Date/Time: Sat, 25 Jan 2025 00:32:54 +0000
DOM
View Count: 683
[2019-02-07 03:19:24] |
User982736 - Posts: 46 |
I tried customizing the columns to see trade volume and the app does not show the new columns. I can see trade volume on the DOM using Rithmic RTraderPro, so I know the data is available. I would prefer to see this info on Sierra DOM. Can you tell me how to do this. I have checked the documentation and don't know how to do it with the Rithmic settings. |
[2019-02-07 04:30:51] |
Make sure you are doing this properly and configuring the columns for the particular Trading DOM that you want. Refer to: Global Trade Settings Windows: Customize Chart/Trade DOM Columns (Chart Specific) You might also want to use the Volume by Price study: Chart Trading and the Chart DOM: Daily Volume Profile (Volume by Price) on Trade DOM Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-02-07 13:41:05] |
The Volume by Price was what I needed. I didn't understand the concept of the DOM being a chart.
