Date/Time: Fri, 29 Mar 2024 06:57:24 +0000
[Locked] - True Millisecond/Microsecond Time Stamping and ACSIL
View Count: 9391
[2020-08-05 19:06:33] |
User355030 - Posts: 163 |
@SCE What's the ETA?
[2020-08-05 19:10:31] |
We cannot answer the question. We can never give time estimates. That is an impossibility and we will often always be wrong especially due to the load we have on this Support Board. That dramatically slows things down for us.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-08-05 19:11:23
[2020-08-10 18:53:12] |
User220914 - Posts: 239 |
We all love sierra chart and appreciate all the work you put in and of course we are at times very SELFISH and want what we need or want individually as fast as possible so we know you gusy work really hard to help us as mch as you can. anyway we are all looking forward to this new format and ability . thank you |
[2020-08-10 20:02:59] |
We will do an initial release, not with millisecond time stamping but with the new integer based SCDateTime object which supports microsecond time stamping. We can have this out before the end of the week. That will need to undergo testing. It is important when updating to this version that you are already running version 2110 or higher and if you go back to a prior version you go back to a version greater or equal to 2110 because Date-Time values will be written as integers to files and you need that version or later for Sierra Chart to be able to read integer Date-Time values. You will have to recompile your custom studies on this version when it comes out. All prior custom studies will no longer be compatible but a simple recompile is all that is necessary. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-08-12 06:29:23] |
Sierra_Chart Engineering - Posts: 13625 |
For the changes to support true millisecond time stamping, go to this thread: Version 2151 Available: Foundation For Millisecond/Microsecond Timestamping Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-09-11 15:38:16] |
ganz - Posts: 1048 |
SC Support There is some typo in the docs Working with the SCDateTime Variables and Values: GetTimeInSecondsWithoutMilliseconds() |
[2020-09-12 02:55:57] |
Specifically what?
[2020-09-12 05:04:16] |
SC Support Working with the SCDateTime Variables and Values: GetTimeInSecondsWithoutMilliseconds() looks like this class member func is doubled and there is no docs for GetTimeInMilliseconds() class member func at all |
[2020-09-12 17:27:19] |
@SCE Is the millisecond timestamping available yet?
[2020-09-12 22:20:00] |
Regarding post #32, we have updated the documentation. Regarding post #33, yes. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-09-12 22:20:08
[2020-09-12 23:51:35] |
What version supports the millisecond time stamping ? @sce |
[2020-09-13 02:42:53] |
The current version does and that is 2166: https://www.sierrachart.com/index.php?page=doc/Whats_New.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-09-13 14:26:01] |
@sce Thank you, last question does market depth data before this update reflect millisecond time stamping, or does the market depth data have to be recorded with the newest version of SC? |
[2020-09-13 22:04:13] |
Yes market depth data has had millisecond time stamping for over a year now.
