Date/Time: Sat, 25 Jan 2025 01:20:56 +0000
Rollover intraday data export
View Count: 677
[2019-02-11 00:13:14]
User493712 - Posts: 11
Hi SC Support,
I tried to export intraday data from ESH19-ESZ18 5-min rollover chart, after applying Edit>>Delete All Data and Download and the Edit>>Export Intraday Data to Text File. It looks the exported data are exactly the same as ESH19, not ESZ18, even before the rollover date (12/13/2018), no matter the rollover method set to Date Rule or Volume Based. But exporting from the rollover daily chart does work. Is the rollover data export not supported on intraday charts? Thank you.
[2019-02-11 16:54:11]
John - SC Support - Posts: 37478
You need to use this command instead:
Edit Menu: Edit >> Export Bar Data to Text File (Edit >>Export Bar Data)
Date Time Of Last Edit: 2019-02-11 19:30:21
