Date/Time: Fri, 24 Jan 2025 20:25:31 +0000
Difficulty diplaying OHLC lines properly
View Count: 686
[2019-02-03 22:50:03] |
TATrader20 - Posts: 6 |
Hi, I am having some difficulty in displaying my OHLC lines properly. Attached is a screenshot of how my charts look. The settings screen that is open is for the chart on the right. The "High" and "Low" lines show properly (previous day), but for some reason, the Open and Close lines show for each individual candle (in this case, 3minutes). I have played around with almost every combination of settings and just cannot figure it out. Including, using daily chart instead of the intraday chart (option 1..'use this intraday chart'). On left part of image is my tpo chart to which i have the same Daily OHLC study attached. Same exact settings as the chart on right and those lines display properly. Any advice? Thank You :) |
Screenshot (3037).png / V - Attached On 2019-02-03 22:46:07 UTC - Size: 139.73 KB - 293 views Attachment Deleted. |
[2019-02-03 23:05:13] |
This is because you have Graph Open and Close Historically set to Yes and it may also relate to displaying on the day session only.
[2019-02-03 23:19:01] |
Ahh beautiful! Such a simple solution that I am sorry to trouble you with lol. Thank You :) |
