Date/Time: Sat, 25 Jan 2025 01:24:05 +0000
How to save sequence of tabs in chartbook
View Count: 1931
[2019-02-06 12:37:45] |
User94606 - Posts: 327 |
Is there a way to save the tab (chartbooks) sequence in sierra chart instance?
[2019-02-06 17:24:51] |
In the latest version of Sierra Chart there is now Chartbook Groups: Chartbooks (Workspaces): To Open a Chartbook Group Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-02-07 23:36:59] |
I read the charbook group description. How would this save the individuals chartbooks (tabs) in the sequential order I want?
[2019-02-08 20:37:11] |
Okay we did not fully understand what you were looking for. We thought you wanted to be able to open a group of Chartbook's. But if you want to control the actual sequence of how they are opened you cannot.
[2019-02-10 00:02:16] |
User106180 - Posts: 88 |
+1. This would be useful to have.
[2019-02-10 22:44:50] |
This would be involved to support but we easily could make them open in an alphabetical order.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-02-10 22:45:06
[2019-02-10 22:54:03] |
This would be useful to an extent. Here is one example where a non-alphabetical order would be useful - US Treasury Futures where you want them in order of duration: 2 Year -> 5 Year -> 10 Year ZT -> ZF -> ZN |
[2019-02-11 06:58:11] |
Actually we realize now that they are in alphabetical order already. A sort is performed of the filenames before they are opened.
