Date/Time: Fri, 24 Jan 2025 20:30:50 +0000
How to scroll on a 24 tick reversal bar footprint chart?
View Count: 1094
[2019-02-04 10:37:47] |
User144031 - Posts: 6 |
Hi" When I have the foot print chart open on a 3 to 10 tick reversal bar footprint chart. I can scroll from left to right with no problem. When I change it to a 12 to 24 tick reversal bar on the footprint chart it does not scroll and the 24 tick freeze frames completely. Just need some help please.
Attachment Deleted. 12 Tick.PNG / V - Attached On 2019-02-04 10:23:53 UTC - Size: 61.24 KB - 375 views 24 TICK.PNG / V - Attached On 2019-02-04 10:24:01 UTC - Size: 62.01 KB - 428 views |
[2019-02-04 15:29:14] |
Refer to: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Downloading/Viewing More Historical Intraday Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
