Date/Time: Sat, 25 Jan 2025 01:14:15 +0000
Bitmex chase limit not updating price. Wrong Price
View Count: 1415
[2019-02-05 10:37:00]
User619308 - Posts: 7
ActivityType  DateTime  Symbol  OrderActionSource  InternalOrderID  ServiceOrderID  OrderType  Quantity  BuySell  Price  Price2  OrderStatus  FillPrice  FilledQuantity  TradeAccount  OpenClose  ParentInternalOrderID  PositionQuantity  FillExecutionServiceID  HighDuringPosition  LowDuringPosition  Note  AccountBalance
Order  2019-02-05 11:14:20.209  XBTM19-BMEX  Order modification failed | BitMEX Trading Direct error: Invalid price tickSize  698  85c2e30d-5938-45b7-3d27-22038a0054d0  Limit Chase  12  Sell  3362.0    Open      790763  Close    24
Order  2019-02-05 11:14:20.318  XBTM19-BMEX  Auto trail order modification. Trigger price: 3360.500. Using new provided price. Requested Price: 3361.950. Requested Quantity: 12  698  85c2e30d-5938-45b7-3d27-22038a0054d0  Limit Chase  12  Sell  3362.0    Pending Modify      790763  Close    24
I am unable to correctly set chase limit (it doesn't chase), as the trading activity log is showing that it tries to modify for an incorrect price (that is, an incorrect lot size). Is there something wrong potentially in the order i am submiting, or is it a problem with bitmex?
Best regards
[2019-02-05 23:00:33]
The Tick Size is not set correctly. It should be .5. Follow the instructions here:
Global Symbol Settings: Update/Apply Symbol Settings to Charts
Date Time Of Last Edit: 2019-02-05 23:00:53
[2019-02-06 10:07:01]
I do actually have tick sizxe set for 0.50000. My record is XBT?##. Contract months boxes checked for H and M, both of them don't work as chase. I should mention that chase limit does actually work when I open position from trading DOM, however it does not in Automated trading. Below I attach the snippet of code in which I am using the chase limit:
s_SCNewOrder LimitTemplate;
LimitTemplate.OrderType = SCT_ORDERTYPE_LIMIT_CHASE;
LimitTemplate.TimeInForce = SCT_TIF_GOOD_TILL_CANCELED;
LimitTemplate.MaximumChaseAsPrice = 5.0;
LimitTemplate.OrderQuantity = abs(qty);
LimitTemplate.Price1 = (qty > 0)? Bid: Ask;
if (qty < 0) ReturnValue = sc.SellOrder(LimitTemplate);
else ReturnValue = sc.BuyOrder(LimitTemplate);
Best Regards
[2019-02-06 16:25:22]
Check the Tick Size setting in Chart >> Chart Settings.
We will test your code and see what we find out.
[2019-02-07 08:51:56]
Tick Size in Chart >> Chart Settings is also set to 0.5. I am currently using custom written limit chase, but it's still a bit inconvenient, considering that chase limits in Trading DOM work.
[2019-02-12 05:01:40]
We just do not see any problems at all testing this. Unable to reproduce this.
There must be a problem with the tick size in the chart in combination with the data causing the problem with the modified price not being correct. Otherwise, it makes no sense why there would be an issue.
Also update to the current version following the instructions here:
Date Time Of Last Edit: 2019-02-12 05:02:29
