Date/Time: Fri, 31 Jan 2025 18:03:21 +0000
Longer Historic data
View Count: 937
[2019-02-04 11:07:48] |
Fabio - Posts: 118 |
Hi, I am back-testing strategies on a daily / weekly time frames, Fx pairs through Lmax data-feed. I noticed that in some pairs (majors) historical data goes back as far as 1993. In all other pairs instead, historical data goes back no further than 2013 even though I write myself 1993 in the data range. As soon as I click apply to confirm the new setting, the data range changes itself back to 2013. Am I doing something wrong? There is a way to have longer historical data on all pairs? Regards, F. |
[2019-02-04 18:32:48] |
We will see if we can add more historical data. Tell us some of the symbols you require this for.
[2019-02-05 12:44:31] |
Basically I'm back testing a strategies across all the Fx pairs: AUD CAD AUD CHF AUD JPY AUD NZD CAD CHF CAD JPY CHF JPY EUR AUD EUR CAD EUR CHF EUR GBP EUR JPY EUR NZD GBP AUD GBP CAD GBP CHF GBP JPY GBP NZD NZD CAD NZD CHF NZD JPY And all the majors Thanks and kind regards. F. Date Time Of Last Edit: 2019-02-05 12:45:35
[2019-02-08 20:29:13] |
We will make sure the maximum amount of historical data is added for those but allow a couple of weeks for this.
[2019-02-24 17:52:05] |
Good morning, I noticed that some of the above markets now goes back as far as 1993 thanks for that. However, some of them still cannot go back further than 2013. Does this means that older data doesn't exist for them? Regards, F. |
[2019-02-25 20:01:53] |
We did not yet do any work on this. We will do our best to get this done, in the next few days.
[2019-03-02 00:06:53] |
The history on these has been extended. Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download". You just need to do this once per symbol and not for each chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-03-02 17:25:34] |
Just to make sure: I saw there are different initial start date, some market from 1993 and other from 2008, 2001 etc. Is that normal? Regards. |
[2019-03-02 22:33:10] |
Yes the starting dates will vary depending upon how much data we have available. We can see about adding more data. Let us know the particular symbols you want to see more data for.
[2019-03-03 17:46:51] |
It would be great if all of the above listed markets could go back as far as 1993. This could help me to have a linear backtest across all asset classes and have a better understanding of the performance. The markets that still don't have data available to 1993 are: AUDCHF AUDNZD CADCHF CADJPY EURNZD GBPAUD GBPCAD GBPNZD NZDCAD NZDCHF NZDJPY Please let me know if I can assist further. Regards. |
[2019-03-03 23:26:09] |
Okay we are going to check on this but we may not be able to add any further data.
[2019-03-04 06:27:54] |
Alright thanks then. Please let me know in any case, so I can find some other ways in case to find further data. Thanks for you help. Regards. |
[2019-05-26 12:35:50] |
Good morning, I wanted just to checking in and know if it was then possible to extend historical data on the above pairs. Regards, |
[2019-05-28 09:52:53] |
No, we have already added historical data as far back as we have available.
