Date/Time: Sat, 25 Jan 2025 00:46:13 +0000
Chartbook Back up
View Count: 959
[2019-02-07 15:30:27]
User37799 - Posts: 6
Dear Sierra Chart,
I recently had a scare. My computer screen went black and I had to bring it in for repair. I thought I had backed up my "Go To" chart book, but when I downloaded the AT software and Sierra Charts on a new computer, it didnt work at all.
I have since got my original computer back and they didn't need to erase the hard drive fortunately. But now I am in a panic to back it up and have the ability to load that specific chart book on a different computer exactly how it is set up on this one, in the event that this one crashes again.
Please help!
Thanks,
[2019-02-07 16:10:28]
You just need to put your Chartbook's which you have saved in another location, into the Data Files Folder which can be determined through this setting:
General Settings Window: Data Files Folder (Global Settings >> General Settings >> Paths >> Files and Folder Paths)
There are also backup Chartbook's available:
Chartbooks (Workspaces): Accessing a Backup Chartbook File
Date Time Of Last Edit: 2019-02-07 16:10:48
