Date/Time: Mon, 14 Sep 2026 21:02:32 +0000
Questions on Historical Data from SC Exchange Data Feed
View Count: 1331
[2019-02-04 06:30:52]
User493712 - Posts: 11
Hi SC support,
I'm new to SC and just starting a trial of your exchange data feed. I explored the exported intraday tick data of ESH19 and see some unexpected. Can you explain a little?
1. Milliseconds in timestamps always start from 1 and end at a number less than 100. It looks like a counter not actual millisecond-level timestamp. So this data do not come with actual millisecond timestamp?
2. The data have bid/ask volumes columns but no bid/ask prices or quotes. Do you provide full book historical data including quotes?
Thank you.
[2019-02-04 19:05:18]
1. Yes this is correct. True millisecond time stamping should come in a few months.
2. If the data being exported is tick by tick you will see the bid and ask prices. Refer to step 6 here:
Exporting and Importing Intraday Data Files: Export and Edit
Before exporting the data, set Sierra Chart to a Tick by Tick Data Configuration. Follow the instructions here to do this:
No.
Date Time Of Last Edit: 2019-02-04 20:38:12
[2019-02-04 19:39:35]
I'm confused. Do you mean bid/ask volumes, not bid/ask prices?
In the documentation, only bid/ask volumes are listed in column names.
[2019-02-04 20:39:09]
The bid and ask prices assuming you have used Edit >> Export Intraday Data to Text File
From documentation:
The format of the exported data is as follows: Date, Time, Open, High, Low, Last, Volume, NumberOfTrades, BidVolume, AskVolume. In the case of when a data record consists of 1 tick/trade, NumberOfTrades will be set to 1 in this case, the Open is equal to 0, the High is equal to the Ask price, the Low is equal to the Bid price, and the Last is equal to the trade price. Volume is equal to the volume of the trade.
Date Time Of Last Edit: 2019-02-04 20:39:18
[2019-02-04 22:27:58]
In DTS "Intraday Data Storage Time Unit" set to 1 Tick (see attached), then Edit >> Delete All Data and Download, and I exported using Edit >> Export Intraday Data to Text File. Below is a piece of ESH19.txt. We can see Open is not 0, and low (bid) price is always the same as high (ask) price. Is this really 1 tick/trade?
2019/2/4, 21:59:50, 2721.00, 2721.00, 2721.00, 2721.00, 1, 1, 1, 0
2019/2/4, 21:59:51, 2721.00, 2721.00, 2721.00, 2721.00, 1, 1, 1, 0
2019/2/4, 21:59:52, 2721.00, 2721.00, 2721.00, 2721.00, 1, 1, 1, 0
2019/2/4, 21:59:52.1, 2721.00, 2721.00, 2721.00, 2721.00, 1, 1, 1, 0
2019/2/4, 21:59:52.2, 2721.00, 2721.00, 2721.00, 2721.00, 1, 1, 1, 0
2019/2/4, 21:59:52.3, 2721.00, 2721.00, 2721.00, 2721.00, 3, 1, 3, 0
2019/2/4, 21:59:54, 2721.25, 2721.25, 2721.25, 2721.25, 2, 1, 0, 2
2019/2/4, 21:59:56, 2721.25, 2721.25, 2721.25, 2721.25, 2, 1, 0, 2
2019/2/4, 21:59:56.1, 2721.25, 2721.25, 2721.25, 2721.25, 1, 1, 0, 1
2019/2/4, 21:59:56.2, 2721.25, 2721.25, 2721.25, 2721.25, 1, 1, 0, 1
2019/2/4, 21:59:56.3, 2721.25, 2721.25, 2721.25, 2721.25, 1, 1, 0, 1
2019/2/4, 21:59:56.4, 2721.25, 2721.25, 2721.25, 2721.25, 3, 1, 0, 3
2019/2/4, 21:59:56.5, 2721.25, 2721.25, 2721.25, 2721.25, 1, 1, 0, 1
2019/2/4, 21:59:57, 2721.25, 2721.25, 2721.25, 2721.25, 1, 1, 0, 1
2019/2/4, 21:59:59, 2721.25, 2721.25, 2721.25, 2721.25, 1, 1, 0, 1
2019/2/4, 21:59:59.1, 2721.25, 2721.25, 2721.25, 2721.25, 2, 1, 0, 2
