Date/Time: Fri, 24 Jan 2025 20:36:03 +0000
Copying drawings from another chartbook chart
View Count: 703
[2019-02-04 17:01:57] |
User982736 - Posts: 46 |
I copied all drawings from a chart on another chartbook and closed the chartbook. The drawings went away! How do I make the app keep the drawings after I copy them? |
[2019-02-04 18:06:03] |
This is not supported.
