Date/Time: Sat, 25 Jan 2025 00:22:42 +0000
cqg and iqfeed at the same time
View Count: 1440
[2019-02-07 20:47:02]
uM8137 - Posts: 183
I have two SierraCharts at the moment. With the trial account (the one I'm posting from)
I can hook up to my personal Iqfeed subscription just fine. So I know it works.
However, with the AMP futures provided SierraChart account, it uses the CQG data feed.
I would like to view symbols/indicators from IQfeed too.
When I go in to GlobalSettings -> Data/Trade Service Settings and choose
Iqfeed, it says "IQFeed (Not enabled on package) [data]". The username
and password fields are missing, so I can't turn them on.
My desire is not to trade through IQfeed (obviously they are only a data service, no trading),
but rather to be able monitor some of their indicators on a chart while trading the
CGQ feed.
Is it possible to enable the IQFeed too?
Thank you.
[2019-02-07 21:28:57]
You need your own direct account to use IQ Feed . Also between the Sierra Chart Market Statistics data feed and the Sierra Chart Exchange Data Feed you should have everything you need:
And you will save a lot.
Date Time Of Last Edit: 2019-02-07 22:17:28
[2019-02-08 02:55:21]
uM8137 - Posts: 183
I see. Thanks.
Different question: Since AMP futures
provides CGQ data and SierraChart with my account with them,
if instead I paid for a direct SierraChart account, would
I still be able to receive the CGQ data via the broker's CQG
feed without additional charge?
Another Q: can I add the SierraChart realtime and historical data on top of my broker's SierraChart login?
Date Time Of Last Edit: 2019-02-08 02:56:44
[2019-02-08 20:27:03]
Yes of course.
Yes this is explained here:
https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#IntegrationWithTradingServices
