Date/Time: Sat, 25 Jan 2025 01:26:14 +0000
Data feed not received
View Count: 543
[2019-02-10 19:46:10] |
37011434 - Posts: 5 |
Hope this is the right message board. I can log in but no data coming thru. Please advise. Thanks Lee |
[2019-02-10 21:00:53] |
We see you are using CQG. First thing you need to do is to update to the current version of Sierra Chart following the instructions here: Software Download: Fast Update You are running an unacceptably old version. Also the markets will not reopen until 6 PM US Eastern time. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-02-10 21:01:09
