Date/Time: Fri, 24 Jan 2025 20:34:10 +0000
Data connection setting for Non-Professional trading account
View Count: 1520
[2019-02-01 21:12:36]
User746879 - Posts: 4
Hi, I have activated market data of full CME Group (CME, CBOT, COMEX, NYMEX) for nonprofessional Trading accounts.
My current Futures Broker is Phillip Capital.
Exchange Agreements
Professional Status: Non-Professional
Is Approved for CME nonprofessional Trading accounts exchange fees: Yes
I can't get the live data and only showed the historical data in charts.
Would you please help to setup it?
Thank you,
Caleb
[2019-02-01 21:40:07]
How do you submit orders through Philip Capital?
For the reason why we ask this question, refer to:
https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#UnderstandingAccessingDataFromCME
If you use the TT platform, we will have a solution ready next week.
[2019-02-01 21:50:52]
I submit orders through "ninjatrader 8" to my Philip Capital account.
Thanks.
[2019-02-01 22:00:43]
Okay does it use CQG or Rithmic for the connection? We need to know which one.
Date Time Of Last Edit: 2019-02-01 22:00:55
[2019-02-01 22:32:50]
Not sure whether CQG or Rithmic is used for the connection. I am waiting for the reply from the brokerage.
Can I try CQG / Rithmic separately to test it?
Is there any instruction for CQG or Rithmic connection?
Thanks a lot.
[2019-02-01 22:43:47]
You can find instructions for each service here:
Supported Data and Trading Services: Supported Services
[2019-02-01 23:15:34]
Confirmed by the brokerage, the connection is using CQG.
Is there any specific setup needed to be done on CQG?
Thanks.
Date Time Of Last Edit: 2019-02-01 23:18:07
[2019-02-03 20:15:44]
Yes there is and that is explained here:
CQG Trading Platform Service: CQG Account Requirements
And refer to the set up instructions here:
CQG Trading Platform Service: Setup Instructions
Date Time Of Last Edit: 2019-02-03 20:15:48
