Date/Time: Fri, 24 Jan 2025 20:25:01 +0000
DOM levels
View Count: 654
[2019-02-01 15:28:46] |
Forward - Posts: 65 |
Hello, how can see on the chart DOM column ALL the levels ? Now the number is 10 default. I don't find the setting. Thank you |
[2019-02-01 17:07:55] |
Refer to the following setting: Chart Settings: Maximum Market Depth Levels (Chart >> Chart Settings >> Market Depth menu) For 50 levels of market depth, you will need to use the Sierra Chart Exchange Data Feed: Sierra Chart Exchange Data Feed We will not provide any technical help for extended market depth data when using Rithmic. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
