09:17 CQG FIX Trading | Disconnected. | 2019-02-11 14:09:17 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-02-11 14:09:17 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-11 14:09:17 CQG FIX socket (1) | Closed. | 2019-02-11 14:09:17 CQG FIX Trading | Disconnected. | 2019-02-11 14:09:17 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-11 14:09:17 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2019-02-11 14:09:20 CQG FIX socket (1) | Creating socket. Using TLS 1.2. | 2019-02-11 14:09:20 CQG FIX socket (1) | Connecting to IP: 208.48.16.214. | 2019-02-11 14:09:20 CQG FIX socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2019-02-11 14:09:41 * CQG FIX: Socket connection was closed without any logout messages sent or received. | 2019-02-11 14:09:41 CQG FIX socket (1) | Closed. | 2019-02-11 14:09:41 CQG FIX Trading | Disconnected. | 2019-02-11 14:09:41 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-02-11 14:09:41 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-11 14:09:41 CQG FIX Trading | Disconnected. | 2019-02-11 14:09:41 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-11 14:09:41 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2019-02-11 14:09:44 CQG FIX socket (1) | Creating socket. Using TLS 1.2. | 2019-02-11 14:09:44 CQG FIX socket (1) | Connecting to IP: 208.48.16.214. | 2019-02-11 14:09:44 CQG FIX socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2019-02-11 14:10:05 * CQG FIX: Socket connection was closed without any logout messages sent or received. | 2019-02-11 14:10:05 CQG FIX Trading | Disconnected. | 2019-02-11 14:10:05 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-02-11 14:10:05 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-11 14:10:05 CQG FIX socket (1) | Closed. | 2019-02-11 14:10:05 CQG FIX Trading | Disconnected. | 2019-02-11 14:10:05 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-11 14:10:05 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2019-02-11 14:10:08 CQG FIX socket (1) | Creating socket. Using TLS 1.2. | 2019-02-11 14:10:08 CQG FIX socket (1) | Connecting to IP: 208.48.16.214. | 2019-02-11 14:10:08 CQG FIX socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2019-02-11 14:10:29 * CQG FIX: Socket connection was closed without any logout messages sent or received. | 2019-02-11 14:10:29 CQG FIX Trading | Disconnected. | 2019-02-11 14:10:29 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-02-11 14:10:29 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-11 14:10:29 CQG FIX socket (1) | Closed. | 2019-02-11 14:10:29 CQG FIX Trading | Disconnected. | 2019-02-11 14:10:29 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-11 14:10:29 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2019-02-11 14:10:32 CQG FIX socket (1) | Creating socket. Using TLS 1.2. | 2019-02-11 14:10:32 CQG FIX socket (1) | Connecting to IP: 208.48.16.214. | 2019-02-11 14:10:32 CQG FIX socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2019-02-11 14:10:53 * CQG FIX: Socket connection was closed without any logout messages sent or received. | 2019-02-11 14:10:53 CQG FIX Trading | Disconnected. | 2019-02-11 14:10:53 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-02-11 14:10:53 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-11 14:10:53 CQG FIX socket (1) | Closed. | 2019-02-11 14:10:53 CQG FIX Trading | Disconnected. | 2019-02-11 14:10:53 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-11 14:10:53 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2019-02-11 14:10:56 CQG FIX socket (1) | Creating socket. Using TLS 1.2. | 2019-02-11 14:10:56 CQG FIX socket (1) | Connecting to IP: 208.48.16.214. | 2019-02-11 14:10:56 CQG FIX socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2019-02-11 14:11:17 * CQG FIX: Socket connection was closed without any logout messages sent or received. | 2019-02-11 14:11:17 CQG FIX Trading | Disconnected. | 2019-02-11 14:11:17 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-02-11 14:11:17 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-11 14:11:17 CQG FIX socket (1) | Closed. | 2019-02-11 14:11:17 CQG FIX Trading | Disconnected. | 2019-02-11 14:11:17 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-11 14:11:17 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2019-02-11 14:11:20 CQG FIX socket (1) | Creating socket. Using TLS 1.2. | 2019-02-11 14:11:20 CQG FIX socket (1) | Connecting to IP: 208.48.16.214. | 2019-02-11 14:11:20 CQG FIX socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2019-02-11 14:11:41 * CQG FIX: Socket connection was closed without any logout messages sent or received. | 2019-02-11 14:11:41 CQG FIX Trading | Disconnected. | 2019-02-11 14:11:41 CQG FIX socket (1) | Closed. | 2019-02-11 14:11:41 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-02-11 14:11:41 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-11 14:11:41 CQG FIX Trading | Disconnected. | 2019-02-11 14:11:41 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-11 14:11:41 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2019-02-11 14:11:44 CQG FIX socket (1) | Creating socket. Using TLS 1.2. | 2019-02-11 14:11:44 CQG FIX socket (1) | Connecting to IP: 208.48.16.214. | 2019-02-11 14:11:44 CQG FIX socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2019-02-11 14:12:05 * CQG FIX: Socket connection was closed without any logout messages sent or received. | 2019-02-11 14:12:05 CQG FIX Trading | Disconnected. | 2019-02-11 14:12:05 CQG FIX socket (1) | Closed. | 2019-02-11 14:12:05 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-02-11 14:12:05 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-11 14:12:05 CQG FIX Trading | Disconnected. | 2019-02-11 14:12:05 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-11 14:12:05 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2019-02-11 14:12:08 CQG FIX socket (1) | Creating socket. Using TLS 1.2. | 2019-02-11 14:12:08 CQG FIX socket (1) | Connecting to IP: 208.48.16.214. | 2019-02-11 14:12:08 CQG FIX socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2019-02-11 14:12:29 * CQG FIX: Socket connection was closed without any logout messages sent or received. | 2019-02-11 14:12:29 CQG FIX Trading | Disconnected. | 2019-02-11 14:12:29 CQG FIX socket (1) | Closed. | 2019-02-11 14:12:29 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-02-11 14:12:29 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-11 14:12:29 CQG FIX Trading | Disconnected. | 2019-02-11 14:12:29 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-02-11 14:12:29 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2019-02-11 14:12:32 CQG FIX socket (1) | Creating socket. Using TLS 1.2. | 2019-02-11 14:12:32 CQG FIX socket (1) | Connecting to IP: 208.48.16.214. | 2019-02-11 14:12:32 |
| [2019-02-11 14:52:58] |
This is the relevant message: CQG FIX socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2019-02-11 14:12:29 *
There is some connectivity problem to the CQG server. It could be because firewall software on your side blocking the connection. The Windows firewall is not going to cause a problem. For more information, refer to: Data/Trading Service Connection and Symbol Issues: 1.2. Network Communication or Server Problem Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
