Date/Time: Sat, 25 Jan 2025 00:57:22 +0000
Market depth historical data does not appear on the chart
View Count: 612
[2019-02-10 07:42:40] |
User985092 - Posts: 13 |
I bought the pack 5 but the Market depth historical data does not work (it does not appear on the chart) when I use Replay mode and when markets are closed (the week-end) . Is it normal ? Thank you |
[2019-02-10 22:16:11] |
There has to have been market depth data previously recorded for the particular time period being replayed. Refer to: Replaying Charts: Replaying of Market Depth Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
