Date/Time: Fri, 24 Jan 2025 20:36:28 +0000
Textbook Row Ref using @ gives error (Bug?)
View Count: 606
[2019-02-03 08:04:37] |
User541156 - Posts: 67 |
From what I can see I am exactly following this support article: Working with Spreadsheets: References to Study Subgraph Columns when using the Spreadsheet Study But whenever I try to enter ref to row using @, I start getting errors? Am I missing something? Date Time Of Last Edit: 2019-02-03 08:05:09
with row ref.PNG / V - Attached On 2019-02-03 08:05:02 UTC - Size: 47.39 KB - 277 views without row ref.PNG / V - Attached On 2019-02-03 08:05:05 UTC - Size: 55.68 KB - 256 views |
[2019-02-03 13:29:57] |
For Alert Formulas for a chart and a study you would need to use ID4.SG17[0] instead: Study/Chart Alerts And Scanning: Referencing Data Other Than on the Last Bar/Column In the Chart The format you mention is for direct use in spreadsheet cells. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-02-03 13:30:16
