Date/Time: Sat, 01 Feb 2025 10:05:07 +0000
when pressed "customize Chart/Trade Dom Columns Settings Window wont appear
View Count: 1032
[2019-02-06 09:26:08] |
User569257 - Posts: 10 |
Hi all, when pressed "customize Chart/Trade Dom Columns Settings Window won't appear. It only appears when i press CTRL + ALT + DEL |
2019-02-06_10-24-54.png / V - Attached On 2019-02-06 09:25:20 UTC - Size: 30.17 KB - 251 views Attachment Deleted. |
[2019-02-06 17:36:45] |
This is explained here: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.40 - Dialog Windows Do Not Display Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-02-07 06:59:54] |
Thanks, i just recognized Problem is fixed once i restarted the System |
[2019-07-03 14:37:55] |
Bedhog - Posts: 179 |
This particular window has not opened for a long time. Thank you for this post. As soon as I touched CTRL-ALT the dialog box opened.
[2019-07-03 16:14:53] |
Ok that is good to know. We are going to be starting soon, with removing the Microsoft dialog windows which have this problem and create our own.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-07-03 16:15:20
