Date/Time: Thu, 30 Jan 2025 08:28:08 +0000
SC Historical Feed
View Count: 1065
[2019-02-02 07:25:54] |
User379468 - Posts: 508 |
Is it possible to enable broker provided SC pkg 3 for SC Historical Feed/Delayed Intraday data, how?
[2019-02-02 21:20:01] |
Since your account is provided through a broker affiliate you do not have access to that service.You need a direct Sierra Chart account: Direct Sierra Chart Account Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-02-02 21:20:15
[2019-02-02 21:28:42] |
Didn't this used to work before, was this taken away for broker provided SC? Outside of SC data then, is there a way to access any of the freely available elsewhere delayed or end of day data? Or to access realtime data from TD? |
[2019-02-04 19:06:35] |
It is not provided with accounts through a broker. You will need a direct Sierra Chart account.
[2019-03-08 06:23:54] |
Is it possible to: 1. Get a credit from Amp, for not using their broker SC, or get them to cover partial cost of direct SC account? 2. Bill a direct account through the brokerage statement still? |
[2019-03-08 06:37:23] |
1, 2. No.