2019/2/4, 21:59:59.2, 2721.25, 2721.25, 2721.25, 2721.25, 1, 1, 0, 1
2019/2/4, 21:59:59.3, 2721.25, 2721.25, 2721.25, 2721.25, 4, 1, 0, 4
2019/2/4, 21:59:59.4, 2721.25, 2721.25, 2721.25, 2721.25, 1, 1, 0, 1
2019/2/4, 21:59:59.5, 2721.25, 2721.25, 2721.25, 2721.25, 10, 1, 0, 10
2019/2/4, 21:59:59.6, 2721.25, 2721.25, 2721.25, 2721.25, 2, 1, 0, 2
2019/2/4, 21:59:59.7, 2721.25, 2721.25, 2721.25, 2721.25, 2, 1, 0, 2
2019/2/4, 21:59:59.8, 2721.00, 2721.00, 2721.00, 2721.00, 2, 1, 2, 0
2019/2/4, 21:59:59.9, 2721.00, 2721.00, 2721.00, 2721.00, 1, 1, 1, 0
2019/2/4, 21:59:59.10, 2721.00, 2721.00, 2721.00, 2721.00, 1, 1, 1, 0
2019/2/4, 21:59:59.11, 2721.00, 2721.00, 2721.00, 2721.00, 1, 1, 1, 0
2019/2/4, 21:59:59.12, 2721.00, 2721.00, 2721.00, 2721.00, 1, 1, 1, 0
2019/2/4, 21:59:59.13, 2721.25, 2721.25, 2721.25, 2721.25, 2, 1, 0, 2
2019/2/4, 21:59:59.14, 2721.25, 2721.25, 2721.25, 2721.25, 2, 1, 0, 2
2019/2/4, 21:59:59.15, 2721.25, 2721.25, 2721.25, 2721.25, 1, 1, 0, 1
2019/2/4, 21:59:59.16, 2721.00, 2721.00, 2721.00, 2721.00, 1, 1, 1, 0
Date Time Of Last Edit: 2019-02-04 22:35:52
imageScreen Shot 2019-02-04 at 1.51.40 PM.png / V - Attached On 2019-02-04 22:19:11 UTC - Size: 110.36 KB - 539 views
[2019-02-05 23:56:39]
This is 1 Tick data but we can see that it is not exported in the format that we have documented, where the High is the Ask price and the Low is the Bid price. This will be resolved in the next release.
[2019-02-10 19:55:34]
Ok I got it correctly from binary file, except open prices at some rows are -1.99e37 not 0 which can be ignored. Looks like this is just exporting tool problem. Your data are good.
(43436.95833913, -1.999001e+37, 2794.75, 2794.5 , 2794.5 , 1, 2, 2, 0),
(43436.95833914, -1.999002e+37, 2794.75, 2794.5 , 2794.5 , 1, 3, 3, 0),
(43436.95833916, -1.999001e+37, 2794.75, 2794.5 , 2794.75, 1, 2, 0, 2),
(43436.95833917, -1.999002e+37, 2794.75, 2794.5 , 2794.75, 1, 3, 0, 3),
(43436.95833918, 0.000000e+00, 2794.75, 2794.5 , 2794.5 , 1, 1, 1, 0),
(43436.95833919, 0.000000e+00, 2794.75, 2794.5 , 2794.75, 1, 1, 0, 1),
(43436.9583392 , 0.000000e+00, 2794.75, 2794.5 , 2794.75, 1, 2, 0, 2),
(43436.95833921, 0.000000e+00, 2794.75, 2794.5 , 2794.75, 1, 1, 0, 1),
(43436.95833922, 0.000000e+00, 2794.75, 2794.5 , 2794.75, 1, 1, 0, 1),
(43436.95833924, 0.000000e+00, 2794.75, 2794.5 , 2794.75, 1, 1, 0, 1),
(43436.95833925, 0.000000e+00, 2794.75, 2794.5 , 2794.75, 1, 2, 0, 2),
(43436.95833926, 0.000000e+00, 2794.75, 2794.5 , 2794.75, 1, 1, 0, 1),
(43436.95833927, 0.000000e+00, 2794.75, 2794.25, 2794.75, 1, 1, 0, 1),
(43436.95833928, 0.000000e+00, 2794.75, 2794.25, 2794.75, 1, 1, 0, 1),
(43436.95833929, 0.000000e+00, 2794.75, 2794.25, 2794.75, 1, 2, 0, 2),
(43436.95833931, 0.000000e+00, 2794.75, 2794.25, 2794.75, 1, 2, 0, 2),
(43436.95833932, 0.000000e+00, 2794.75, 2794.25, 2794.25, 1, 5, 5, 0),
(43436.95833933, 0.000000e+00, 2794.75, 2794.25, 2794.75, 1, 1, 0, 1),
(43436.95833934, 0.000000e+00, 2794.75, 2794.25, 2794.75, 1, 1, 0, 1),
(43436.95833935, 0.000000e+00, 2794.75, 2794.25, 2794.75, 1, 1, 0, 1),
(43436.95833936, -1.999001e+37, 2795. , 2794.25, 2795. , 1, 1, 0, 1),
(43436.95833937, 0.000000e+00, 2795. , 2794.25, 2795. , 1, 1, 0, 1),
(43436.95833939, -1.999002e+37, 2795. , 2794.25, 2795. , 1, 1, 0, 1),
