Date/Time: Sat, 25 Jan 2025 00:45:43 +0000
[Programming Help] - bar charts and an extra bar
View Count: 610
[2019-02-08 02:52:24] |
User28682 - Posts: 233 |
I have attached a SQ 30 bar chart. The session times for me are 6:30 to 13:00 pst, regular mkt hours. Why am I getting a small bar(tick) for the 13:00 hr where I have circled in red? This is a bad bar, as it usually is very small with just a few trades in it and its after I don't want a new bar started? How do I make my chart end at 13:00 or on the closing bell without getting this bar?
Attachment Deleted. SQ_30_min.png / V - Attached On 2019-02-08 02:51:54 UTC - Size: 33.75 KB - 230 views |
[2019-02-08 03:12:53] |
You need to make the End Time 12:59:59.
