Date/Time: Fri, 24 Jan 2025 23:59:42 +0000
Different TPO Values for same study
View Count: 588
[2019-02-06 13:20:31]
User661434 - Posts: 27
Hi
I noticed that my POC Value's Area Lines are different when I use exactly the same study settings in a different chart session time:
The TPO value line study, with a time Period Type set to WEEKS, in a WEEKLY Chart Session is giving different values compared to
the same study with an time Period Type also set to WEEKS, with identically the same settings, in a DAILY Chart Session.
OR
When changing the weekly period to the daily, I get different values although the study is weekly
I have attached the study settings file
Shouldn't this be identical?
Thank You for Your support
imageTPO study settings.jpg / V - Attached On 2019-02-06 13:17:37 UTC - Size: 163.33 KB - 257 views
[2019-02-06 16:30:38]
This cannot possibly be accurate. The chart bars cannot be greater than 1 day based on the TPO Value Area lines subperiod/letter time you have set.
Date Time Of Last Edit: 2019-02-06 16:31:25
