Date/Time: Fri, 24 Jan 2025 20:26:29 +0000
This account requires activation !
View Count: 606
[2019-02-01 20:33:48]
User138960 - Posts: 2
I've just downloaded Sierrachart by AMP Futures.
When I start the software, a notification appears telling me that I need to activate the account.
You will find the message as an attachment.
How can I do ?
Thanks for your help.
imageAccount-requieres-activation-SierraChart.png / V - Attached On 2019-02-01 20:32:35 UTC - Size: 28.16 KB - 239 views
[2019-02-01 22:13:08]
Sierra Chart - Max - Posts: 5780
Your account has been activated and the usage time extended if necessary.
If Sierra Chart is running, it will automatically be activated within about three minutes. However, you may need to exit from the Sierra Chart charting and trading software by selecting "File >> Exit". And then open Sierra Chart through the icon on your desktop or through the desktop Start menu.
After your Sierra Chart usage time ends you need to pay for additional usage time through "Help >> Add Usage Credit".
Sierra Chart Support