(43436.9583394 , -1.999001e+37, 2795. , 2794.25, 2794.25, 1, 1, 1, 0),
(43436.95833941, 0.000000e+00, 2795. , 2794.25, 2794.25, 1, 5, 5, 0),
(43436.95833942, 0.000000e+00, 2795. , 2794.25, 2794.25, 1, 1, 1, 0),
(43436.95833943, -1.999002e+37, 2795. , 2794.25, 2794.25, 1, 2, 2, 0),
(43436.95833944, 0.000000e+00, 2795. , 2794. , 2795. , 1, 1, 0, 1),
(43436.95833946, 0.000000e+00, 2795. , 2794. , 2795. , 1, 2, 0, 2),
(43436.95833947, -1.999001e+37, 2795. , 2794. , 2795. , 1, 4, 0, 4),
(43436.95833948, -1.999002e+37, 2795. , 2794. , 2795. , 1, 2, 0, 2),
(43436.95833949, 0.000000e+00, 2795. , 2794. , 2795. , 1, 1, 0, 1),
(43436.9583395 , -1.999001e+37, 2795. , 2794. , 2795. , 1, 7, 0, 7),
(43436.95833951, 0.000000e+00, 2795. , 2794. , 2795. , 1, 1, 0, 1),
(43436.95833953, 0.000000e+00, 2795. , 2794. , 2795. , 1, 1, 0, 1),
(43436.95833954, 0.000000e+00, 2795. , 2794. , 2795. , 1, 1, 0, 1),
(43436.95833955, 0.000000e+00, 2795. , 2794. , 2795. , 1, 1, 0, 1),
(43436.95833956, 0.000000e+00, 2795. , 2794. , 2795. , 1, 1, 0, 1),
(43436.95833957, 0.000000e+00, 2795. , 2794. , 2795. , 1, 1, 0, 1),
(43436.95833958, 0.000000e+00, 2795. , 2794. , 2795. , 1, 1, 0, 1),
(43436.95833959, 0.000000e+00, 2795. , 2794. , 2795. , 1, 1, 0, 1),
(43436.95833961, 0.000000e+00, 2795. , 2794. , 2795. , 1, 1, 0, 1),
(43436.95833962, -1.999002e+37, 2795. , 2794. , 2795. , 1, 2, 0, 2),
(43436.95833963, -1.999001e+37, 2795. , 2794. , 2795. , 1, 1, 0, 1),
(43436.95833964, -1.999002e+37, 2795. , 2794. , 2795. , 1, 3, 0, 3),
(43436.95833965, -1.999001e+37, 2795. , 2794. , 2795. , 1, 1, 0, 1),
(43436.95833966, 0.000000e+00, 2795. , 2794. , 2795. , 1, 8, 0, 8),
(43436.95833968, -1.999002e+37, 2795. , 2794. , 2795. , 1, 1, 0, 1),
(43436.95833969, 0.000000e+00, 2795. , 2794. , 2795. , 1, 1, 0, 1),
(43436.9583397 , 0.000000e+00, 2795. , 2794. , 2795. , 1, 1, 0, 1),
(43436.95833971, 0.000000e+00, 2795. , 2794. , 2795. , 1, 2, 0, 2),
(43436.95833972, 0.000000e+00, 2795. , 2794. , 2795. , 1, 1, 0, 1),
(43436.95833973, 0.000000e+00, 2795. , 2794. , 2795. , 1, 25, 0, 25),
(43436.95833975, 0.000000e+00, 2795. , 2794. , 2794. , 1, 1, 1, 0),
(43436.95833976, 0.000000e+00, 2795. , 2793.75, 2795. , 1, 1, 0, 1),
(43436.95833977, 0.000000e+00, 2795. , 2793.75, 2795. , 1, 1, 0, 1),
(43436.95833978, 0.000000e+00, 2795. , 2793.75, 2795. , 1, 5, 0, 5),
(43436.95833979, -1.999001e+37, 2795. , 2793.75, 2793.75, 1, 1, 1, 0),
(43436.9583398 , 0.000000e+00, 2795. , 2793.75, 2793.75, 1, 1, 1, 0),
(43436.95833981, -1.999002e+37, 2795. , 2793.75, 2793.75, 1, 1, 1, 0),
(43436.95833983, -1.999001e+37, 2794.75, 2793.75, 2794.75, 1, 1, 0, 1),
(43436.95833984, -1.999002e+37, 2794.75, 2793.75, 2794.75, 1, 1, 0, 1),
(43436.95833985, 0.000000e+00, 2794.75, 2793.75, 2794.75, 1, 1, 0, 1),
(43436.95833986, -1.999001e+37, 2794.75, 2793.75, 2795. , 1, 9, 0, 9),
(43436.95833987, 0.000000e+00, 2794.75, 2793.75, 2795. , 1, 10, 0, 10),
(43436.95833988, 0.000000e+00, 2794.75, 2793.75, 2795. , 1, 1, 0, 1),
(43436.9583399 , 0.000000e+00, 2794.75, 2793.75, 2795. , 1, 1, 0, 1),
(43436.95833991, 0.000000e+00, 2794.75, 2793.75, 2795. , 1, 1, 0, 1),
(43436.95833992, 0.000000e+00, 2794.75, 2793.75, 2795. , 1, 5, 0, 5)]
[2019-02-11 20:00:56]
If you update to the current version the data will now be exported with the right values using the built-in export functionality.
