Date/Time: Fri, 24 Jan 2025 20:35:19 +0000
Average Bar size
View Count: 1014
[2019-02-04 05:03:04] |
User378205 - Posts: 28 |
Hello Is there an indicator showing average size of bars within X period of time? |
[2019-02-04 18:23:56] |
You could use this moving average study: Moving Average - Time Period Based on the Bar Difference study: Bar Difference Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
