Date/Time: Sat, 25 Jan 2025 00:45:36 +0000
DOM default stop
View Count: 586
[2019-02-07 15:00:34] |
User691479 - Posts: 4 |
Hi, Somewhere I set a step trailing stop so that when I put an order in DOM it attaches a step trail stop by default. I want to change this, but I cannot find where I set it the first time. Any help? |
[2019-02-07 16:31:21] |
This is done through the Targets tab of the Trade Window and is documented here: Attached Orders: Step-By-Step Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
