Date/Time: Fri, 24 Jan 2025 20:28:45 +0000
[Programming Help] - Alerts
View Count: 651
[2019-02-04 17:45:11]
User588258 - Posts: 1
Hola, estaria interesado en la posibilidad de poner una alerta en dos de las columnas del dom. La alerta seria de tipo, cuando el valor sea superior a "xxx" que se active una alerta unicamente de aviso.
Si esto es posible, ¿cual seria el precio para asistencia remota?
Muhcas Gracias, adjunto captura de pantalla.
Hello, I would be interested in the possibility of putting an alert in two of the columns of the sun. The alert would be of type, when the value is greater than "xxx" that a warning alert will be activated only.
If this is possible, what would be the price for remote assistance?
Muhcas Thank you, attached screenshot.
https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=25678
