Date/Time: Tue, 04 Nov 2025 18:08:35 +0000
Forex
View Count: 2478
| [2013-04-09 15:24:11] |
| gmorgan111 - Posts: 121 |
Can I run the FXCM service to trade the forex while running DTN and Rithmic trading the ES on the same copy of sierra chart? Can both be running concurrently while trading both markets? Thanks |
| [2013-04-09 16:44:07] |
You will need to install separate copies of Sierra Chart for this. Please refer to this page: http://www.sierrachart.com/index.php?l=doc/MultipleServices.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
