Date/Time: Fri, 24 Jan 2025 20:44:50 +0000
Bitcoin session times
View Count: 1164
[2019-02-03 19:41:19] |
TATrader20 - Posts: 6 |
Hi there, i am wondering if it is possible to change the settings for cryptocurrency symbols (mainly bitmex XBT) to where it starts a new weekly candle on Sunday evenings 19:00 EST (or 00:00 UTC, Monday) I see in the global settings where i can change start of week to Monday from Sunday....but that appears that changes ALL symbols. I want to set that for crypto only. More specifically, for my weekly TPO charts. Thanks in advance :) |
[2019-02-04 18:41:56] |
Refer to: Chart Session Times: Weekly Bars Created From Intraday Data Starting at a Particular Day of the Week You will also want to make sure the Session Start Time in the chart is set to 19:00:00. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
